Old 08-16-2015, 02:17 PM   #201
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 1968 C10 5.3 swap, the easy way.
If you're available on Sunday mornings, you need to bring the truck by the show on Cheyenne and Jones. Unfortunately I wont be around next weekend, but Sunday September 6th I'll be back in town. There was another LSx swap truck in 2010 Camaro Cyber Grey Metallic there last weekend....
Rich
1972 K5 Blazer CST Click HERE
Old 09-15-2015, 05:48 PM   #202
thumpros@yahoo.com
thumpros@yahoo.com's Avatar
I am in the process of the same swap also. I have a LM7-5.3 LS1 from a 2000 Suburban, but I opted to go with a 700r4 OD tranny with 2500 stall converter. I plan on using 20" GM/Chevy late model factory oem wheels found on todays SUV/Trucks.
What would be an ideal rear end gear? Which gears are you using, the original 3.08s?
Let me know how yours is running as a daily driver..Thanks
68 C10 LS SWB LM7 5.3 700R4 http://67-72chevytrucks.com/vboard/s...d.php?t=692803
thumpros@yahoo.com is offline   Reply With Quote
Old 09-16-2015, 11:28 PM   #203
vannatta20
vannatta20's Avatar
Stock 3.73 ratio gears work great. I am now running a ford 8.8 rear but with 3.73s. Cheap way to get posi.
vannatta20 is offline   Reply With Quote
Old 09-27-2015, 05:27 AM   #204
mcmlxix
mcmlxix's Avatar
http://lasvegas.craigslist.org/cto/5239836506.html
Rich
Old 09-27-2015, 08:04 AM   #205
55chevy1st
Such a shame...
55chevy1st is offline   Reply With Quote
Old 09-27-2015, 09:44 AM   #206
bodydropped68
bodydropped68's Avatar
Originally Posted by mcmlxix View Post
That is going to make someone an awesome ride
bodydropped68 is offline   Reply With Quote
Old 09-27-2015, 01:51 PM   #207
vannatta20
vannatta20's Avatar
I have a 1968 firebird rotting away and it needs to be saved. I cant afford two classic cars plus a daily driver. I found a buyer that wants to daily drive it the way it was intended to be used. Las Vegas has to many crazy drivers.
Old 10-29-2015, 08:53 PM   #208
XwalkerX
so did it end up selling?
XwalkerX is offline   Reply With Quote
Old 11-02-2015, 11:55 PM   #209
3drburb
Great write up on the motor swap.
You mentioned that your selling the wire harness, what is your price?
Considering this swap also.
3drburb is offline   Reply With Quote
Old 01-17-2016, 08:36 PM   #210
elf w/capital T
Dude, thanks for the tips and photos! Nice build!
elf w/capital T is offline   Reply With Quote
Old 02-24-2016, 09:00 AM   #211
Billyburban
Your truck is lowerd ? What oil pan did you use factory or one of the many oil pans on the market
Billyburban is offline   Reply With Quote
Old 05-05-2016, 04:40 PM   #212
ChuckLee
what a great link full of awesome info. this makes me want to "take the plunge"
ChuckLee is offline   Reply With Quote
Old 05-06-2016, 05:34 AM   #213
71Sleeper
71Sleeper's Avatar
thanks for the information...
71Sleeper is offline   Reply With Quote
Old 05-06-2016, 10:54 AM   #214
vannatta20
vannatta20's Avatar
Truck oil pan. A 98-02 ls1 camaro pan will give the best clearance but the truck pan works fine if the vehicle is only lowered a few inches.
Old 05-06-2016, 11:07 AM   #215
Billyburban
Thanks for the reply I bought the GM muscle car pan kit now to start my swap
Old 05-17-2016, 09:17 AM   #216
tow21
Are you using the factory high hump trans cover?
Where did u get this is know this is an old post but I'm looking for one for my 70
tow21 is offline   Reply With Quote
Old 05-17-2016, 10:04 AM   #217
vannatta20
vannatta20's Avatar
I used the factory low hump.
Old 07-25-2016, 10:49 AM   #218
hanly2
Where the dirty dingo 67-72 mounts available when you did this build or do the ones you used just work better? What trans crossmember did you use?
hanly2 is offline   Reply With Quote
Old 07-25-2016, 01:56 PM   #219
michael bustamante
michael bustamante's Avatar
im pretty sure he used 73 and up frame towers and used the 73 and up dd mounts
now it says you're in nevada but i spy a NM plate...... do you frequent NM too? if so i cant wait to see the truck on 66!!
1967custom
michael bustamante is offline   Reply With Quote
Old 05-31-2017, 09:10 PM   #220
Cavendishrdfrank
Cavendishrdfrank's Avatar
What wires did you use off the top bulk head plug on the firewall?? I'm about to do mine and just keep finding a kind of useless (to me) factory wiring diagram... thanks in advance!
Cavendishrdfrank is offline   Reply With Quote
Old 07-25-2017, 09:49 PM   #221
71Sleeper
71Sleeper's Avatar
Tagged for future info. Thanks for all the information on your swap.
Old 11-19-2017, 01:06 AM   #222
Jkmyers84
Did you modify the gas tank to run the stock fuel pump or order it this way?
Jkmyers84 is offline   Reply With Quote
Old 11-19-2017, 02:46 PM   #223
vannatta20
vannatta20's Avatar
I have had an issue ripping apart the early Small block chevy rubber mounts so I will not use that design anymore. You can buy the poly mounts but they cost more $$$ I used the later mounts since they are a clam shell design encased in metal. Those engine mounts were used on the 73-87 trucks.
Old 11-19-2017, 02:48 PM   #224
vannatta20
vannatta20's Avatar
We modded the carb version of the tank. We just cut a hole to drop the pump down into.
Old 11-30-2017, 12:10 AM   #225
69ls4.8swap
thanks for all the info to kick me in the butt to swap my truck. I was really nervous about taking this project on but after spending a couple hours reading all the posts i feel good. BTW nice paint color
69ls4.8swap is offline   Reply With Quote
