07-13-2015, 08:55 PM | #226 |
Re: LVPhotos 1962 Build
And back together.... next transmission crossmember.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
07-14-2015, 01:58 PM | #227 |
Hey there...couple of questions for you.
I too, have a 62 and love your grill. I take it that it's chromed steel, yes? Did you have it chromed? If so, who and how much? I have a spare steel one that I need to get chromed. Also, your front fenders, it would appear you bought aftermarket replacements. Who from and how did they fit?? Thanks in advance...love your truck! |
07-14-2015, 02:41 PM | #228 |
The 60-66 GMC/Pontiac guy....
Cool build
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
07-14-2015, 05:41 PM | #229 |
That is my original grill, originally white. Was chromed years ago, assuming it was sent to CA, top notch job cost was $350 then there was a dent driver side that was fixed only tool mark is inside the L. The fenders were bought years ago, I would suggest Goodmark or any other OER dealers. Tuckers Classic Truck here in Las Vegas is normally my goto, now they changed vender and I started a broken budget I go to who has the better product.
07-14-2015, 05:50 PM | #230 |
Pic.
07-17-2015, 05:23 PM | #231 |
Transmission crossmember welded up and smoothed out, ready for some paint.
07-17-2015, 06:58 PM | #232 |
Bam! And used up the last of the paint.
07-18-2015, 01:47 PM | #233 |
All in and on ground. Why would you fully polish stainless steel and then put a sticker on it that won't come off?
07-28-2015, 11:24 AM | #234 |
Nice looking 62. On the cab mounting did you mount it without the factory square brackets or did you channel the cab?
07-28-2015, 11:45 AM | #235 |
The cab is the only thing that has not been off frame. It still sits on factory mounts.
07-29-2015, 07:59 PM | #236 |
That's all she got. Bumper on ground. That is not dog slobber under the headlight, but a tear for not being driven!
07-29-2015, 10:36 PM | #237 |
looks great!
08-02-2015, 02:25 PM | #238 |
Box of wire and fan control from Speedway Motors. Small 12 circuit mini fuse block.
08-02-2015, 02:28 PM | #239 |
Block
08-19-2015, 08:15 AM | #240 |
Hey, do the 295's fit without rubbing the rear wheel tubs on the inside? I'm looking at the same size for the rear but was wondering if I would have to modify by stock wheel tubs. I have a 1965 12 bolt rear. Also, your project looks great..
08-19-2015, 12:07 PM | #241 |
There is a 1/4" rub each side dead center of my aftermarket tubs bulge. That's from side to side movement. My rims are "4.5 inch backspace " Rims can set different with same backspace. No need to trim outer, plenty up travel as well. If your not hitting turns hard or use something other than panhard bar... triangle or watts link.
08-19-2015, 01:03 PM | #242 |
My wheels are 5 inch backspace so it looks like I'll be doing the tubs. Thanks for your help, LV...
09-04-2015, 10:19 PM | #243 |
Working again so here it sits once again.
05-05-2016, 08:05 PM | #244 |
Been awhile since I been home. Parts on order and shop time reserved. Dirty but looking good!
05-10-2016, 02:57 PM | #245 |
How do the new PB trailing arms attach to old crossmember do you have a pic?
05-10-2016, 04:46 PM | #246 |
I don't have a good picture. It bolts in like stock. The rod ends have a "cone" spacer on ech side to center it.
05-12-2016, 07:37 PM | #247 |
Chrome plated IDIDIT column in.
09-12-2016, 08:09 PM | #248 |
New 2 piece driveshaft, new exhaust. Ebrake cables and brake lines. And of course the pictures will be sideways!
09-17-2016, 10:01 AM | #249 |
Trying to right pic.
10-19-2016, 06:21 PM | #250 |
Back in action! All new parts in and testing. Don't like the power brakes(too squishy) so the vacuum line is caped. The quick ratio manual rack is a bit ruff. Fast and sensitive. Going to get some cleaning done and have it out for the weekend.
Tags |
1962 chevy, bagged c10, manual transmission, short bed c 10 |
