Old 05-28-2015, 10:18 PM   #101
murd969
Re: 1956 Chevy 3100 Corvette Suspension
One more.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 05-29-2015, 08:10 AM   #102
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-04-2015, 10:44 AM   #103
murd969
I finally got the step notch done and everything is welded back in. I also had to narrow the rear suspension 2.5". I had the half shafts narrowed. Just waiting for the tie rod ends to be finished and the lower control arms. Then hopefully we can get the suspension back together and then install some air bags.
Instagram: murd969
Old 07-04-2015, 10:47 AM   #104
murd969
We also realized that we would have to notch the cross-member in front of the rear suspension in order to install the drive shaft.
Instagram: murd969
Old 07-04-2015, 01:45 PM   #105
Kim57
Kim57's Avatar
Nice progress.
Looks real clean.
Kim
My build thread
Old 07-16-2015, 10:57 AM   #106
murd969
Finally getting the suspension back together made a little progress the other day.
Instagram: murd969
Old 07-16-2015, 10:59 AM   #107
murd969
I went today and it's finally all together. We have to shorten the 4 link bars a little bit the get the suspension lined up. Other than that we're getting ready to set the ride height and get the air bags on.
Instagram: murd969
Old 07-16-2015, 02:59 PM   #108
Kim57
Kim57's Avatar
Pretty slick.
Kim
My build thread
Old 07-17-2015, 08:58 AM   #109
oldman3
oldman3's Avatar
Looks good...Jim
oldman3 is offline   Reply With Quote
Old 07-17-2015, 10:15 PM   #110
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Nice read... killer truck!! /Ken
87Lowrider is offline   Reply With Quote
Old 07-18-2015, 12:29 AM   #111
murd969
Thanks for the comments everyone. I'm definitely glad to see some progress on my truck. This project feels like it's been going forever. ( It's been 4 1/2 years) I guess maybe that is forever.
Instagram: murd969
Old 07-23-2015, 09:59 PM   #112
murd969
I finally have the wheels on the truck. The rear needs to be adjusted a little bit and then it will be ready to get the mounts welded on for the air bags. Basically where it's sitting now is the ride height. The low height will be almost 3 inches lower and I should be able to go up about 2 inches. I should have plenty of travel. I should have it rolling around next week.
Instagram: murd969
Old 07-23-2015, 10:00 PM   #113
murd969
Here's a view from inside the bed.
Instagram: murd969
Old 07-24-2015, 11:44 AM   #114
Nut Case
Nut Case's Avatar
murd969, great, pics, ideas and build. If this question is in previous posts I'm sorry, what is the advantage to lengthening from stock the link rods. Thanks in advance NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 07-24-2015, 12:32 PM   #115
murd969
We did it longer to help get a better ride and to limit the pinion angle when there's suspension travel.
Instagram: murd969
Old 07-24-2015, 01:02 PM   #116
Nut Case
Nut Case's Avatar
If you were to guess what is your estimate of degrees of adjustment to pinion angle that you gain by lengthening the links. Considering that the differential is fixed what are you going to set your pinion angle. FYI I'm a few months before I start on a 57 GMC 100 with 96 C-4 both front and rear. Any suggestions would be greatly appreciated. Could I PM you about setting up how to put pictures in this forum? Thanks in advance NC
Old 07-27-2015, 09:27 PM   #117
murd969
I'm going by the shop on Thursday and I will try and get accurate information before I relay it to you. You can PM me any time and I can try and help you out.
Instagram: murd969
Old 07-28-2015, 02:32 AM   #118
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
Old 07-30-2015, 09:06 PM   #119
murd969
I have more progress done on the truck. The suspension is done other than minor clean up and other small things but it's officially a 100% roller with the air bags.
Instagram: murd969
Old 07-30-2015, 09:09 PM   #120
murd969
Here's some closer pics of how we did the lower rear bag mount. A lot of people use the shock mount but we weren't comfortable using it. We added a bar below the lower 4 link bar and put the bracket there. I get plenty of lift now that we did the bags like this.
Instagram: murd969
Old 08-02-2015, 07:16 AM   #121
Kim57
Kim57's Avatar
That looks real nice.
Kim
My build thread
Old 08-02-2015, 09:59 AM   #122
murd969
Thanks Kim
Instagram: murd969
Old 08-03-2015, 10:33 AM   #123
ccreddell
ccreddell's Avatar
I must have missed it; What size tires and wheels are you running?
ccreddell is offline   Reply With Quote
Old 08-03-2015, 10:34 AM   #124
murd969
20 x 8.5 in the front and 20 x 10 in the rear.
Instagram: murd969
Old 08-03-2015, 01:11 PM   #125
ptc
ptc's Avatar
Do you get full travel of the rear shock rods with them at that angle? I would think they would push against one another, you may wear out bags and seals quicker with them that way.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
