07-09-2015, 02:11 PM | #76 |
Re: Converting factory AC to use R134a
Truck is at the AC shop getting a charge right now. I will report how well it works as soon as I know.
Here's some more photos from the project: |
07-09-2015, 04:28 PM | #77 |
It works!
AC guy says I could add an electric fan to the condenser if I want it colder. It should be 100 or more next week, that should be a good test. |
07-17-2015, 04:16 PM | #78 | |
07-17-2015, 05:31 PM | #79 | |
Interested in a PF condenser, filter/dryer, new hoses/ o rings, A6 replacement and re-calibrated POA valve for a 1972 Chevrolet truck which will be converted to R134. Is there anything else needed when converting? Thanks |
07-17-2015, 05:37 PM | #80 |
You chimed in at the right time. I am getting my AC working again and have not ordered anything yet.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
07-19-2015, 02:40 PM | #81 |
yea guys have ben telling me to join this forum. hopefully I can help some people out
07-19-2015, 03:06 PM | #82 |
I didn't realize that was you, either! Good to see you here. Do you have an opinion on whether the A6 does better with PAG or POE oil when cleaned well then converted to R134a?
07-19-2015, 03:20 PM | #83 |
07-20-2015, 05:50 PM | #84 |
Thanks. I would say ester oil if the rest of the system hasn't been flushed. Pag is good if everything is clean. Ester is what we used where I use to work. And that place is very well known for classic automobile ac/heat restoration.
08-03-2015, 08:20 PM | #85 |
Is there any disadvantage to using ester? I've cleaned it best I can, but if ester works just as well why not avoid incompatibility and just use ester?
08-03-2015, 09:45 PM | #86 |
This is what I was told by an ACDelco engineer...." It is hygroscopic and it will release the water under compression in the compressor and cause erosion. There's a reason none of the OE's use ester."
08-08-2015, 11:49 AM | #87 |
I've decided to go with Delco PAG-150. Evaporator has been professionally cleaned and pressure tested. Drier is new. Can I just rinse out the hoses, condenser, and compressor? I'ver read in a few places that electrical contact cleaner is a good solvent for old R12/mineral oil and it's cheap. Thoughts?
08-08-2015, 07:28 PM | #88 | |
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
08-08-2015, 07:37 PM | #89 |
Im starting to collect parts for my K20 Suburban A/C and have to get a large amount of hose to run to the rear unit. I was wondering if anyone has just cut off the fittings for the compressor/condenser/POA from the old lines and just used hose clamps instead? If I do order new hoses I hate to have to cut them in half to add the T fitting that just uses hose clamps anyway.
Is there a conversion schrader valve kit I need to install to the old muffler and valve to use 134? |
09-22-2015, 10:37 PM | #90 |
Looks really nice!
I got mine working today after several weeks of work. Complete disassembly and cleaning or flushing of every component. Had evaporator professionally repaired where there were a few leak "tracks." It came back spotless and pressure-tested. New O-rings everywhere. Calibrated the POA to 26.5psi (very easy as it turns out). Stock 45 year old A6 was rinsed way too many times with expensive ACDelco PAG150 until it was clean. New receiver-drier at the very last moment, then obsessive-compulsive evacuation which I left for 3 days. Final one hour evacuation and recharged her today. Have three 12oz cans in there at the moment and I think it needs just a touch more. Original sticker on the compressor says 3.25lbs R12. I'm using 80% which comes to 41.6oz of R135, and 3 cans provides 36oz. At this point the test drive showed 40 degrees at the driver side vent, but by the time I was done it was only in the upper 80's here. One thing I found interesting, and I'd like to know if this is a useful way of "seeing" that you are finally full of refrigerant: My POA is set to 26.5. As I filled with each successive can, the low side would "take" the can, then pump down to 26.5. After 3 cans it's still at 26.5 on the low side, and 225-240 on the high side. I'm thinking that I need a little more R134 in there so that the low side is just "dipping" into that 26.5 setting? It sits there like a rock right now. What do you experts think? |
09-23-2015, 09:07 AM | #91 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-23-2015, 09:21 AM | #92 |
Old member
Just a good rule of thumb. Is the system getting cold and is it condensating around the POA valve. If so you should be really close.
Outside temp has a lot to do with how well it will cool also and how much air your moving. Take a look at the chart for outside air temps.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-23-2015, 11:51 AM | #93 |
Great thread! I am getting ready to make my AC work again and have a couple of questions. (factory air 70 C20)
I will be needing a new compressor and a new dryer. I assume I need to change out the o-rings to R134 compatible. I need to calibrate the POA or have it done. I think I also need to have adapters for the connections, Do I need to replace all the hoses? Anything else? I'm open to suggestions. Of course flushing the entire system will be done.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-23-2015, 01:08 PM | #94 |
That's the chart I was using! It was 90f in the shop and after 36oz of R134 I had 240/27psi. And yes... there was a little frost...
09-23-2015, 01:12 PM | #95 |
borrowed my brothers HB gauge set and looks like I need adapter too. Any recommendations?
Picklito, what was your procedure on cleaning and recalibrating the POA? thanks |
09-23-2015, 01:21 PM | #96 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-23-2015, 01:30 PM | #97 |
09-23-2015, 01:33 PM | #98 |
See post #83 above. I had to drill one hole to lower the upper mounting loop about 1" because the drier is a little bit shorter than my OE. You can see Jimbo's upper loop is right at the radius of the drier. My drier sat a little lower so the loop was up around the skinnier part. Drier sits where it sits, because of the tubing, so I lowered the loop a little.
09-23-2015, 03:09 PM | #99 |
09-23-2015, 03:27 PM | #100 |
I just got a reply back from Classic Auto Air for a kit which includes the Saden-style compressor, brackets, condenser, hoses, filter/drier and hardware to update and run R134. $800 + $190 for a rebuilt and calibrated POA valve and $60 for a expansion valve. Does this sound reasonable or can I save a few putting something together myself. Sounds like everything from the firewall forward.
Tags |
134a, a/c, air conditioning, r134, r134a |
