Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-30-2015, 01:14 AM   #176
JJ's Sierra Grande
JJ's Sierra Grande's Avatar
Re: Buried to Bagged 1972 2wd
weekends over, pics??
JJ's Sierra Grande is offline   Reply With Quote
Old 06-30-2015, 08:14 AM   #177
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the wire channel cover.
Old 06-30-2015, 05:39 PM   #178
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hahaha, now I am getting pressed for pics!! Really did not get anything significant done this weekend except cleaning the shop!! Of course we have to do that occasionally. I did weld some square tubes to the body dolly to keep the tub from sliding off, safety first!
Thank you sir! I have to weld a small piece on the driver side and put some more tacks on it before it's done. Hope to get that done this weekend!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-15-2015, 01:37 PM   #179
BIG ORANGE
BIG ORANGE's Avatar
Well SLICK got a update on anything to share with us, I would like to see how the cowl cover and windshield mod worked out,,,,,,
Donnie
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-15-2015, 01:41 PM   #180
Slick67
Sofa King Crazy!!
Slick67's Avatar
I'm baaack!!! Have been working a lot and just have not had the time to post! My company called me back after being off just one week and I have been working ever since. July 23 is my supposed last day now. Back to the project!! Got a few minor little things done..... I cut a big hole in the tub....
Just enough to fit the c-notches in!
It felt good seeing it sitting on the frame.
Even while still sitting on the jacks I was happy to see wheels tuckin!!
I should have pulled the wheel wells out first, but you know how it is when you get excited about something.
Old 07-15-2015, 01:52 PM   #181
Slick67
Sofa King Crazy!!
Slick67's Avatar
Donnie
I guess I was posting while you wrote this! There was a little progress made on the top of the windshield frame, just not anything noteworthy really. As for the cowl I am considering a couple of different approaches, one I can do with my limited skill and tools the other will have to be a paid job.
Old 07-15-2015, 02:05 PM   #182
Blown06
Blown06's Avatar
She's looking great tater salad. Lol
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 07-15-2015, 02:19 PM   #183
Slick67
Sofa King Crazy!!
Slick67's Avatar
You just couldn't let that one pass you up could you? HAHHAAHA.
Old 07-15-2015, 02:59 PM   #184
Slick67
Sofa King Crazy!!
Slick67's Avatar
Since it was a large step I took a few extra pics.
This is the first pic of it layed out almost at zero pressure.
This is lifted to almost max.
This is a problem, it's not low enough!!! The heads on the bolts that hold in the trailing arm crossmember make the body and frame "teeter" front to back so this will have to be addressed.
Limbo contests are gonna be fun with this thing!!
Added a fender to check clearance, everything looks good after cutting out for the Slosh Tubz, doesn't look like I'll have to cut into the firewall but things change.
Old 07-15-2015, 03:13 PM   #185
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks great!
What size (diameter) wheel/tire combo will you be running when it's finished?
This will dictate how low it goes.
Keith
Convert to disc brakes.
Old 07-15-2015, 03:18 PM   #186
Blown06
Blown06's Avatar
Weld the bottom of that crossmember then you won't have the bolt heads to deal with. Honestly how often do you plan to remove it? But if you do decide to remove it you only have a few welds to cut.
Me: Jarrod
Old 07-15-2015, 04:27 PM   #187
Slick67
Sofa King Crazy!!
Slick67's Avatar
Looks great!
I was thinking 22X9 front and 24X12 back. Then we have to really get technical and ask what tire size. After deleting the bolt heads I will have a better idea of what I am really dealing with.
I was planning on welding it, just really surprised that it made it sit that far off the ground with the body on. I do not have the body mounts in yet so we'll see how that effects it. Next is body mounts and measurements for all the stuff that will be hidden.
Old 07-15-2015, 04:29 PM   #188
Slick67
Sofa King Crazy!!
Slick67's Avatar
Almost forgot. SLOSH TUBZ!!!!!!
Old 07-15-2015, 04:30 PM   #189
Blown06
Blown06's Avatar
Body mounts will probably raise it 3/4" or so.
Me: Jarrod
Old 07-15-2015, 04:31 PM   #190
Blown06
Blown06's Avatar
Slosh Tubz look sweet!
Me: Jarrod
Old 07-15-2015, 04:59 PM   #191
Slick67
Sofa King Crazy!!
Slick67's Avatar
I figure there is a happy medium between layin the frame, wheel size, and pinch weld removal. I will be Zen when these three things come together. The mounts are not really gonna raise it that much because I stuffed in the old mounts in. So I may be looking at an 1/8th to a 1/4 difference from the pics. But I see you slept at a Best Western last night!!
Old 07-15-2015, 05:02 PM   #192
Blown06
Blown06's Avatar
I always sleep at a Best Western! Wait a minute!!!! Lol
Didn't realize you had the old ones in there still.
Me: Jarrod
Old 07-15-2015, 05:15 PM   #193
Slick67
Sofa King Crazy!!
Slick67's Avatar
One of the rubber mounts is ripped in two, so I have to allow for that. Have you already got your mounting kit?
Old 07-15-2015, 05:32 PM   #194
Blown06
Blown06's Avatar
Yeah body drop kit is in, still have to buy the cushions. I'm missing a few items but Travis is working on it. Having flooring put in the house this week so no truck work will happen during my week off at home, but that's ok since the wife is happy.
Me: Jarrod
Old 07-16-2015, 08:05 AM   #195
mcbassin
Still Learning
mcbassin's Avatar
Excellent progress! everything looks great.
Old 07-16-2015, 08:52 AM   #196
BIG ORANGE
BIG ORANGE's Avatar
Progress is a good thang,,,,,,
Old 07-16-2015, 10:06 AM   #197
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks Mike! Plenty to do this weekend so I should have a few more pics next week.
Absolutely! Body is coming back off at the end of the weekend most likely and welding up that crossmember!
Old 07-16-2015, 09:52 PM   #198
slick copper
slick copper's Avatar
Don't worry I'm watchin' yours too! Man that thing is low! Keep up the good work. And keep that insurance up to date! Lol. ;-)
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 07-18-2015, 03:52 PM   #199
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks man! It's a ghost town over here in the Blazer area, that's too bad cause there is some nice stuff happening over here. That insurance will be on point when this Blazer hits the roads!!!
Old 07-21-2015, 01:20 PM   #200
Slick67
Sofa King Crazy!!
Slick67's Avatar
I am steadily making progress each week! The pics do not show much progress, but it actually was a lot of progress. Only had a day and a half to get this all done so I was happy. These pics are all that I took, but I did spray both sides of the tub with rattle can primer. I hope to have an announcement about the project soon.....so stay tuned!!!
Paint is gone off the dash.
I fabbed up a filler panel and filled in the windshield pillar, still gotta weld in the other side.
Made some fillers for the taillights as well.
Bare metal shows all, found a patch at the front of the tub on both sides and the quarter panel on the driver side will need to be replaced. There was a gallon of bondo on that quarter panel!!!
