08-05-2015, 01:16 PM | #1 |
Help...a little confused
I bought my '71 Sub thinking it was a K10-1/2 ton model. The SPID shows the model as KE10906 and the Vin starts with KE. Does this mean it is actually a K20-3/4 ton version? And only 256 were produced with barn doors?
What else could I look at to verify that it is a K20? |
08-05-2015, 02:50 PM | #2 |
Re: Help...a little confused
The model number 10906 defines it as a 1/2 ton Suburban.
A 3/4 ton would be a 20906 model number. The K in the VIN indicates 4wd (regardless of series); the E indicates V8 engine. http://67-72chevytrucks.com/vboard/s...d.php?t=570059 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-05-2015, 04:58 PM | #3 |
Thanks Keith, weird, this site:
http://outintheshop.com/prodnum.html lists the 1/2 ton as KS and the 3/4 ton as KE. They must be wrong or I'm not getting there data. |
08-06-2015, 09:51 AM | #4 |
Yes - you are confusing the VIN coding and the model code.
They are two separate entities and the structure and meaning are different. Just an unfortunate coincidence that they are so similar in this instance. K
08-06-2015, 10:51 AM | #5 |
Here's the model info from my 1967 service manual. The '71 info will be similar.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
