Old 06-22-2015, 10:58 PM   #1
In The Ten Ring
Removing the grill brackets from the outer grill.
My passenger side outer grill bracket is pretty rusty. To remove I have to drill through the rivets, right?
Now to put it back together, can I get by with small bolts, nuts, washers, and lock washers?
In The Ten Ring is offline   Reply With Quote
Old 06-23-2015, 01:05 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Removing the grill brackets from the outer grill.
Drill them out and replace with rivet screws. They work and look great.
http://www.ebay.com/itm/8-32-x-5-8-C...item56669190ca
FirstOwner69 is offline   Reply With Quote
Old 06-23-2015, 02:05 AM   #3
In The Ten Ring
Oh wow! Is that what I need to order?
Old 06-23-2015, 10:25 AM   #4
FirstOwner69
That's what I used. I don't have a decent picture but could post some in a few days.
Old 06-23-2015, 11:30 AM   #5
In The Ten Ring
Thanks man, I just now ordered a set.
I bought a set of grill brackets from a forum member 2 years ago but if I can cleanup and reuse mine I will. As much as I can, I try to keep all the original parts on my truck.
