Old 12-11-2015, 08:31 PM   #176
aotte1
Re: 64' K10 Project Long Bed
Front Spring/Shackle Removed
Photos of the shackles removed, the front pins came out easy. Removed the outside nut and then unscrewed the bolt/pin. The rear pins were removed by, nuts and washers removed, side plates removed with drift and hammer (as 61K10 suggested), then the pins unscrew. Got pins out except for one that turns and then gets tight, it is on the right side.
The photos show the rear pins being removed.
Les
aotte1 is offline   Reply With Quote
Old 12-11-2015, 08:44 PM   #177
aotte1
Loaded ready to go to be soaked tomorrow. A big milestone in project.
Used the trailer winch to load frame partially on trailer, then used engine crane to move cab onto the frame sitting on trailer. Next winched both up all way onto trailer. First part of loading used dolley after front axle removed. Then moved the frame on 2x8's the rest of the way.
Dually truck bed loaded also under the bed sides, and trailer box full.
Old 12-11-2015, 11:09 PM   #178
61K10
61K10's Avatar
the stubborn pin should come out after you soaked the frame.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-12-2015, 12:49 AM   #179
_mg
Active Member
_mg's Avatar
Congratulations on the milestone Les!
_mg is offline   Reply With Quote
Old 12-12-2015, 10:56 PM   #180
aotte1
61K10, dropped off the truck parts to be soaked/dipped this morning, they use a non-acid process. Hope it does make the last front spring pin ease to remove, once I get it back. It will be their 4 to 5 weeks or maybe a little more. The process is a little slow but works great, and gets in all the dark places.
Do you know of any photos showing the rear spring pack in stock condition for a '64 K10. Pretty sure mine were modified with the addition of additional springs.
MG - thanks, I will be working on the springs and axles next few weeks.
Les
Old 12-13-2015, 02:09 PM   #181
61K10
61K10's Avatar
Les---post a pic of your spring. mine has 2 leafs added to the stock spring. will post up a pic of mine.
1961 chevy K10
Old 12-14-2015, 10:26 PM   #182
aotte1
61K10,
Thanks,
Photos of front springs.
Note: the sway bar is part of the '78 Dana 44 upgrade
Les
Old 12-14-2015, 10:33 PM   #183
aotte1
Photo of rear springs, looks like two leafs added, and not sure about the bottom helper spring. The two springs that look added seem to be wider. The last photo shows a close-up of the top spring curling around/thru the shackle. Would like to restore the original springs if they will work.
Les
Old 12-16-2015, 04:30 PM   #184
61K10
61K10's Avatar
Les---first pic is my ft spring. the second is the rear spring. my stock springs are 6 leaf. I thank they had 5 leaf also? the 2 bottom rear leafs are a add on, like a over-load. with no weight in the bed they don't touch the stock spring pack.
1961 chevy K10
Old 12-17-2015, 12:01 AM   #185
aotte1
61K10,
Thanks for the photos of your springs front and rear. Do you have a photo of your rear spring shackle close-up, as to how the springs fit it.
thanks,
Les
Old 12-17-2015, 12:09 AM   #186
aotte1
A few more photos of the rear spring attaching hardware and spring block.
Next step is to disassemble the axles and have them steam cleaned.
Old 12-17-2015, 01:02 PM   #187
61K10
61K10's Avatar
Les--couple of pics. Don't know if the plate on the axle pad and lift block is stock. might be able to zoom in on the frame.
1961 chevy K10
Old 12-17-2015, 09:15 PM   #188
aotte1
61K10,
Thanks, photos help.
Les
Old 12-22-2015, 09:25 PM   #189
aotte1
Cleaning the Dana 44 Front and 12 Bolt Rear Axle
Today got around to steam cleaning the front and rear axle housings and certain parts. Mostly good news and a little worn-out news. The Dana 44 front which I thought was a '78 and looks like it is a '79 per housing code. Cleaned for a little more then an hour at about 180 degrees, lots of steam. Did a really nice job on getting the inside clean!
The 12 bolt rear axles are toast, getting new ones. The Dana 44 front axle is getting all new ball joints ( upper were good and lowers worn/loose) and axle u-joints (ok in one direction and gritty in other).
Took the ball joints out first this morning, like others have reported here, removed the nuts, and broke the knuckle loose with ball joints still installed from axle tube, by hammering on axle tube with snap-on dead blow hammer. Some came loose very easy with additional blow to ball joint end. One needed more force, allowing for F_ _ _, frustration to be released Then used ball joint press to remove them from knuckle. Pretty easy with tools needed, 15 to 20 mins.
First photos parts loaded going to area for steam cleaning, last two bad axles where bearing has damaged it.
L
Old 12-22-2015, 09:34 PM   #190
aotte1
More Axle Cleaning and Findings.
The hub assemblies are a little worn on the bottom just in from the threads, thinking about rotating the top to the bottom to give good surface to bottom of bearing where max load is. Good idea???? First two photos are of this area on hubs. Other photos of parts cleaned.
Old 12-22-2015, 09:43 PM   #191
aotte1
A Few More Axle Cleaning Photos - Sway Bar/Spring U-Bolt top Plate
The sway bar bushing are really dry and coming apart, need to check the inside part to see how bad that area is. Have not found a replacement rubber part, may have to go with other material. Any suggestions on what can be used? Sway bar has some of the original casting slag still on it.
Old 12-22-2015, 09:52 PM   #192
aotte1
Front Axle Backing Plate/ Caliper Bracket
Photos of the back plate and caliper bracket, show small areas of gold cad. plating on the front and back. The photos do not show the color good of the old gold colored cadmium plating. It is also present inside the bolt holes.
Not sure about the black paint on top of cad. ??? part of axle black-out at Dana, part of truck black-out at GM, black spray paint by previous owner ( could be but does not look like it, more like a factory application). Did not look to see manufacture emblem stamping on bracket.
Note: for reference this is a '79 Dana 44, using on the '65
L
Old 12-22-2015, 10:08 PM   #193
aotte1
More photos of axles parts later. One of axles housings back in garage.
Les
Old 01-08-2016, 11:42 PM   #194
aotte1
Rear Spring Shackle
Working on restoring the rear springs and found one of the shackles is worn a lot. Looking to find one from the not very common rear leaf spring trucks. Researching which model trucks had them. Do know the front spring parts were used on several different models.
Old 01-08-2016, 11:44 PM   #195
aotte1
Another photo using IPad only one photo at time
Old 01-08-2016, 11:44 PM   #196
aotte1
Photo....
Old 01-09-2016, 09:59 AM   #197
_mg
Active Member
_mg's Avatar
L
Hi Les, just catching up on your build. How was it to remove the front axle gear carrier?
Old 01-09-2016, 03:29 PM   #198
61K10
61K10's Avatar
I see you getting some free. LMC does have them. might buy a set as mine might be bad also.
1961 chevy K10
Old 01-10-2016, 03:29 PM   #199
aotte1
MG,
It was all pretty easy. Did both apart and parts labeled for Dana 44 and 12 bolt in a little less then 2 hours.
It was not hard, all the hubs stuff came out easy, and carrier was not hard. Used impact to get pinion nut loose. It was kind of tight, however, gave up and came loose after a bit.
Now putting Dana back together will likely take some time to get it adjusted?? Maybe lots of trial set-up, this is first Dana 44.
Les
Old 01-10-2016, 05:19 PM   #200
61K10
61K10's Avatar
Les--are you gonna use the org ring and pinion? pinion bearings? there are shims under the pinion bearing races to adj the pinion and behind the carrier bearings. put back together the same if using the org R&P. the 44 isn't fun if replacing everything.
kimble
1961 chevy K10
