Old 11-29-2015, 08:57 AM   #76
freemoto_xxx
Re: 1972 c10 om 2001 tahoe 4x4 chassis
Originally Posted by swamp rat View Post
Per that body mount nut, if that idea doesn't pan out I see a hole on the bottom of the frame that could be hogged open a bit and reinforced if necessary, you could possibly weld it thru the bottom or just use a socket and extension?
That's not a bad idea
freemoto_xxx is offline   Reply With Quote
Old 11-29-2015, 05:14 PM   #77
freemoto_xxx
Ok the cab is back on for the final time. Now just test fitting the rest of the body then time to make it run
Old 11-29-2015, 07:06 PM   #78
57taskforce
All about them K’s
57taskforce's Avatar
Are you posting this all real time?? I.e. As its happening? If so this is pretty incredible that you've got it to this point in only a week or two. Looks like your doing excellent work. I've done a K/5 frame swap on my 3100 so I know first hand the amount of work this takes. Looks like your doing a great job!
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 11-29-2015, 08:58 PM   #79
freemoto_xxx
The post where I cut up the tahoe was a week prior but everything else is real time. And thank you
Old 12-04-2015, 11:09 PM   #80
freemoto_xxx
i built the new steering shaft and installed the 2008 trailblazer ss brake booster and master cylinder
Old 01-13-2016, 08:26 AM   #81
MARKDTN
Any updates on this? I was enjoying this one.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-14-2016, 01:10 AM   #82
NurseBen
NurseBen's Avatar
Yes, more please! I'm doing a similar swap but with a 2011 GMC Savana AWD van. I'm only using the chassis/running gear but have some questions for you. Looks like the track width of the van and Tahoe are fairly close, I believe the van is a few inches wider, have you run into any issues with wheels protruding from the fenders? Looks like your keeping the stock height, mine will be as low as possible so I'm anticipating fitment issues. Why did you redo your gas lines? I'm enjoying your build, keep the updates coming.
Ben
NurseBen is offline   Reply With Quote
Old 01-14-2016, 01:12 AM   #83
NurseBen
NurseBen's Avatar
Oh and what did you use for the steering shaft. Thank you
Old 01-14-2016, 05:20 AM   #84
junkcarguy
Subscribed I'd like to do one with a awd escalade
junkcarguy is offline   Reply With Quote
Old 01-14-2016, 12:26 PM   #85
SaltyC20
SaltyC20's Avatar
This looks awesome. Does anyone have links to other body swap build threads like this?
1968 Chevy C20
SaltyC20 is offline   Reply With Quote
Old 02-07-2016, 03:44 PM   #86
freemoto_xxx
ok getting back on track. i had to work for a couple months now i have about a week of down time. i need to re do the brakes then mount the rest of the sheet metal. after that it will be time to test drive
Old 02-07-2016, 03:46 PM   #87
freemoto_xxx
new carpet also came in
Old 02-07-2016, 03:47 PM   #88
freemoto_xxx
i used a mix of the 72 chevy and the tahoe steering parts to make the shaft
Old 02-07-2016, 03:49 PM   #89
freemoto_xxx
Ben
my truck will be lowered. it doesnt look like im going to have an issue with tire rub
Old 03-07-2016, 04:20 PM   #90
NastyBuzzard
NastyBuzzard's Avatar
You are doing an awesome job. Do you still have the crew cab short bed with the 6.5 TD?
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 03-07-2016, 05:41 PM   #91
kehstr
kehstr's Avatar
subscribed
kehstr is offline   Reply With Quote
Old 03-07-2016, 06:29 PM   #92
Ed F
Ed F's Avatar
Subscribed
Ed F is offline   Reply With Quote
Old 03-07-2016, 09:30 PM   #93
sleepertruck72
sleepertruck72's Avatar
You sir are doing some nice work !
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 03-15-2016, 06:22 PM   #94
freemoto_xxx
Rebuilding the front end. I want it to drive like new
Old 03-15-2016, 07:19 PM   #95
freemoto_xxx
Yes I do and I'm thinking about selling it
Old 03-16-2016, 06:50 AM   #96
NastyBuzzard
Can you give me some info on it or pictures? I am currently building a 88 crew cab short bed that I converter to 4x4 and I have a 6.5TD/NV4500 for it. I haven't seen or couldn't really find anyone who has done a build thread on it.
Old 03-16-2016, 11:33 AM   #97
treveiger
treveiger's Avatar
Looks great so far.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-16-2016, 12:48 PM   #98
AMERICAN PICK-UP
looking GOOD sir...
AMERICAN PICK-UP is offline   Reply With Quote
Old 03-16-2016, 12:54 PM   #99
Custom/20
Custom/20's Avatar
Talking Re: 1972 c10 om 2001 tahoe 4x4 chassis
Great job so far man, looking forward to seeing it on the road!
Custom/20 is offline   Reply With Quote
Old 03-16-2016, 09:47 PM   #100
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Crew cab shortbed with a 6.5? I'm intrigued, especially one that's for sale. Tell us more!
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
