11-29-2015, 03:14 AM | #26 | |
Re: Dana 60 Ratios
11-29-2015, 10:05 AM | #27 |
Re: Dana 60 Ratios
Next logical question would be if this ratio was a regular option on GMC 3/4 tons with the Dana 60, could this ratio be special ordered on a Chevy 3/4 ton with a Dana 60?
11-29-2015, 10:51 AM | #28 |
Re: Dana 60 Ratios
Interesting find. I'd think yes, in Chevys too.
11-29-2015, 11:19 AM | #29 |
Re: Dana 60 Ratios
That is quite an interesting find. First I've ever seen or heard of 3.73s factory optioned in a 67-72 3/4 ton.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
11-29-2015, 10:40 PM | #30 |
Re: Dana 60 Ratios
Very interesting thread, I had never seen or heard of a 3:73 ratio in a 3/4 or 1 ton before. But here is a GMC longhorn SPID with it listed.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
11-30-2015, 12:43 AM | #31 | |
Re: Dana 60 Ratios
If you have 4.56's, you can run 4.88's, 5.13's, and a fair bit lower. It is also possible to swap in 3.07's if needed. |
11-30-2015, 10:06 AM | #32 |
Re: Dana 60 Ratios
Makes me wonder about any 4wds out there.
12-01-2015, 12:45 PM | #33 |
Re: Dana 60 Ratios
I had a '72 K2500 (D60/D44) that had 3.73's. There was no mention of gear ratio on the SPID so it could have been swapped but IDK.
12-01-2015, 12:48 PM | #34 | |
Re: Dana 60 Ratios
12-01-2015, 03:37 PM | #35 |
Re: Dana 60 Ratios
I've got a 3.54 in my coil spring C20, but since I've recently installed a 2004r I'm looking for a 4.11 but haven't had any luck. Has anyone changed gears? I'm wondering how hard it would be.
12-02-2015, 09:09 AM | #36 |
Re: Dana 60 Ratios
You really shouldn't need to do that. Look a little harder, I am sure you will find someone who would swap. Is yours a factory big block/TH400 truck?
12-02-2015, 02:11 PM | #37 |
Re: Dana 60 Ratios
It originally had a 327 T400 combo with the HO52 rear with 4.56 gears. That was too high so I swapped in the dana 60 with the 3.54, which was much better! Then I came across the 2004r and installed that and now the gears are a little too low, about 1600 at 65.
12-03-2015, 12:33 AM | #38 | |
Re: Dana 60 Ratios
I consider swapping gears to be easy, but I see many people that are scared of setting up a Dana differential that will advise against it. I don't even have a case spreader and still don't have any trouble. |
12-03-2015, 02:03 PM | #39 |
Re: Dana 60 Ratios
