08-27-2015, 03:08 PM | #101 |
Re: F/S: 73-87 power window relay harness
He has quite the project truck going on-he opted for the single headlight relay harness, dual tank harness and diesel engine harness. I had delays getting my wife's truck back together after fixing and repainting the whole thing so that's been what's been holding me up a bit. But I'm glad that's over....I know every square inch of that Yukon now!!!
10-08-2015, 02:39 PM | #102 |
Aloha I have a 89 crewcab that I put powerwindows in from a 87 suburban and I would like to purchase you wiring kit with express down on the two front doors only what is the cost and How woul i get the money to you Mahalo Ed
10-18-2015, 06:24 PM | #103 |
Having done a lot of wiring work over the years id like to say wow to your attention to detail and quality of the parts used!
Any thoughts on replacement window motors. I bought so A1 auto motors from ebay and together they lasted a day... DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
10-18-2015, 08:25 PM | #104 |
Thank you for the kind words! I try to provide the highest quality OEM style harness with or without late model upgrades....I build them exactly as I use them!
10-18-2015, 10:28 PM | #105 |
There's a local 3M electrical shop in town around here that services any type of motor-Id say check into that or, I have had good luck sending the OEM window motors out to A-1 Cardone for an R&R rebuild. Back when I was a parts counter guy (yep, there were of a few of us parts guys who knew our stuff!) we used to routinely send off OEM parts for customers to get rebuilt-stuff like water pumps, alternators, distributors, etc. when they wanted to retain a numbers matching vehicle. |
10-21-2015, 07:20 PM | #106 |
Will a 2door harness work on a 4door sub?dont necessarily need it on the back doors. Don't roll them down as much.
Zaccaglin 1998 Chevrolet C1500 Ext. Cab 350 Former Rig: 1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208 |
10-21-2015, 07:42 PM | #107 |
You can-the kickpanel connectors are different-you'll need to re-pin everything.
10-22-2015, 11:11 AM | #108 |
The issue with the power window/lock harnesses through the years is that across the board and for no apparent reason, there were many different style of connectors used for the male/female mates which is why if possible, its often better to replace the center harness along with the LH and RH because I build an OEM replacement from end to end so I know everything will mate up. Otherwise, without knowing exactly what connector styles you have on your center harness be it a 2-door or 4-door, I can only supply you with the most common styles-now IF yours appear to be different then a quick pic or two and I can send the corresponding terminals out-much better to shoot me some pics beforehand so I can see what you're dealing with. Also, you just never know what a PO has done to the wiring as well ya know? Either way, if you need a specific connector, drop me a line-I have pretty much every connector/terminal all on hand for even the most unusual situations.
11-04-2015, 09:42 PM | #109 |
I am curious what people that didn't originally have power windows are using for the door jamb boots? I got my harness and my truck didn't have power windows so I have to drill all of the holes in the jambs. Are people getting original ones at the wrecking yard or are their other alternatives?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
01-13-2016, 06:09 AM | #110 |
I will be talking to you if I get this 76 Crew purchased. I need everything. PM me here or on the MC SS board.
01-13-2016, 07:28 AM | #111 |
Cool! Pics! Pics!
06-09-2016, 02:23 AM | #112 |
Hi, I have a 85 stepside 2 door cab and was wondering if you had a harness that would work for it. It has existing power windows but I am looking for an upgrade and your YouTube video was very impressive. Any information would be appreciated thanks.
06-10-2016, 04:50 PM | #113 |
PM sent!
11-13-2016, 09:00 AM | #114 |
Interested in one of your power window relay harnesses for my 86 if you can shoot me some prices.
11-13-2016, 03:43 PM | #115 |
01-15-2017, 11:14 AM | #116 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
01-16-2017, 02:00 PM | #117 |
Here's a Motorcraft 2-speed RF24 T-Bird fan mounted stealth style inside a stock pickup fan shroud-it is powered using my 3-speed conversion harness also. This way, the fan motor is converted to 3-speed operation. This type of fan harness allows you to run any style of fan(s) without the worry of high inrush currents or sudden spiking. I've moved away from failure prone PWM controllers and have been using these bullet proof relay resistor fan harnesses for over 6 years now.
01-17-2017, 12:33 AM | #118 |
For those looking for a complete replacement harness and are using either 81-up doors, are using factory 77-80 power doors or plan to convert manual doors 73-87 using a hardware conversion kit from Classic or A1 I have several options for harnesses-stock, auto down and auto down/up. If you've got a mutt of a build and need options on power accessories, PM me for details-I've got the best options available for power windows!
01-17-2017, 02:28 AM | #119 |
Not that I'm especially knowledgeable when it comes to e-fan actuation but I do know that even mid grade relays will get eaten up by today's more powerful fan motors. Also, that initial amperage hit can be hi! I remember cruising around with extra relays just for the times when they would go bad to ensure I stayed on the road! Went so for as to source 40amp relays and was going to attempt to build my own harness.....lol.....that was back in 06, still have the parts but no harness!
When I get to the wiring phase I will definitely be contacting you! Thanks for the great info!
02-07-2017, 12:27 PM | #120 |
Just wondering, do you make complete vehicle re-wiring kits? I have an 84 K5 am thinking about getting one of your upgrade harnesses for the windows, headlights, and e-fans and am trying to decide if I replace the rest while I'm at it so I have a fresh slate going forward...
02-07-2017, 01:36 PM | #121 | |
02-07-2017, 02:03 PM | #122 |
03-18-2017, 12:30 AM | #123 |
PM Sent.
05-08-2017, 12:01 PM | #124 |
1982 Pickup with windows, would like kit with express down. Price and availability
please |
05-08-2017, 12:14 PM | #125 |
$159 shipped-1 week out right now.
