Old 07-13-2015, 09:30 AM   #1951
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Eric showed up shortly after lunch. We got the brakes bled, still need some minor adjusting, but won't take much.
We also worked on the hydraulic clutch. Will need just a touch more adjusting there also. Slave still feels a little spongy, so still has some air in it. Doing all this around a big block and long tube headers is fun if you've never had the experience.
Later in the evening we switched gears to the engine. Got the covers swapped, #1 set to TDC, distributor pulled.....plenty of room for removal with the cap removed, engine primed, battery installed and of coarse it was dead, so took the battery out of Austins 63 and the oem starter just doesn't have enough to kick it over. Tried jumping off a truck and same result. By this time it was around 830, so we called it a night. I want to come in tonight and recheck that all grounds are good 1st, before I commit to a hi torque starter as it almost sounds like it doesn't have a good enough ground. Ran block to firewall grounds, battery to block and block to frame, so will pull grounds and make sure we have good contact.
Couple of pics of the vintage covers installed.
1964 Short bed trailer
Old 07-13-2015, 09:54 AM   #1952
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Looks sweet!
Old 07-13-2015, 10:21 AM   #1953
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by TJ's Chevy View Post
Looks sweet!
Thanks TJ. Hoping I just have a bad ground issue and will have the engine resolved tonight. 2nd battery was good, but just got a click at the starter, so starter/selonoid either bad or bad grounds in my opinion.
Old 07-13-2015, 10:22 AM   #1954
Pappyx3!
Pappyx3!'s Avatar
Re: 1963 C-10 in NC
Looks sharp!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 07-13-2015, 10:28 AM   #1955
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by Pappyx3! View Post
Looks sharp!
Thanks....be nice to turn her over now!!!
Old 07-13-2015, 10:38 AM   #1956
Pappyx3!
Pappyx3!'s Avatar
Re: 1963 C-10 in NC
In the same boat with you Jon, went to start mine on Sunday, got to hear it run for about 2 mins, for the first time since Nov. Hang in there, I'm sure you'll be making motor music soon.
John 3:16
Old 07-13-2015, 10:51 AM   #1957
Re: 1963 C-10 in NC
Looking good. Hope it goes good and you hear the roar tonight.
Old 07-13-2015, 11:14 AM   #1958
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks....we worked all day in anticipation of firing of the engine. All ready and got.....click. Disappointing, but we'll get it right. The starter was good that I put on it so really hoping just a ground issue. If the ground doesn't resolve it.....pass side header off and starter replacement. The 3 bolt snout starters are very limited on whats available. If I have to replace will probably be a powermaster 3635
Old 07-13-2015, 11:14 AM   #1959
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks and same here. Would love to hear her fire up tonight.
Old 07-13-2015, 11:23 AM   #1960
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Might need some more cranking amps to. Sometimes its the starter....sometimes its the battery not having enough guts to.
Old 07-13-2015, 11:24 AM   #1961
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
1000cca battery is whats installed
Old 07-13-2015, 11:26 AM   #1962
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
1000cca battery
That'll work.
Old 07-13-2015, 12:20 PM   #1963
Eric15chevys
Eric15chevys's Avatar
Re: 1963 C-10 in NC
I had a great time playing with the truck yesterday and wasn't in to much trouble for hanging out all day. I was thinking ground, but you could hear the draw on Austin's truck when you tried to kick it over. I think in the long run a good high torque will save you a lot of headache. Big blocks just take so much to turn them over.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 07-13-2015, 12:45 PM   #1964
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Looking like powermaster 3635 Eric...only hi torque 3 bolt nose starter I found
http://www.jegs.com/i/Powermaster/713/3635/10002/-1
That means header removal on pass side and clutch inspection plates have to drop...love it
Old 07-13-2015, 12:47 PM   #1965
Pappyx3!
Pappyx3!'s Avatar
Re: 1963 C-10 in NC
If you got all those CCA's and the battery is fully charged. I'll bet your problems gonna be all that new paint(connection issues)
Performing the Volt Drops should help you find those issues and correct them real quick.
Not saying that a good PMGR starter would not be a good addition to that BBC.
John 3:16
Old 07-13-2015, 12:50 PM   #1966
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Agreed....I still want to double check grounds 1st.
Old 07-13-2015, 01:14 PM   #1967
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Will be looking at a heat shield also......
Old 07-14-2015, 08:52 AM   #1968
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Went home and my new ground kit arrived. So, new grounds on both heads to firewall. Added a ground from the voltage regulator to the horn to radiator support and moved and cleaned the block to frame connection. It now runs directly to the block, not off a mount to the block.
Old 07-14-2015, 09:11 AM   #1969
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Couple more
Old 07-14-2015, 09:12 AM   #1970
Pappyx3!
Pappyx3!'s Avatar
Re: 1963 C-10 in NC
Ground straps look great! Where did you get them?
John 3:16
Old 07-14-2015, 09:13 AM   #1971
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
And another big concern resolved.
Plenty of room on the tail shaft mount shifter. 1st 3 pics are in 1st gear and last is in reverse. Seat is still two notches from farthest position so still more room to go back. Relieved that we are good here. Do need to figure out a different shift boot as the hurst one will not work here.
Old 07-14-2015, 09:14 AM   #1972
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
And a couple of extra pics
Old 07-14-2015, 09:16 AM   #1973
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got them off ebay. $18 shipped and nice quality
Link: http://www.ebay.com/itm/191358201525...%3AMEBIDX%3AIT
Old 07-14-2015, 09:16 AM   #1974
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Since your the electrician.....do the grounds look placed ok? Any more I should add?
Old 07-14-2015, 10:51 AM   #1975
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Fancy ground straps. My 292 in my 66 never had any for some reason...or any that I remember...its been awhile since I've seen it. haha. My 305 v6 has 1 on the driver's side valve cover to the fire wall. It didn't even matter weather I left it off or not. Not sure if I'm gonna use any on the new engine either...hope I don't need to.
