10-01-2015, 10:41 PM | #1 |
Power steering issues, gm box- cummins pump
I'm having issues getting my powersteering to work. At idle I have some chatters and kinda works. When bringing truck off idle ps is gone. I used the 72 gm box and the 91 dodge pump. I adapted the two with braided line and an fittings. I think it was -6 for ps pressure (braided with plastic liner)
Do you think the line is to small? Both trucks worked great before tear down. Matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
10-02-2015, 08:48 PM | #2 |
Re: Power steering issues, gm box- cummins pump
Got it fixed, tons of air in system. Took alot to bleed out compared to other cars I've done
10-03-2015, 01:30 AM | #3 |
Glad you got it fixed. I had the same problem with mine.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
10-05-2015, 08:33 PM | #4 |
6>8 Plugless........
I've had a tough time gettign a couple trucks bled out after a full build before. It seems jacking the front axle up and turning the wheel swith no weight on it helps get the system moving. Sometimes it takes cracking the pressure line at the steering box.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
