Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-02-2015, 04:19 AM   #26
BigDan3131
BigDan3131's Avatar
Re: 1978 luv # 2
I know you love these things so I found another one up here for you: http://seattle.craigslist.org/sno/cto/5178085446.html
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-02-2015, 11:26 AM   #27
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Washington seems to be where majority of them sold . Northern California .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-06-2015, 10:54 AM   #28
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Getting closer .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-13-2015, 11:23 AM   #29
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Well It was a lot of work , but I got it in a really good state yesterday by 2pm and decided to take it to Lufkin @ Pinevalley raceway for one of the last bracket races of the year . I got a lot of good data from the trip think I made 5 passes . The air got really good after sunset . Passes are : 7.5929 , 7.6100 , 7.7002 ( bad burn out , it spun , my fault ) , 7.6052 , 7.5697 ( good air for the break out ) .
The goal was to us this at bracket finals in No-E sportsman which is 7.50-12.99 1/8th mile . My lights were .049-.057 all night . Im going to swtich to a 25 inch front tire to help with the lights . Had a great time . Im off next week so I will be getting the newly rechromed bumpers put on and finishing up the small details . Tags , inspection , gas gauge , carpet Little stuff . Illl update as I go .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-17-2015, 11:20 AM   #30
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Got the front and rear bumpers on . Headed to Ben Bruce memorial raceway this weekend for Texas vs Louisiana race .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-20-2015, 04:56 PM   #31
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Had a pretty good night . Won the reaction time challenge with my worst light of the night a .0327 and got to 3 cars and lost with a .-012 to and .084. I had the rpm at 2200 instead of 2000 and was watching the tach . By the time I got it to 2000 it had crept into the second bulb and was almost deep . $183.75 for semis and reaction time challenge . .003 a .012 a pair of .018s and the .032 . Now have about 10 passes on it and the fastest pass is 7.64 . Still has about 16 number swing , but trans shifts different now and then in drive . Going to try and just shift it at 5000 off the shift light Thursday . Had a blast .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-22-2015, 06:25 PM   #32
djracer
djracer's Avatar
Re: 1978 luv # 2
I am glad someone is getting to play. I have been working on a friends wife's race car just to get something to play with at the track. It is a 68 nova with one of my old small block street motors. It should run low 8's in the eighth.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-22-2015, 09:58 PM   #33
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Just gonna try shifting manually @ 5000 . I had a few electrical issues last weekend , mainly the tach light and loss of power to half the accessories . I went today to West Marine and bought a 6 place ATC fuse block and a needed power junction . All the original stuff was Japanese and worn out . The fan belt was rubbing the underside of the upper radiator hose . I pulled the bulb out of the fasten seat belt light . anyway .... im as ready as im gonna get . Leaving Thursday morning For DIV 4 bracket finals .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-22-2015, 10:19 PM   #34
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
I don't see how you guys do it . I work on these things and enjoy it , but I love to race .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-28-2015, 04:56 PM   #35
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Had a pretty good weekend . Manually shifting at 5000 worked out well . It definitely has more in it . The air was 1800DA sunday morning and 32% humidity and I won a double break out with a 7.498 . Went out 3rd round . I was like.030 to .045 all weekend . Going into 3rd I knew I needed to wittle on the .030 and made a big front tire pressure adjustment of 3#s up and was -.010 red , but my opponent was .012 so I was gonna have to make a move. I just moved to much . Before I left I installed a stereo and speaker so I could listen to the track announcer on the radio broadcast to get hints about the passes . The dash pad on this truck was long gone so I just glued some cheap carpet to it . Had a great time and figured I would add a few pictures .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-06-2015, 09:49 PM   #36
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
ended up going 3 rounds @ Div 4 bracket finals and took to big a bump and tire pressure move . Had a great time truck is fun for sure .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-15-2015, 11:04 AM   #37
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Just to update . I dropped a screwdriver while it was running and tore up the radiator . $38 later it was repaired . Got it all back together and took it to get inspection yesterday . Guess I forgot to tighten the gas cap cause when I got to the inspection place it was gone . Nobody in town had one . Got one ordered and had fun driving it around town . Sat next to a police man at a light and he just shot me a thumbs up with no plates and registration out of date . Fun truck on the street for sure . Passengerside caliper acts like it is hanging up a bit . So far so good .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-20-2015, 04:33 PM   #38
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
I took it out a couple of weeks ago on test and tune night and ran it all the way out the back . Motor seems to really like being back on gas vs E85 . 11.88 @111 on 87 pump gas. Happy with that for sure . 1.57 60'
Anyway I have a taillight on the driver side that has some sort of short . When I hit the brakes the turn signal lights . Anyway took the truck to get it inspected and got to the place and passed everything except the gas cap was gone . Guess I forgot to tighten it . Drove to every auto parts in town looking for a new one and had to order it . Bought the only 2 they had left . In Texas the previous owner has the right to keep the plates off the car . The guy I bought it from chose to keep them . Also in Texas you have to have an inspection paper to get new tags . Basically I have insurance on it , but no plates and inspection . Pulled up to a light and Baytown PD pulls up next to me . I look over and he gives me a thumbs up ! Just glad he wasn't the ticket writing guy . I worked all weekend and now we have rain . The gas gauge wasn't working and on these trucks the fuel gauge has a voltage regulator that drops the voltage to the fuel gauge and the temp gauge to 7 volts . Somewhere along the way the wires had shorted and the voltage to both was 11.7 . The fuel gauge was un responsive and the temp gauge was working , but not very linear on the higher end . I found this thing n o s .
Hopefully this fixes the remainder of the factory gauges . I also found the factory bolts for the tailgate to put the tailgate straps back on .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-08-2016, 09:42 PM   #39
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Have not updated this one in a while , but I was trying to save my Yellow truck for IHRA . I took this one out for sat/sunday NHRA race . I double teched it box and no box and I was killing it . Worst light was .033 . Headed into 3rd round in no box . I was .087 and 6 numbers slow for the lose . 3rd round super pro or box I was .088 and 7 slow . Broke the sprag in the converter .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-11-2016, 11:35 AM   #40
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
So last update I broke the sprag in the converter . Well I pulled the trans , which is a pain in the butt. These trucks have torsion bars like a Duster and the transmission crossmember is solid as it also holds all the rear mounts for the torsion bars . Trans has to come out bellhousing first . I had a tci break away (2800) in the garage and threw it in . Way to tight compaired to the tci super street fighter at 3800 . I took the truck to get it inspected and they wouldn't pass it due to the et streets . Inspector was a dumbass and didn't even know what a dot number or expiration date was . I wasn't letting this idiot drive my truck . Came back and put a set of 275/60's on it and was headed to another inspection station and got on it a bit to hard . Motor still has oil pressure , but has a real light rod knock . It can be saved , but needs to come out . I put new intake gaskets in the 388 pump gas motor and the super street fighter is rebuilt and fresh , so new motor and coverter .
My next question is about the trans . I have a th350 being built and the builder offered me what he calls his super stock trans . It is a 700 planetary machined to fit a th350 case . This changes the first gear from 2,52 to 2,75 . Truck has a 3,60 gear . Looking for opinions on this first gear change
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-16-2016, 08:20 PM   #41
regan wilson
regan wilson's Avatar
Re: 1978 luv # 2
I did the math and it really doesnt run the starting line ratio up that much. If your not having alot of trouble with tire spin it make help perk up the R-T's. It's a difference of 9.072 to 9.90 starting line ratio.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 11-17-2016, 10:14 PM   #42
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Well I have always aimed for 9 to 1 first gear . Also worried somewhat about the bigger rpm drop going into second . I can mount a 28 x 10.5 and make shock adjustments and I think I can make it work with my very stock suspension .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-06-2016, 01:35 PM   #43
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Well just an update . truck got driven at a truck race in the 12.0 class here in Houston and got a bit hot . Looks like it got a head gasket . Afr headed 388 going in with rebuilt converter . Also the long tubes off my yellow truck and a new exhaust system going in . This motor was .2 slower than the old "beater" in my yellow truck so maybe we can slow it back down to 7.50 1/8th mile . It has been as fast as 11.44 now . Anyway here are some update photos . Oil had water in it .
Coolent in the starter bolt hole
Old motor coming out
New motor
Going in
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-06-2016, 10:29 PM   #44
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Well I got a bit further and the motor doesn't look hurt to bad . It looks like it got hot and pushed water from the water jacket into the valley from the corner . Any way here are more pics of progress .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-08-2016, 04:38 PM   #45
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-24-2016, 08:29 PM   #46
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
This is a video from last years bracket finals .
https://youtu.be/MHX0fi9_NCE
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-06-2017, 12:31 PM   #47
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Moved the shocks straight up to make room for exhaust .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-03-2017, 08:51 PM   #48
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
had an ever so slight oil drip over the back of the block and the starter . Found the problem and fixed it . Guess I didn't put down enough sealer on the rear China wall.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-29-2017, 06:16 PM   #49
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
Well , I have been driving this thing more and more as my yellow truck has issues . The motor seems to be getting better the more I drive it , So far best pass is a 6.97 in killer air . I ran it in Baytown in no box and went to 7 cars and in the money . It was around 7.07 in 2800DA air . Of coarse I got protested for safety , but they let me finish out the weekend . I bought a Willys restrictor plate for it and this cuts it back to 7.48 ish . Yesterday they had an Iron man race for 7.0 index and only one car showed up so we went for it . I told them hey here is the deal , no bars . They said we are good with it . We tree'd a dedicated 7.0 back half Vega and didn't have enough . We went 7.10 all out and he only clipped up by .014 at the finish line . A buddy of mine drove it at the truck race in Baytown and won the 12.0 index with it also .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 06-11-2017, 06:20 PM   #50
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 1978 luv # 2
GOt the exhaust finished on this thing and now it is tagged and inspected again . My yellow truck is down so I have been bracket racing this truck . With the restrictor plate open it runs 7.25 with the back pressure and added weight of the exhaust . We went to Evadale Saturday morning and lost in the finals . Then loaded up and made the trip to Pinevalley as the gates opened at 4 pm . First time trial was at 6 pm , we pulled in at 5;45 just in time . Huge car count . Lost at 11 cars to a 14 pack . Had a great weekend of racing .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
