07-05-2015, 09:31 AM | #1 |
Left/Right Brake Caliper Confusion
I lost track of which is which. It's a 72 GMC K2500 (Dana 44). I guess to boil it down my question is Should the bleeders be pointed up or down. Here's a pic of how I installed them. (pointing down) Is this correct or backwards? I hope it's clear enough to see them. Thanks!
07-05-2015, 09:39 AM | #2 |
Re: Left/Right Brake Caliper Confusion
bleeder up on everything I've ever used. that way the air can escape from the top where it will be. Use a soft mallet to tap the caliper too before you crack the bleeder to knock any tiny air bubbles clinging to the inside off.
07-05-2015, 09:46 AM | #3 |
Yep. Always up. Never get all the air out otherwise. It will be trapper above the fluid inside the caliper. "Been there, changed that".
"Life is too short to drive a boring vehicle". Later, Wayne |
07-05-2015, 12:19 PM | #4 |
Ok Thanks for clearing that up for me fellas. I'll swap them back right.
