Old 11-12-2015, 09:11 PM   #51
diceman50
Re: Supercharger for my Apache
While I was degreeing the cam in my new engine I decided to build a proper timing indicator.
http://i532.photobucket.com/albums/e...111_135455.jpg
http://i532.photobucket.com/albums/e...111_135657.jpg
http://i532.photobucket.com/albums/e...111_140104.jpg
http://i532.photobucket.com/albums/e...111_140448.jpg
http://i532.photobucket.com/albums/e...141213_001.jpg
http://i532.photobucket.com/albums/e...111_141307.jpg
http://i532.photobucket.com/albums/e...111_142007.jpg
"In an insane world a sane man must appear insane" ~Spock~
diceman50 is offline   Reply With Quote
Old 11-12-2015, 09:16 PM   #52
diceman50
Then I added some additional marks to the balancer.
http://i532.photobucket.com/albums/e...111_154624.jpg
http://i532.photobucket.com/albums/e...111_154630.jpg
Old 11-12-2015, 11:43 PM   #53
Advanced Design
Advanced Design's Avatar
Did you make the mark with a bit in a vertical mill?
Advanced Design is offline   Reply With Quote
Old 11-13-2015, 01:43 PM   #54
diceman50
Yes, I am using a balancer for a 250 engine and it had a TDC notch already (the one with the square bottom) so I built my indicator accordingly. Then I added 6 more notches at 2 degrees each with my rotary table and mill.
http://i532.photobucket.com/albums/e...113_111917.jpg
Old 11-13-2015, 04:18 PM   #55
Advanced Design
That looks seriously handy!
Old 11-13-2015, 10:46 PM   #56
diceman50
Here's the final product.
Old 11-13-2015, 11:09 PM   #57
Z10
Z10's Avatar
Excellent my friend! It looks "Factory"
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 11-13-2015, 11:23 PM   #58
diceman50
Oh crap, now I have to start over.
Old 11-14-2015, 10:38 AM   #59
Advanced Design
Looks good. Factory custom? I was wondering what the twisted wire is on the balancer.
Old 11-14-2015, 10:52 AM   #60
OutlawDrifter
Safety wire.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-14-2015, 01:36 PM   #61
diceman50
It is safety wire. The bolt I have is AN spec with a safety wire hole in it so I decided to use it. I drilled a 3/32 hole in one of the spokes to tie it to and used .041 safety wire. Not really necessary but, "what the hell".
Old 11-14-2015, 02:01 PM   #62
Advanced Design
Pretty cool though. I zoomed in on the pic of the wire and couldn't see it running through the bolt head.
Old 11-15-2015, 06:01 PM   #63
diceman50
While I was building the timing pointer it occurred to me that since the belt grooves are machined into the inertia ring on the damper I might have a problem. I was wondering if the extra load of the supercharger might make the inertia ring (i.e. the pulleys) slip on the hub. I talked the situation over with my son who has been building and tuning Indy Car and Daytona Prototype engines for 30 years and one of my best friends who is a master automotive machinist. The consensus was maybe, probably, and eventually. I decided it would be much easier to deal with it now instead of later so I designed and built a "harmonic damper snubber".
I bolted an aluminum disc to the inertia ring with 6 10-32 screws. Then oversize holes (9/16") were drilled in the disc for the 3/8" hub bolts. Then "O" rings were placed over the hub bolts to take up the space and provide a cushion if the inertia ring ever does slip. The theory is that if the load is to great for the elastomer ring between the hub and the pulleys the snubber will catch it before the elastomer ring is damaged. I hope it works!
Old 11-15-2015, 09:12 PM   #64
Purcell69
Very nice work and good thinking. Better safe than sorry.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 11-15-2015, 11:06 PM   #65
diceman50
Thanks Joe,
Now that I have my crank pulleys sorted out I can get back to work on my supercharger mount. I had to make another mounting plate because I didn't realize that the front head bolt is offset 5/32nd's of an inch when I made the first one. I tried to enlarge the holes but couldn't get it to fit properly. It was also a chance to make a couple of other changes. That 3/8" hot roll is giving my old yard sale band saw a workout.
Old 11-17-2015, 10:12 AM   #66
RockinKees
RockinKees's Avatar
Love your inguinity!!
Looks great!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-17-2015, 09:36 PM   #67
diceman50
Thanks Kees,
I made a little more progress on the supercharger mount today.
Old 11-17-2015, 10:09 PM   #68
Purcell69
That is looking fantastic!
-Joe
Old 11-17-2015, 10:20 PM   #69
Advanced Design
The balancer snubber is a good idea. I didn't consider the potential load on the ring / pulleys. Well, actually I haven't noticed pulleys incorporated into the balance ring due to my lack of knowledge on these engines. Again a fun learning experience for me.
Nice triangulation on the mount. Do you have any concerns about the load on the lower bolt?
Old 11-17-2015, 10:56 PM   #70
diceman50
Thanks A/D,
Good question! Since the top plate is 3/8" steel I don't think there should be much deflection in it plus the bolt is 3/8". That's the good thing about these old engines, all the hardware is heavy duty. Also, I am planning on putting another brace in the back once I get the manifolds mounted. Better safe than sorry. I am more concerned about the load on the belt since I am going to be running the supercharger and the alternator on it. I'm not looking for much boost so maybe it will be okay.
Ronnie
Old 11-18-2015, 12:29 PM   #71
diceman50
A friend was looking at the supercharger mount yesterday and asked me how I aligned the pulleys. I came up with an idea several years ago using my laser bore sighting tool and thought some of you might be interested too.
Old 11-18-2015, 09:20 PM   #72
Advanced Design
Great idea! Which one do you have Ronnie? Actually, I didn't know they existed and can see lots of uses for that tool. Thanks for sharing!
Old 11-18-2015, 10:39 PM   #73
diceman50
Mine is an inexpensive generic unit. You can buy them all over the internet for about $30 or less. When I worked at a chassis shop building drag cars I machined a piece of plastic to fit in the tail housing of an empty powerglide transmission we used for mock up and inserted one in it. Once the engine and transmission were mounted I could measure and square everything on the chassis and rear suspension with it.
Old 11-18-2015, 11:04 PM   #74
Advanced Design
Thank you Ronnie. Another good idea there. Amazon is shipping one to me now.
Old 11-18-2015, 11:30 PM   #75
diceman50
Your welcome A/D,
It was a good afternoon in the shop today. I built and installed a new alternator mount to work with the supercharger drive. Because I have to lay the alternator out horizontally to tension the belt I had to raise it up to clear the motor mount. I was also able to get the belt tensioner mounted for the blower belt.
