07-13-2015, 09:16 PM | #676 |
Re: 1958 Apache 38 Dually Dump Project
Yep, we stretched the wheelbase a bit with the newer chassis...it should all be good though!
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
07-13-2015, 10:58 PM | #677 |
Not much to add other than PTO to pump shaft is in and we're back to patching doors...passenger side this time. We need to get the cab metalwork done and try and get color on this.
07-14-2015, 10:06 AM | #678 |
Nice work.
Kim |
07-20-2015, 11:25 PM | #679 |
Thanks Kim, we're slowly working through the rust and holes on this door. We welded in the hinge access door to match the driver side (PO welded the hinge solid)...the lower part of both doors will be bed-lined. Also filled/smoothed multiple holes from two different sets of "truck" mirrors. We then drilled holes and welded nuts on the backside for a stock type mirror on the passenger side door.
07-21-2015, 01:12 AM | #680 |
Your doing some real nice work.
Kim |
07-21-2015, 06:04 AM | #681 |
One day...
Sweet, progress
I need to make it over there and bug you guys this week |
07-21-2015, 03:20 PM | #682 |
6>8 Plugless........
Great work! Holes and rust, that brings back memories of my doors.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-21-2015, 10:41 PM | #683 | ||
Thanks Kim!
Worked through the layers to find some more to repair...
07-21-2015, 11:01 PM | #684 |
One day...
Thats a big crater, fix the top like we talked about and ill work the bottom out where its workable.
07-22-2015, 12:24 AM | #685 |
Getting the torch out now...
07-22-2015, 10:28 AM | #686 |
One day...
07-22-2015, 11:47 PM | #687 |
Scott came out and rescued me from myself We were able to get the pass door fitting a lot better thanks to Scott's touch...and big hammers!
07-22-2015, 11:55 PM | #688 |
Great job!! Wow that thing had some layers of paint.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
07-23-2015, 06:16 AM | #689 |
One day...
And thats saying it nicely
07-23-2015, 09:25 AM | #690 |
Fits real good.
Kim |
07-25-2015, 02:18 AM | #691 |
Yep, just a few
Yep, lots better than I thought it would. Baby steps, but keep marching forward...
08-02-2015, 11:39 PM | #692 |
We worked through the driver side door, it was in better shape than the pass side...still had over a dozen different holes from mirrors over the years though.
08-02-2015, 11:52 PM | #693 |
We also welded and smoothed the upper fender to cab seams...continuing our effort to make the cab and front clip one piece.
08-04-2015, 12:08 AM | #694 |
Tonight we rounded off the mid front corner of both doors. I saw this on at least one build in here and thought it flowed nicely...so we thought we'd give it a try. We'll shape it a bit better once we spend some more time on lining up the doors...close for now though.
08-04-2015, 12:36 AM | #695 |
Passenger side...
08-04-2015, 03:09 AM | #696 |
Everything is looking real good.
Kim |
08-04-2015, 07:39 AM | #697 |
One day...
Sweet!
08-04-2015, 12:27 PM | #698 |
Nice work guys. Looking really good!
08-04-2015, 04:14 PM | #699 |
A320 Pilot/USAF Retired
Very cool!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-04-2015, 07:35 PM | #700 |
Great work! I like the body door line change too.
