09-22-2015, 03:42 PM | #1 |
Rear gear question
Since the wifes new(to us)vehicle broke down (long story on that) i am now daily driving my truck again. I am very happy with this and would have all the time but couldnt justify letting a vehicle sit that cost me money monthly unlike the truck. Any ways, i will be driving my truck everyday for a few months til next spring. It is a '72 C20 with 4.11 rear gearing. i drive 7 miles to work and with our winters here i would like to change the gears from being a one-wheel-wonder open diff. for better traction when its not so nice out. This was built a work truck when new and still is so i do not want to compromise that. I pull a trailer from time to time also. what is your opinions? what are you running or had good luck with? ive done some research and liked the sound of a powertrax system. are these suitable for my needs?
09-22-2015, 05:20 PM | #2 |
Re: Rear gear question
You can drive it into a shop asnd have them install a brand new posi in a day for about $1000
09-22-2015, 05:41 PM | #3 | |
09-22-2015, 07:59 PM | #4 |
I have a "lunch box locker" in my 12 bolt. 3.08 gears. I did have a perp it was free! not a powertrax,but it's been in there 3 years now.I love it.They are pricey new but very easily installed.I like the click you get when turning.Kinda like a countdown to smokin' both tires!!
Just my opinion!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
09-22-2015, 08:55 PM | #5 |
I added a Yukon post in my truck and Camaro, for me they work great....
09-22-2015, 09:12 PM | #6 |
eaton or dana
09-22-2015, 09:28 PM | #7 |
It is a Dana 60 with 4.10 gears. Anybody have part numbers or good places to buy from?
09-23-2015, 09:43 AM | #8 |
Also how much do they reduce mileage? I get the brick on wheels but I'm getting 12 mpg now. Don't want to drop it to 8 mpg
09-23-2015, 11:16 AM | #9 | |
12 is actually pretty good MPG!!! I would NOT change the gear ratio!!! the MPG difference will disappoint you. I'm with you on the posi idea. Been in situations where 2 wheels spinning would have made a difference. |
09-23-2015, 11:29 AM | #10 |
12 is good for these trucks and the weight of the vehicle. like i said i fully understand that im driving a gas loving truck and dont mind at all. im not going to change the gears from 4.10 because i love my towing/hauling ability with that gear. i just want to use a locker or something for better traction in the snow. i just dont want to bring it down to like 7/8 mpg. why pay that much more in gas everyday to have something else you would only need a few times
09-23-2015, 12:57 PM | #11 |
these trucks are not really that heavy. its the rear end gearing and the horsepower ratings that kill gas milage. and how you drive it. My 72 c10 3 spd/307/373 gears gets 13 maybe 14 mpg. It will do some work though!
09-23-2015, 01:08 PM | #12 |
I'm a believer in overdrive. 700R4 with 3.73
I just put in a eaton E-locker spool in this week. We'll see how much change it makes. I suspect not a lot on the freeway where it's mostly straight line driving.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
09-23-2015, 01:08 PM | #13 |
these are some of the best work trucks ever imo. i have done way more with my truck then i could ever do alot of newer model 3/4 tons. Ive been reading up on lockers and alot of people are saying they are worse for snow and ice. so im needing to know now, what can i do, aside from chains, to get better traction when it snows? i already run 500 lbs in the back over the axle but still get one wheel action alot. im not complaining about it, i know what i bought and what it does, but want to do what i can to improve this so i can enjoy my truck more
09-23-2015, 02:11 PM | #14 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-23-2015, 02:23 PM | #15 | |
09-23-2015, 02:31 PM | #16 |
12mpg is not bad. My '83 K20 used to get 14 or so with 700R4 and 3.42 gears. If you are not going to go to overdrive, I would change to 3.73 or 3.55. That should be plenty of gear for hauling and should help slightly with mileage. A more tangible benefit should be fewer RPMs at cruising speed which may be quieter inside the cab.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-23-2015, 09:13 PM | #17 |
I've read and didn't see, but do you have the Eaton axle or the Dana 60? If you have the Eaton, you are SOL on a limited slip aka Posi-traction. But posi is the answer you are looking for if you have the Dana axle. The cheapest way to do that is a TrakLok in a Dana 60. Not known for really good longevity, based on what you are doing should still be good for 10 years and it could be rebuilt. Figure $300 to buy it if you shop around and another couple of hundred to install it.
09-23-2015, 09:26 PM | #18 |
This is my set up on my BB, just added the eaton posi and changed the gear to a 3.73 from a 3.08 in a non Dana rear end. I like it..
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-23-2015, 09:39 PM | #19 |
I have a Dana 60 rear end with 4.10 gears. Any recomended places to buy a traklok ?
09-24-2015, 07:07 AM | #20 |
Check out the eaton truetrac. Lots of good info on Eaton's website.
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!! |
09-24-2015, 08:15 AM | #21 |
The TrueTrac is a great choice as well. I like Randy's Ring & Pinion but any of the big mail order places should be able to fix you up.
09-24-2015, 10:56 AM | #22 |
looking at different ones online i found this one
http://www.ebay.com/itm/GM-12-Bolt-T...a0e292&vxp=mtr idk if i got the link posted right so il try it and see. would this one here fit then? it seemd to match up but want to make sure i didnt overlook something |
09-24-2015, 11:30 AM | #23 |
Nope. That's for a 12 bolt. You need one for a Dana 60 with 30 spline axles. Here are some choices.
The PowerLock is real beef: http://www.ebay.com/itm/DANA-60-POWE...342a33&vxp=mtr Here's a TracLock with bearings and bolts and shims: http://www.ebay.com/itm/OEM-DANA-60-...4b0c83&vxp=mtr
