Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 06-24-2012, 10:47 AM   #1
lolife99
67-72 parts collector,…
lolife99's Avatar
Measuring For Wheels Video,...
I get asked almost daily,... either on the board or via PM, about the correct "offset", or "backspacing" for wheels, for these old trucks.
Since my normal answer is to, "Measure your truck, yourself",... I'm going to use this thread to post any info or store any videos that explain the process.
Here's one for a '74 nova, that I found today.
The length of the video is kinda long, but it covers all the details.
Keith
Convert to disc brakes.
lolife99 is offline
Old 06-24-2012, 10:48 AM   #2
El Campo
El Campo's Avatar
Re: Measuring For Wheels Video,...
Awesome!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline
Old 06-24-2012, 11:03 AM   #3
lolife99
lolife99's Avatar
Here's one using the Percy's Wheelrite tool.
Keith
lolife99 is offline
Old 06-24-2012, 11:12 AM   #4
lolife99
lolife99's Avatar
This is a great thread from Car Craft.
http://www.carcraft.com/techarticles...t/viewall.html
It also shows you how to make a quick tool for measuring.
The back wheels can be done easily with a tape measure and a straight edge.
The front is a little more complex, because they have to turn.
The tool in this article allows you to rotate the rotor to check for interference inside the entire fenderwell, AND, turn the wheels left and right to check for chassis interferences.
This is a must for static dropped and bagged trucks, as well as getting a proper fitting wheel on stock trucks.
As most know,... the track width of the rear wheels on the 60-87 trucks are narrower, than the front wheels.
If you run the same width wheel (front and rear) it is obvious, by just looking at your truck.
The front wheels are closer to the fender edge than the rear wheels.
Altering the backspacing or using wider rear wheels, will help mask this issue that GM designed in these trucks.
Keith
lolife99 is offline
Old 06-24-2012, 11:20 AM   #5
lolife99
lolife99's Avatar
I used the above Car Craft article to design my own backspace tool.
I made one with the 5x5 Chevrolet truck bolt pattern and the 5x4.75 car pattern.
I also have one for the 6x5.5 bolt pattern for the 6-lug trucks.
The threaded rod represents the wheel width.
All threaded rod is 1" longer than the wheel width since wheels are measured from the actual tire "bead surface".
The outside-to-outside measurement of most wheels is approximately 1" wider in total width.
(a 20x8.5 wheel will actually measure 9.5" wide)
Keith
lolife99 is offline
Old 06-24-2012, 11:24 AM   #6
SCOTI
SCOTI's Avatar
Nice work on the BS tool.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 06-24-2012, 11:27 AM   #7
lolife99
lolife99's Avatar
Another good thread:
http://www.superchevy.com/technical/...s/viewall.html
Keith
lolife99 is offline
Old 06-24-2012, 11:30 AM   #8
RRR18
RRR18's Avatar
Good Thread!
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline
Old 06-24-2012, 11:32 AM   #9
lolife99
lolife99's Avatar
Thanks.
I made it a few years ago, when I was trying to squeeze a big tire under the rear of my '91 S10.
(that's why it has the 15" diameter spot on it)
I should have made it longer, so I can measure for 22's, 24's and diameter bigger wheels.
I had to make the 6-lug version when we measure wheels for Nate's (72BlckButy) 4.5/6 dropped '69 swb.
Keith
lolife99 is offline
Old 06-24-2012, 11:40 AM   #10
lolife99
lolife99's Avatar
Backspace measuring from Weld Racing Wheels.
Keith
lolife99 is offline
Old 06-24-2012, 11:44 AM   #11
lolife99
lolife99's Avatar
Measuring for wheel "bolt circle".
Keith
lolife99 is offline
Old 06-24-2012, 02:40 PM   #12
big_al_71
big_al_71's Avatar
This is great Keith...You my man always take the time to help and i sure appreciate all your advice/help over the last few years..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 06-26-2012, 07:20 AM   #13
andrewmp6
Can we have a sticky for this ?I will say one thing that wheelrite tool is worth buying if you have to custom order rims or running a totally different suspension then stock.
andrewmp6 is offline
Old 08-13-2012, 09:22 PM   #14
lolife99
lolife99's Avatar
Bringing this back to the top,...
Keith
lolife99 is offline
Old 08-13-2012, 11:46 PM   #15
red02chevy
http://wheelworksinc.com/index.php?o...=78&Itemid=118
Awesome tool for finding out the correct offset and tire clearance.
red02chevy is offline
Old 08-14-2012, 06:45 AM   #16
andrewmp6
I'll ask again can we have this as a sticky please admin.
Old 08-14-2012, 11:33 AM   #17
lolife99
lolife99's Avatar
andrewmp6,... I doubt this will be a sticky.
I can see it maybe being put in the FAQ section.
This board does not use sticky's very often.
Keith
lolife99 is offline
Old 08-14-2012, 11:49 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
andrewmp6,... I doubt this will be a sticky. I can see it maybe being put in the FAQ section. This board does not use sticky's very often.
lolife99 is correct. We have found that too many stickies create clutter that most members don't read. It will be recommended and reviewed as FAQ material.
In the meantime I suggest you subscribe to it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 08-15-2012, 02:15 AM   #19
andrewmp6
Yeah i kinda forgot about the FAQ lol but if it makes it would help answer a lot of questions on what wheels will fit or not.
Old 11-09-2012, 02:03 PM   #20
64shortbox
64shortbox's Avatar
A LOT of good information here!
64shortbox is offline
Old 11-09-2012, 02:53 PM   #21
jimmydean
jimmydean's Avatar
Wow, I was just going over this last weekend when trying to see if I can get OE wheels to work on my truck. Thanks for the info and links.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 01-15-2013, 08:14 PM   #22
lolife99
lolife99's Avatar
Bringing this back to the top, for recent questions.
Keith
lolife99 is offline
Old 02-27-2013, 05:14 AM   #23
ZUBZ
ZUBZ's Avatar
Awesome thread lolife, must subscribe to this and check back when I am ready for wheels....
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline
Old 03-02-2013, 06:22 AM   #24
Andy4639
Old member
Andy4639's Avatar
Wink Re: Measuring For Wheels Video,...
Nice thread man thanks for sharing the info.
Here is a nice little tool I have used over and over again. $5.00 at my local tire store. It gives you all the popular wheel sizes and bolt patterns.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 06-24-2013, 06:29 AM   #25
lolife99
lolife99's Avatar
Bring this back to the top since the questions keep coming.
I recently used my backspace measuring tool on a buddy's '66 Impala wagon.
He wanted to simulate the actual tire height also.
So I added to my backspace tool.
The 1/4" tubing represents the tire height.
It can be adjusted up and down to get the exact height wanted,...
and the tubing moves in and out, when the BS number needs to change.
Keith
lolife99 is offline
