Old 07-12-2015, 11:41 AM   #1
Jake1971
Jake1971's Avatar
WTS OEM 12 bolt differential cover
I have this OEM cover that has surface rust on the outside and clean inside I removed recently from a 1968 c-10 truck, the outer tip was slightly bent somehow but it does not affect the seal or functionality. See photos. $20 plus the ride. I can throw in the 12 bolts with it. LMK.
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 07-15-2015, 06:59 PM   #2
Jake1971
Jake1971's Avatar
Re: WTS OEM 12 bolt differential cover
Ttt
Old 07-18-2015, 12:40 PM   #3
Jake1971
Jake1971's Avatar
Bump. Offers?
Old 07-20-2015, 06:32 PM   #4
Jake1971
Jake1971's Avatar
Ttt
Old 07-31-2015, 06:54 PM   #5
Jake1971
Jake1971's Avatar
bump
Old 08-01-2015, 12:47 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If the edge is just bent, not cut, or the very edge damaged, then a small crescent wrench should do the trick. At least it did last night.
The bend is from a floor jack.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-01-2015, 03:02 PM   #7
Jake1971
Jake1971's Avatar
That's what it appears to be.
1967-1972 blazer, hat, original, plate, rear end
