04-27-2014, 07:02 PM | #201 |
Re: Tail light fuel filler
Bump.
04-29-2014, 03:33 PM | #202 |
Subbed.
'72 GMC Super Custom 1500 350 V8 w/AC |
04-29-2014, 05:23 PM | #203 |
Well If I can get the Make and part Number of the Filler cap then I will order it and reinvent the wheel and try to do this myself... I would appreciate any info you can supply me with... Thanks... Dan
04-29-2014, 08:40 PM | #204 |
Not sure, but it looks like he modified a white cap #6993A
04-29-2014, 09:40 PM | #205 |
04-30-2014, 07:26 AM | #206 |
white cap brand. It is a Marine part . #6993A
05-05-2014, 03:35 PM | #207 |
I was using a stainless, push-up marine style filler, labeled "water", and machining the mounting lip off of it. Like this one. http://www.ebay.com/itm/NEW-316-stai...vip=true&rt=nc
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
05-05-2014, 04:05 PM | #208 |
Still Learning
Hey Wynne,
You have used this setup for several years now, do you have any trouble doing fillups at the pump? What gas tank are you using? I am still leaning towards a similar setup but worry about slow filling.... |
05-06-2014, 09:06 AM | #209 |
I have one of Fuelcellguy's tanks, and don't have any trouble with slow filling, but I usually don't hold it wide open. I usually fill it at about 1/2 to 3/4 speed, which is plenty fast enough, and it's only a 16 gallon tank, so it doesn't take long. If I top it off too fast, it will burp fuel out when it gets full, and if I pull into a station that has the big boot around the nozzle, I may have a problem, but so far it hasn't happened. I think the key to fast filling is being able to vent the tank as fast as you want to fill it. I have mine vented with a 3/8" hose at one corner, and another 3/8" hose running from the top of the tank to the filler, just below the gas cap. It works ok, but I think a 1/2" vent line would be better.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 05-06-2014 at 09:32 AM. |
12-20-2014, 06:05 PM | #210 |
Any update on the hidden fuel filler
10-27-2015, 03:57 PM | #211 |
bump
10-27-2015, 06:51 PM | #212 |
I was able to fab everything up for little cost with a Marine filler neck /cap assy, handsome plate metal from Atwoods. It took me 2 or 3 times making one from scratch to get it right, but once you get started it's not that big of a deal. You just have to cut away quite a bit behind the drivers tail light assembly.
10-27-2015, 08:12 PM | #213 |
thanks man. i have no problem making one from scratch. its just with work and the kids, it would be great to just buy one pre-fabbed, ready to tack in there
ive seen one guy run his through the reverse light. after youve done this, do you think that would be easier or harder than the tail light? thanks |
10-27-2015, 08:43 PM | #214 |
I understand about you not wanting to have one yourself. I felt the same way, but not being able to buy one, I had no choice. I definitely would not try to do on through the reverse light, there is not enough space!
10-28-2015, 12:07 PM | #215 |
I still have the pattern in the laser cutter
I can make more, I just got so much crap from some guys on the board about it I just let it lay $10 Flat or $25 bent up
1950 Chevy 1500 1961 C-10 1969 C-10 1971 Chevelle 2008 Dodge HD3500 Tow Rig |
10-28-2015, 06:53 PM | #216 |
I'd be interested in a bent one, but what's involved to install?
10-28-2015, 11:56 PM | #217 |
I'd be interested in a bent one, too
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
10-31-2015, 11:44 AM | #218 |
10-31-2015, 11:48 AM | #219 |
10-31-2015, 06:55 PM | #220 |
Parts and more parts
What is needed to order a bent piece from you? Be happy to work it out, however you want.
Frank
Frank |
11-12-2015, 09:51 PM | #221 |
I'd be interested in a bent one as well. Thanks.
11-12-2015, 10:08 PM | #222 | |
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
11-12-2015, 11:02 PM | #223 |
here is the one in my 67... It is roughed in at this point so final adjustments need to be completed...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
11-12-2015, 11:14 PM | #224 |
Is this something that can be done with no tail light trim??
11-12-2015, 11:15 PM | #225 |
Sure... it wouls actually be easier...
