Old 08-09-2015, 07:33 PM   #1
DBear
DBear's Avatar
1963 gmc 3/4 ton 4x4
Will a gm 10 front and a 14 bolt FF fit on this truck? I'm thinking the spring perches on the 14 bolt will have to to moved out an inch each side....but really wanted to know if the front would bolt in??
DBear is offline   Reply With Quote
Old 08-09-2015, 08:36 PM   #2
'63GENIII
'63GENIII's Avatar
Re: 1963 gmc 3/4 ton 4x4
The front should go in without a problem. Brake lines will have to change but the axle itself shouldn't be a problem.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
