12-26-2015, 12:06 PM | #1 |
Opinions or ideas needed
I've got my new to me 205 installed, and now I need to figure out just what to do with the drive shaft. The way it sits right now, it's going to hit the cross member that housed the old carrier bearing. The way it sits, it's about a 12 degree slope from the tailshaft to the pinion on the rear end. I figure I have two options, 1 would be to lower the cross-member holding up the tcase, or 2 just modify the cross member to provide some clearance. Any ideas of what I should do would be greatly appreciated.
12-26-2015, 03:10 PM | #2 |
Re: Opinions or ideas needed
Clearancing the crossmember is going to be a whole lot easier than lowering the t-case.
You should easily be able to clearance and reinforce the modified area on the cross member. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
12-26-2015, 03:24 PM | #3 |
That was my thought too. Thank you Brad!
12-26-2015, 03:52 PM | #4 |
KEEP ON TRUCKIN'
Some type of driveshaft loop might work.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
12-26-2015, 04:23 PM | #5 |
I skimmed through your build thread and was trying to find where you mounted your engine. Would be a good time to move it forward before the drivelines are built. I know the t-case is already done, but if you convert the rear of the case to a fixed yoke it will all clear without frame mods.
12-26-2015, 05:25 PM | #6 |
Fixed yoke will fix all your problems
12-26-2015, 08:08 PM | #7 |
I agree with going to a fixed yoke on the rear of the t-case. It will shorten up the overall length of the t-case, plus it's what these trucks came with anyways.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
12-26-2015, 08:59 PM | #8 | ||
I was thinking about looking for something like that today.
Thanks all!!! |
12-26-2015, 09:07 PM | #9 |
How will a fixed yoke change the centerline or angle? The DS will hit that crossmember regardless unless there's a huge lift.
The carrier bearing center would be what 3-5 inches below what it is in the pic if it was still there? My guess is something has been changed and the rear of the TC needs to come way down. Last edited by franken; 12-26-2015 at 09:16 PM. |
12-26-2015, 09:25 PM | #10 |
All you need is a rear output shaft, seal retainer, and seal. 100 bucks on ebay.
12-26-2015, 09:26 PM | #11 | |
12-26-2015, 09:28 PM | #12 |
I think I'll start looking. If I'm going to do it, I only want to build the driveshaft once LOL
12-26-2015, 09:35 PM | #13 |
And a nut with a flange or a washer
12-26-2015, 10:51 PM | #14 | |
12-27-2015, 02:08 AM | #15 |
Since you moved the engine forward already, even with the fixed yoke you will have notch the member....just not nearly as much. Your drive shaft will probably need to be at least a 2.75'' tube minimum, being a 1 piece
12-27-2015, 01:16 PM | #16 |
I'll try to snap a pic when I get in the garage today.
That's what I was thinking. I'm going to take it down to the local driveline shop to have them evaluate everything, but they want the body and everything on it so they can measure it correctly. |
