12-22-2015, 09:03 PM | #1 |
air compressors?
What is the difference between the ridetech air compressor and the viaair 450 ? Which is better? I bought the ridetech just wondering if Iade the right choice
72 gmc 1500 with leafs . |
12-23-2015, 12:03 AM | #2 |
Re: air compressors?
What RideTech compressor in particular did you buy? All are good choices, so I am sure you made a good decision. What size tank are you running?
Posted via Mobile Device |
12-23-2015, 12:39 AM | #3 |
12-23-2015, 12:41 AM | #4 |
Not sure on tank but most likely a 3 gal.i am trying to get everything before I install it.waiting on air over leaf kit,c notch and flip are done.
12-23-2015, 10:15 AM | #5 |
The VIAIR 450C will be faster, as well as the 444C and 400C. That compressor is built by Thomas, and is a great compressor that will last you many years like the VIAIR. The Thomas is just a little slower than the VIAIR's. Not to say it is bad at all.
You made a great choice, and if you ever want more speed, you can add another Thomas or VIAIR compressor. Filling a 3 gallon tank will be Ok with the Thomas. If going with air on all 4 corners, then I would look at a 5 gallon, and a second compressors. But start with what you have already, and go from there. |
12-23-2015, 11:46 AM | #6 |
Thanks for the help ,glad to know I am on the right course and that was my plan ,to add more if needed
.it is mostly for comfort not for play.thank you. |
12-24-2015, 01:32 PM | #7 |
The Thomas comps will fill a 3gal tank from zero to 150psi in 6mins. The Viair's would prob be faster. I recall there was a difference between the Thomas & Viair in the 'duty cycle' when they ran.
12-26-2015, 04:47 PM | #8 |
I searched everywhere I could and found almost no info on it . I returned everything I ordered from ridetech and gonna go with viair dual setup.
12-26-2015, 10:18 PM | #9 | |
- Travis |
