Old 09-01-2015, 09:56 AM   #51
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 GMC C30 panel truck
Good couple coats of clear would shine that right up.
Old 09-02-2015, 07:39 AM   #52
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Originally Posted by AJCK87 View Post
Little concerned about the wood bed, I want to preserve it to use as a template for the new floor boards.
There's bedwood dimensions available here if you need them: http://www.gmcpauls.com/47-72_BedWood_Info.htm
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 09-14-2015, 10:55 PM   #53
AJCK87
Worked on the drivers vent window this week, got it all restored with some fresh paint and rubber.
AJCK87 is offline   Reply With Quote
Old 10-03-2015, 07:49 PM   #54
AJCK87
Found a 60/40 bench seat this weekend. It will work perfect for the front seat. Will be able to get to the back seat with one lever. Pulled it out of a 94 Chevy with the extended cab. Got it all cleaned up, it is in great shape. I will be mocking it up next weekend.
Old 10-05-2015, 10:47 AM   #55
AJCK87
That is an awesome site! I wasn't sure of the dimensions for the cut in edges for the floor boards, and that site lays it out prefect. Would be nice to be able to use some of the products but they are all set up for short and long bed applications. I measured the boards in my panel and they are 10 1/2' long. I will likely have to make my own boards.
Old 10-11-2015, 11:59 AM   #56
AJCK87
Drivers seat is in! The steering wheel is not done yet, still needs a few coats of paint. These seats fit in the panel perfectly, no modifications required. Now onto the passengers side
Old 10-11-2015, 12:02 PM   #57
AJCK87
Worked on the passengers side mirror a bit last night.
Old 10-11-2015, 12:03 PM   #58
AJCK87
Anthony the other side....
Old 10-11-2015, 03:15 PM   #59
AJCK87
Passenger seat is mounted. Would have been better if I mounted them more forward. O well, just a bit tight for those getting into the back
Old 10-11-2015, 06:04 PM   #60
AJCK87
Got the drivers side vent window in. The extra time spent paid off, turned out nicer then the passengers side.
Old 11-07-2015, 02:01 PM   #61
AJCK87
Still on the road for my two week hunting trip. Got three deer between my brother in law and I. The best part was I spotted a 63 suburban and a 65 suburban parked out in this guys farm yard. lucky for me the guy was there, as I was passing through, he set me up with a bunch of critical parts that I am missing/ or that are heavily damaged. Rear crossmember and sil plate with barn door stricker plates, fuel door, driver side tail light housing, all the cover plates for the barn doors, all the rear barn door latches and a mint crome bumper with all the brackets. Soo pumped. Currently it's all jammed in the back of my 77' security camper with three deer and all our camping and hunting gear.... So pictures to come hahaha
Old 11-07-2015, 03:21 PM   #62
deejaaa1
great progress so far.
we were at Brightsand Regional Park in SK this last summer.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 11-07-2015, 04:27 PM   #63
AJCK87
Thanks! I'm excited things keep moving along. Saskatchewan has some beauty Whitetails. Would be a cool hunt. I had the opportunity to participate in a duck and goose hunt in Manitoba and it was a blast!!
Old 11-07-2015, 07:21 PM   #64
62stepside longbox
62stepside longbox's Avatar
Good work and nice find on the parts. Good to see another b.c. Member on here
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 11-07-2015, 09:07 PM   #65
AJCK87
Thanks! Beauty, we were just hunting out that way, bear main and esperon.
Old 11-08-2015, 10:46 AM   #66
Free Candy Inside
Coming along nice
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 11-08-2015, 12:55 PM   #67
AJCK87
Originally Posted by Free Candy Inside View Post
Coming along nice
Thanks! Can't wait to get her on the road. It's nice to see you driving yours around!
Old 11-08-2015, 03:52 PM   #68
AJCK87
The new rear bumper!
Old 11-08-2015, 03:53 PM   #69
AJCK87
With the brackets....
Old 11-08-2015, 03:54 PM   #70
AJCK87
The rear sil plate with cross member.
Old 11-08-2015, 03:56 PM   #71
AJCK87
Barn door access port cover plates
Old 11-08-2015, 03:57 PM   #72
AJCK87
Fuel door
Old 11-08-2015, 03:58 PM   #73
AJCK87
Barn door latches and stricker plates
Old 11-08-2015, 04:03 PM   #74
AJCK87
And the drivers side tail light lens and housing. Got the lot for $160. Got some parts and some new tools. A 1500lb engine stand for the Cummins, a new 12.5v grinder, some butt weld clamps, spot weld cutters and some sand blasting media.
Old 11-22-2015, 01:40 PM   #75
AJCK87
Got out to the shop last night. Spent some time working on the rear sil and cross member. Welded the ends of the cross member back on, filled the hole for the trailer plug and hammered out the dents. Then I started to sand blast the rough looking areas around the cross member. Noticed some pin holes and areas I will have to patch up.
