Old 08-01-2015, 06:43 PM   #1
68 P.O.S.
Question Steering Stabilizer/Damper Mounting
So, I bought a Moog steering stabilizer for my 72 C-10 (yes, 2wd) because I am getting a lot of bump steer, even after I overhauled the steering and suspension. Problem is the directions are almost useless. After searching I found this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=220370. The pic in post 10 shows one end mounts to the steering box somehow...but it doesnt show how. Can somone please tell or show me how it attaches? Thank you
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-01-2015, 06:58 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Steering Stabilizer/Damper Mounting
I believe that pic is of a 4x4 installation
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is online now   Reply With Quote
Old 08-01-2015, 07:21 PM   #3
68 P.O.S.
I thought so at first too, but after re-reading it, he says it's on a C-10, not a K-10.
Old 08-01-2015, 10:28 PM   #4
Ol Blue K20
I saw what he said but if you look at the pics it's a 4x4 cross member
Dale
Old 08-01-2015, 11:51 PM   #5
68 P.O.S.
Bump
Old 08-02-2015, 08:53 AM   #6
68 P.O.S.
Morning bump
Old 08-02-2015, 08:58 AM   #7
Ol Blue K20
Sorry I can't help, I have only done stabilizers on 4x4. But here's a bump to keep it close to the top.
Dale
Old 08-02-2015, 07:13 PM   #8
racerop
racerop's Avatar
On my k20 the steering stabilizer is between the axle tube and the draglink. If you can find a place to mount the one end on the frame could you place the other on the draglink?
racerop is offline   Reply With Quote
Old 08-02-2015, 07:44 PM   #9
mike16
steering dampner cures bump steering issues?
I always thought that was a geometry problem at the suspension extreams of travel.
mike16 is offline   Reply With Quote
Old 08-03-2015, 05:43 AM   #10
68 P.O.S.
Ttt
Old 08-03-2015, 03:23 PM   #11
68 P.O.S.
C'mon guys, help a brother out. No one knows anything?
Old 08-03-2015, 04:26 PM   #12
summitflier
summitflier's Avatar
Don't know about the 60's chevy stabilizers. But typically one end is bolted to the frame.
The other end is connected to the steering arm ends.
None of these images are Chevy C-10's, this how I have installed them on other vehicles.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 08-03-2015, 04:37 PM   #13
michael bustamante
michael bustamante's Avatar
you might have to fab a bracket to mount the stabilizer to the frame but i dont know if that will cure the bump steer. i had the same problem with the blazer 4x4 but it turned out to be a combo of a loose ball joint ( didnt tighten it enough ) and a bad tire that would follow the grooves in the road
1967custom
michael bustamante is offline   Reply With Quote
Old 08-03-2015, 05:09 PM   #14
summitflier
See part #11 on this page.
http://media.lmctruck.com/pdf/CB/0135.pdf
It looks like it has piece that bolts to the frame.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 08-03-2015, 10:43 PM   #15
mike16
my old 64 lemans had one from the factory
the stationary bracket was samwitched between the PS box and the frame.
the moving part was bolted by u-bolts to the center link
make sure the dampner you use allows enough travel in both directions. and does not bottom out when you go full lock to lock in either direction.
Old 08-03-2015, 10:54 PM   #16
68 P.O.S.
Thanks guys, I'll see what I can figure out. I've already seen that LMC page, but the steering box is in the way of what I want to see. Lol
Thanks again
Old 09-20-2015, 11:10 AM   #17
68 P.O.S.
Here's an update for anyone who may be interested. I've had the damper on my daily driver for over a month now, and I gotta say, the difference is almost imperceptible. The only real difference I see is the loss of return to center for the front wheels. So is this a worthwhile upgrade? Maybe not, but I guess it wouldn't hurt.
Old 09-24-2015, 08:14 PM   #18
Elwood431
Elwood431's Avatar
I'm looking to install a steering stabilizer on my 67 c10. Could you post some pictures of how you installed yours?
Elwood431 is offline   Reply With Quote
