10-30-2015, 12:40 AM | #2801 |
Re: What did you do to your truck today? Chapter II
I'm taking advantage of my truck being parked for the winter to do a few projects. Tonight I finished installing a new turn signal switch in my non-tilt column. It went easier than I thought, but I couldn't see any way of feeding the molded, half moon shaped plug through the small opening in the housing. I ended up making a clean cut near the dash connection and resplicing the wires back together. Turned out pretty good I think.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-30-2015, 08:04 AM | #2802 |
Swapped out my Flowmaster Super 50s for a pair of Dynomax 17615 Installer Turbo mufflers dumped under the axle. ....Little quieter, but not as quiet as I would like. Don't have the room for a larger muffler without rerouting the pipes..
1970 C10 Short Stepper with 71/72 front clip. |
10-30-2015, 08:22 AM | #2803 |
Dumping the exhaust under the bed is always going to be noisy , try full length pipes and enjoy the quietude .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-30-2015, 08:27 AM | #2804 |
GARY 67 LWB CST FLEET 56 CHEV 3100 55 CHEV BEL AIR 2DR SEDAN 67 BUICK GS400 CONVERT |
10-30-2015, 08:40 AM | #2805 | |
If I go to a shop, I would probably have them reroute from the headers back.
10-30-2015, 10:06 PM | #2806 |
10-30-2015, 11:15 PM | #2807 |
10-31-2015, 01:08 AM | #2808 |
Got some new 16x7 steelies and 245/75 tyres for the c20
John 69 c20, 396, th400, dana60, ps, ac |
10-31-2015, 07:16 AM | #2809 |
laying low
That's a real nice looking truck John.
10-31-2015, 08:10 AM | #2810 |
Thanks Boog
10-31-2015, 03:12 PM | #2811 |
Swapped out the pair of Dynomax 17615 installer turbo mufflers I just installed back to my Flowmaster Super 50s. Turns out the turbos we not any quieter than the 50s and sounded crapy at idle and revved. Shipping them back.
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 10-31-2015 at 05:46 PM. |
10-31-2015, 05:35 PM | #2812 |
Was able to get more paint off the heater box. I hope I can get it all off and so, return it to OEM grey plastic glory.
10-31-2015, 08:49 PM | #2813 |
Installed my buddy buckets and dash pad.
Scott |
10-31-2015, 11:30 PM | #2814 |
I removed my gauges for a good cleaning. I plan to repaint the silver on the edges and then put the wood grain decal on it. I used self adhesive wood grain shelf paper on the glove box door and ash tray to see it I liked the look. It turned out so nice and matches the decal from Brother's Truck so well I might just leave it that way. OPINIONS?
1960 Buick Invictia 4dr Hard Top- 30,000 mile survivor 1965 Impala Conv- project 1967 Mustang, wife's project 1968 C20, driver/project 1952 Ford F1, son's project/my first truck 1990 Jeep wrangler, daily driver |
11-01-2015, 07:49 AM | #2815 |
Brad handshoe |
11-01-2015, 09:27 AM | #2816 |
Scott |
11-01-2015, 11:49 PM | #2817 |
FWIW ;
I like the sound of a robust engine ~ I often don't run any muffler at all but them I have nearly stock engine . A crossover on a V configuration engine will always make it run better and mellow out the exhaust bark at the same time . I can't imagine a rig so low you can drive it but not have space to run a 2 - 1/2" exhaust . If the pipe gets too close to he bed wood , simply install a sheet metal heat shield like GM did back in the 1940's , it worked perfectly .
11-02-2015, 01:09 AM | #2818 |
11-02-2015, 08:53 AM | #2819 |
first time out of garage in a long time. more polishing and assembly and it will be ready for a road teat.
11-02-2015, 01:32 PM | #2820 |
Two - tone looks sharp! .
11-02-2015, 03:22 PM | #2821 |
I've had new fender emblems sitting on the bench for a couple of years now, so I decided to change them while my truck is parked. The bed has been pulled and new bed wood is being milled and prepped. I pulled the inner fenders as part of the job, and I am going to have them painted to match my exterior paint.
11-03-2015, 06:42 PM | #2822 |
[QUOTE=OregonNed;7362541]I've had new fender emblems sitting on the bench for a couple of years now, so I decided to change them while my truck is parked. The bed has been pulled and new bed wood is being milled and prepped. I pulled the inner fenders as part of the job, and I am going to have them painted to match my exterior paint.
Looks great, but thats a lot of work to change emblems good luck on your truck .... |
11-03-2015, 09:32 PM | #2823 |
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
11-03-2015, 09:42 PM | #2824 |
I installed a new dash pad. I used wing nuts because it was awful hard getting the little nuts on!!
11-03-2015, 11:28 PM | #2825 |
While at the local u-pull it yard and browsing, i ran across a 71c20 that was pertty well picked over. i found the original power steering pump and bracket still in place, i have manual steering now. 25.00 dollars and it was all mine.
