Old 09-22-2015, 02:27 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Looking for a super duper OEM vapor canister, for 71.
71 Chevy
NOS or like new. These have three connections for fuel emissions:
1. Fuel Tank
2. CARB
3. PCV
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-22-2015, 10:46 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Looking for a super duper OEM vapor canister, for 71.
Originally Posted by 71CHEVYSHORTBED402 View Post
71 Chevy
1. Fuel Tank
2. CARB
3. PCV
Here are a couple of older threads on the subject. Especially the second one but you have to read the whole thread....
http://67-72chevytrucks.com/vboard/s...d.php?t=572954
http://67-72chevytrucks.com/vboard/s...d.php?t=569115
Not sure how much is still relevant....
LockDoc
Leon
Old 09-22-2015, 12:44 PM   #3
71CHEVYSHORTBED402
LockDoc
Thanks Doc. I spent hours researching just last night. The NOS (17063011) in the first thread is not the original set-up for the 71, though would probably work. It looks to be an 1980 and later part.
Tony
Old 09-22-2015, 01:17 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I have a couple... $50 Plus shipping, includes mounting bracket and rusty OEM bolts...This is another one but missing the cap...$40 plus shipping
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-22-2015, 05:59 PM   #5
71CHEVYSHORTBED402
Hi Iron. How many miles you figure on that first one? Is the charcoal still good? Should be nice and loose.
Does it have the drain on the bottom? If so, I believe the bottom comes off.
Thank you.
Tony
Old 09-23-2015, 07:48 PM   #6
Ironangel
Ironangel's Avatar
Thank you.
The first one is a pic of my daily driver and she's an actual 116,000 72 LWB C-10 (still mounted and venting the gas tank)...The second pic is out of my other 72-C-10 with 154,000 miles on the trucks clock but that canister came out and went under the bench 5 years ago. Both are in excellent shape with a fiber disk shaped filters on the bottom. Neither one appears to have been molested nor do they appear to "come apart". They are identical other than the missing cap in the second photo. I'm pretty sure that cap is in the shop...Somewhere? I do know that with a good cleaning, an exacto-knife used with ginger diligence, these units can be disassembled, cleaned and restored with an overnight soak in Armor-All, refilled with activated charcoal and glued back together for a new looking canister...PS. The bottom of both of these has a single molded plastic rod that runs across the bottom diameter of a 3-1/2" opening...
"Two Seventy Two's"
02 3/4 ton Express
Old 09-24-2015, 10:55 PM   #7
71CHEVYSHORTBED402
I'll give it some consideration Iron. I would need to cut it open, but the canister looks nice. The top on mine was thrashed by battery acid.
Tony
