07-17-2015, 07:26 PM | #1 |
99-00 6.0l flywheel gm# 12561757(nv4500) not available?aftermarket options?
i'm having a hard time finding a flywheel for my 2000 6.0l/nv4500 combo. i think its gm#12561757(discontinued) but i could be wrong. any ideas or options? hopefully a short crankshaft install isn't the only option.
07-17-2015, 08:05 PM | #2 |
Re: 99-00 6.0l flywheel gm# 12561757(nv4500) not available?aftermarket options?
ah ha! maybe? sachs pn# W0133-1688543? anyone have experience with the ol' iron head 6.0l (long crank)? i'm not too confident seeing as discount auto parts on ebay says this will also fit a 6.5. guess i'll look it up a few other places.
07-17-2015, 08:33 PM | #3 |
The chevy 6.5 is a diesel engine,, I don't know if it will fit your early 6.0 or not..the dealership should be able to cross reference part numbers for you..I think the iron head 6.0 and the 4.8 carry the same flywheel..everybody told me to shy away from the iron head 6.0 and go with the aluminum head version..so that's what I did
07-17-2015, 08:46 PM | #4 |
thats what i'm skeptical about.some computer geek messed up the listing but i don't think i have a lot of options other than seeing if it will fit the ls.anyway the whole truck was 500$ from a friend since he accidentally did some extreme bodywork to the cab with his excavator
07-17-2015, 09:12 PM | #5 |
hmm it gets deeper, it seems theres a single mass flywheel conversion for the 6.5 i wonder if thats related somehow? arggg!
07-26-2015, 11:17 PM | #6 |
i ordered the above mentioned sachs flywheel i'll see soon enough if its for an early lsx
07-26-2015, 11:46 PM | #7 |
Watching!
07-30-2015, 07:08 PM | #8 |
so the sachs flywheel is a misrepresentation of the nfw 1043 for a 6.5l. i've ordered it from two different places and got the same thing with one place sending me two for good measure. i wound up ordering one used from a wrecking yard,hopefully that won't have gremlins of its own.
07-30-2015, 11:36 PM | #9 |
Fabricate till you "puke"
1050 Sachs, 4.8/6.0....its on a 5.3, but the 5.3 was never listed with a stick trans? If you really plan to rev it...Mcleod lists a billet wheel, tad pricey, but it will bolt the gen I clutch, with no mods On my app, I went with the gen I clutch, but had to ream 3 holes on the clutch hat to fit. The sachs wheel, takes the ls-1 metric bolts, & wheras it is pinned for location on the hat, you can use the 3 larger holes to locate, the ream the 3 smaller bolts to spec. I can buzz mine to 6000 +, & she don't vibe....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-31-2015, 01:11 AM | #10 |
i wish i could use a later model flywheel for the motors with the crank almost flush with the seal. but unfortunately 99-00 m/t motors have .400 more crank stickout from the rear of the block compared to the 5.3's(a/t) and later engines. i'll probably get a later engine or crank when its time to rebuild.
07-31-2015, 08:51 AM | #11 | |
Let us know how it works for you
08-01-2015, 10:47 PM | #12 | |
08-01-2015, 11:38 PM | #13 |
thanks for the food for thought!
