12-21-2015, 12:36 PM | #1 |
Aftermarket crank pulley smaller than OE?
I got a couple pulleys to dress up the front of the engine a little, and the crank pulley is smaller than the original. Is this going to cause a problem?
12-21-2015, 07:07 PM | #2 |
Re: Aftermarket crank pulley smaller than OE?
Anybody?
12-21-2015, 07:43 PM | #3 |
They should work fine as long as all the grooves line up with the old pulleys.
A smaller diameter crank pulley might speed up the other pulleys depending on there size. But you'll never notice the differnce.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-21-2015, 07:44 PM | #4 |
Your accessories will run slower than with the stock crankshaft pulley. The rule is larger accessory puller the slower the accessory will run, conversely the smaller the crankshaft pulley the slower. You can do the math if you want, it is a matter of ratios between the drive pulley and driven pulleys.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
12-21-2015, 07:47 PM | #5 |
I gave wrong advice........................
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 12-21-2015 at 09:48 PM. |
12-21-2015, 09:33 PM | #6 |
Nope, a smaller pulley equals less surface on the diameter of the pulley, less surface means a slower belt and accesorys turn slower
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-21-2015, 09:46 PM | #7 |
You are correct, where is my brain tonite....
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
12-21-2015, 09:46 PM | #8 |
reread that you're correct,but only if you're talking main pulley diameter. If the accessories pulleys are larger it slows them down
12-22-2015, 08:42 AM | #9 |
Thinkin an typing don't work sometimes.
it will slow it down the belt. But like I said you won't notice it.
12-22-2015, 08:49 AM | #10 |
Worst case is if the RPMs are low at idle and some accesories like heater fan or head lites on you might see the alternator light flicker if you have idiat lite or the needle might show discharge on a gauge..
