#276 | |
Re: Camaro Caliper Brackets
#277 |
How do these calipers adjust the parking brake for pad wear?
#278 |
60-66 Nut
I just assumed they had some sort of internal ratcheting mechanism. Did you use new/rebuilt calipers or used?
#279 |
They are rebuilt. The design does not have a ratchet. The Camero did though, have a ratchet built into the handle. But I'm unsure if this was to adjust the parking brake or simply keep the cables tight.
#280 |
Has anyone successfully tested this on a running truck? How's the P brake hold?
#281 |
#282 |
Do you make a kit to utilize a 98-02 camaro ls1 brake it? I have a 6 lug 64
Posted via Mobile Device |
#283 |
60-66 Nut
No I do not. I just have the two 6 lug rear disc brackets.
#284 |
Not sure if this is the right place to ask this question, but what is everybody using these rear brakes using for a proportioning valve? I would really like to avoid using an adjustable one if at all possible.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#285 |
60-66 Nut
I do not know if there are any differences in the brake bias with the aftermarket fixed disc/disc proportioning valves.
#286 |
I had interference with the e-brake lever arm on the caliper and the bottom of the back of the trailing arm. SO I installed these facing forward. But now I am putting airbags in the rear and the e-brake cable will interfere with the bag.
The main problem is the big rubber bushing that's on the e-brake lever arm. I don't know what that is for - harmonic dampening? Any suggestions? |
#287 | |
60-66 Nut
I believe the 'rubber bushing' you are referring to can be removed. Do you have any pics of your installation. I just can nit picture how the e-brake lever could make contact with the trailing arm. I have been looking at the pics in post #184 and post #220.
#288 |
driving is in my blood
The time has finally come and I check back to make sure everything is good and see this. So I re-read the thread and found you already said they won't work many pages ago. Dangit!! I have the 10 bolt. When I read 10 and 12 bolts I just assumed my 98's 10 bolt was the same.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#289 | |
60-66 Nut
Sorry but I still don't have anything for the '88-'98 10 bolts, I'm still working 80 hrs a week every week. There are actually 2 versions of the 8.5" 10 bolts in the '88-'98 trucks which have different backing plate flanges both of which are different from the '87 and earlier 10 bolts. I assume one is a standard duty and the other is a heavy duty. Additionally the '88-'98's have a wider brake offset. I am still hoping to get to these one day.
#290 |
hello there! Please tell me you are still making these?!
#291 |
60-66 Nut
Yes all of my products are still available including these rear disc brackets. would you like them in bare steel or satin black powder coat?
#292 |
#293 |
60-66 Nut
PM replied to
#294 |
I PM'd you about getting some bare steel camaro caliper/impala rotor brackets.
#295 |
60-66 Nut
I replied to your PM from early this morning. I only have time to log onto the forum once a day, in the evenings after I get home.
#296 |
Never Ending Projects
Sent ya a PM for a set of brackets.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#297 |
60-66 Nut
#298 |
After reading through this entire thread it's not clear -- has anyone found calipers that include the bracket and e-brake setup? Rock Auto has excellent deals but not all of their products have pics, so it's hard to say whether this stuff is included.
1968 LWB C20 / AC / Wood Bed |
#299 | |
![]() Join Date: Oct 2004
#300 |
I'd rather find a new or reman set, never know what you're going to get with used calipers! On the other hand there could be useful connectors to be had along with the salvaged calipers...
