Old 09-19-2015, 08:45 PM   #1
sshuttlesworth24
Cutting bottom lip on 69-72 Grilles
does any body have a write up on how to do this... i think it looks neat! somebody share with me cause i plan on doing this to mine! i tried searching but no luck... if there is a thread pls direct me to it thanks
sshuttlesworth24 is offline   Reply With Quote
Old 09-19-2015, 09:14 PM   #2
65standard
65standard's Avatar
Re: Cutting bottom lip on 69-72 Grilles
Doesn't look cut off, just painted body color.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 09-19-2015, 09:15 PM   #3
hugger6933
Looks like the filler part of the grille has been taken off probably with a die grinder then sanded then polished. It does provide a different look to the grille but I prefer the bumper for both protection and looks. Jim
hugger6933 is online now   Reply With Quote
Old 09-19-2015, 09:19 PM   #4
sshuttlesworth24
i perfer the bumper too it was just another pic i had of the bottom lip cut.... my question is what was used to fill the space where the "lip" was?
many diff angles of the look
https://youtu.be/LR1Qeauu_dw
<iframe width="560" height="315" src="https://www.youtube.com/embed/LR1Qeauu_dw" frameborder="0" allowfullscreen></iframe>
Old 09-19-2015, 09:22 PM   #5
sshuttlesworth24
i think its cut... view vid ^^^
Old 09-20-2015, 06:36 AM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
The red truck's looks painted, you can see the seam along the front, for some reason, not so much on the ends near the fender. Not sure about the brown truck. You could always get an old grille to practice on and do the forum a favor and make the write up for us I would think some 18 or 20 gauge sheet metal would be the ticket to fill the area in, but I'm not sure your efforts would be seen very well hiding behind a bumper. If you used a front roll pan and welded/molded everything together, I could see going through the trouble, as a lot of the '67-68 trucks on here have that look when using a front roll pan. I just painted the lower lip on mine body color, but obviously I have a seam running across the front of my truck above the roll pan now. Had to do quite a bit of shaping/bending/relief cutting to get the profiles to match, as the rollpan had a gentle curve to it and the grille made a much sharper break in the middle.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
