Old 09-26-2015, 10:28 PM   #226
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Blazer SPID thread?
LOL! That one gets my vole for the oddest one yet - thanks for posting Brad.
Old 09-27-2015, 12:04 AM   #227
IronCanine
I'm trying....
IronCanine's Avatar
It's neat not only for the unlabeled codes or the random codes, but also for the BX2 and the A50 which I think should technically be covered by the Z84.
Edit---also by the book, I think all CSTs should have come with a spare tire cover.
Double edit--another one I missed...how about the CB8 and Z58
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 09-27-2015, 01:01 AM   #228
Chulisohombre
Chulisohombre's Avatar
Man that truck had everything. Except had z84 package and ordered black vinyl seats. Should be highlander with that. Some of the blanks I'm wondering about though.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-27-2015, 01:53 AM   #229
SS Tim
SS Tim's Avatar
CKE182F100563 is the listed VIN.
Nothing sinister or really unusual actually. Go back to posts 219-222 for a similar St. Louis example. Its really just a case of too much information common during SPID format changes.
Being the 563rd truck off of the 72 Flint line I am surprised its even that good. There were a lot of issues getting the correct RPO suffix codes during the change over from letters to numbers for the 72 MY.
It was what it codes.
K5 Hugger Orange with Black CST trim and a White top.
BTW Those RM1 codes with the blank descriptions are H78-15/B
On-Off Road Bias Belted tires.
CSTs ordered with a hard top included a spare tire cover. So most but not all CSTs had tire covers as shipped.
SS Tim is offline   Reply With Quote
Old 10-26-2015, 03:10 PM   #230
SS Tim
SS Tim's Avatar
Originally Posted by Trifelynn View Post
So is there a different code between the single wall top and the double wall top?
Is there a way you can tell the difference from the SPID?
To clear things up this is from GM dated January, 1972
"New Removable Top Assembly (RPO CC3) 1972 Blazer
A new (simplified construction) top is being offered to supplement the currently available (RPO CB8) top for Blazer models. The new top (RPO CC3) is a single skin design with three exposed interior roof rib reinforcements running from side to side, whereas the RPO CB8 top is a double skin design with inner roof panel lines running front to rear. Part numbers for the two tops are as follows:
RPO---Part No.--Color
CB8--6262051---Black
-------6262052--White
CC3--6271845---Black
-------6271846--White
Mounting of the new top differs from the earlier style in that attachment to the box is accomplished through floating anchors contained in the box sides (Fig.1). The top is then bolted from above making trim panel removal unnecessary.
New parts contained in the RPO CC3 top are:
* Side door glass weatherstrip and retainer (providing an adjustable weatherstrip feature).
* Thinner (1/8 inch) side glass and weatherstrip.
* Top to box weatherstrip.
* Seal and metal retainer around lift gate hinges.
* Top to box side molding and chrome plated hold-down bolts.
The lift gate and attaching parts, header weatherstrio, and header attachments are common to both tops."
Unfortunately unless you have a build (broadcast) sheet or one of the atypical SPID as mention in earlier posting you will not see the CB8 OR CC3 codes. Generally they are found only on the build (broadcast) sheet. There they indicate the conversion of the vehicle to a removable hard top. Where the generally seen SPID codes Z58 (White) and Z59 (Black) really only indicate the color and confirm a factory hardtop installation.
Old 10-26-2015, 04:35 PM   #231
IronCanine
I'm trying....
IronCanine's Avatar
Wow Tim...fantastic info as always. Thanks for being the guru.
Old 10-28-2015, 05:22 PM   #232
WarMonger
WarMonger's Avatar
Ok, here the SPID from my Blazer. Quick question, what is the H78-15-B ON-OFF ROA?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 10-28-2015, 05:25 PM   #233
IronCanine
I'm trying....
IronCanine's Avatar
Tires.
Old 10-28-2015, 05:30 PM   #234
68panelman
68panelman's Avatar
Bias ply tires that is
68panelman is offline   Reply With Quote
Old 10-28-2015, 05:36 PM   #235
WarMonger
WarMonger's Avatar
well now I feel stupid
1970 C20
-_--_--_- ______
1972 K5
Old 10-28-2015, 07:29 PM   #236
SS Tim
SS Tim's Avatar
Five bias belted tubeless blackwall tires with an on-off road tread.
Old 12-06-2015, 09:21 PM   #237
joea307
joea307's Avatar
I just bought a 71 blazer glove box door and driver door here is its spid
joea307 is offline   Reply With Quote
Old 01-08-2016, 02:58 PM   #238
SS Tim
SS Tim's Avatar
A member's 70 4X2 Gold on Gold 6cyl 3OTT.
http://67-72chevytrucks.com/vboard/s...4&postcount=87
Old 01-16-2016, 12:06 PM   #239
yim94
Here's mine 1970 2WD Jimmy.
yim94 is offline   Reply With Quote
Old 02-02-2016, 11:09 PM   #240
DeadheadNM
Carpe manana
DeadheadNM's Avatar
uno mas...red w black interior
Old 02-03-2016, 06:26 PM   #241
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
[QUOTE=SS Tim;7354312]To clear things up this is from GM dated January, 1972
Tim - thanks for sharing this info. I had a guy from a local repair boat shop come by the house to take a look at my top. In the photos below I drew black annotation marks to call out, or confirm if these are the roof rib reinforcements running side to side? We were discussing these and neither of us could determine if this was factory or if this was a repair that happened at some point in time.
Thanks!
Mike
This is the driver front side. They have the same matching lines on the other side as well.
Name:  Top front side.jpg
Passenger backside
Name:  top back side.jpg
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 02-03-2016, 08:08 PM   #242
Chulisohombre
Pretty sure the roof ribs are up Top and not on the sides. It gives the top the strength it needs to support its own weight and not sag.
Old 03-13-2016, 06:52 PM   #243
cst204x4
Here's a spid on a glove box door from a blazer that got parted years ago
1970 CST 4x4 collecting nos parts for this project
1972 cutlass owned since 1984
1972 cutlass conv
1970 Cutlass conv
1981 chevy shortbox
1986 grand national
2004 2500HD Crew Cab 66,000 miles
cst204x4 is offline   Reply With Quote
Old 03-13-2016, 08:05 PM   #244
IronCanine
I'm trying....
IronCanine's Avatar
That's about as loaded a 70 as I've seen. Wish it still existed.
Old 03-13-2016, 08:15 PM   #245
skrenly
skrenly's Avatar
Unusual options. AUX battery, camper mirrors.
skrenly is offline   Reply With Quote
Old 03-13-2016, 08:17 PM   #246
skrenly
skrenly's Avatar
Another CST
Old 03-13-2016, 08:33 PM   #247
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Does any one have the option two ton colors for the seats.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-13-2016, 11:44 PM   #248
Chulisohombre
Those trucks were loaded about s much as can be possible. My dads jimmy had the camper mirrors stock I believe as well. Wish it would have lasted long enough to be my first truck. Mom wrecked it one winter and sold the jimmy as a parts truck. I was a sad little boy to se it go. That's why I bought my blazer. Wanted those memories back.
Old 03-14-2016, 12:23 AM   #249
Lumaestas
Heres my 71 CST
Lumaestas is offline   Reply With Quote
Old 03-14-2016, 01:10 PM   #250
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice - thanks for posting these. Gary by two tone do you mean Highlander plaid? Can't recall seeing another OEM style seat set up close to two tone for utility or sport buckets.
