12-14-2015, 11:26 PM | #1 |
SWB 4x4 Collector
Gas door opinion
Guys I need some opinions on what gas door you would choose between these two, keep in mind the truck will have both upper and lower trim. I like the curved one as i havent seen it used before but the rectangle one might fit the shapes of the marker lights better. Thanks Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-14-2015, 11:35 PM | #2 |
Re: Gas door opinion
I like the curved one, but your truck is raised so the rectangle could be a lower option to reach up to for refueling. I getting older so you to add in these factors and I'm not that tall.
Derek |
12-14-2015, 11:55 PM | #3 |
Neither. 88-98 Silverado/Tahoe/burb.
Looks excellent on fleets too. If I had to pick from the above... The yellow one.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-15-2015 at 12:03 AM. |
12-15-2015, 12:05 AM | #4 |
SWB 4x4 Collector
Put one on one of my first trucks. Didn't look bad, but trying something new.
12-15-2015, 12:06 AM | #5 |
The one you call "curved" is my choice. I fits the lines of the truck better. The square one would fit a 60-66 or 73+ better IMO
'68 C10 SWB '85 K30 Blazer |
12-15-2015, 12:39 AM | #6 |
BlahBlahBlah
I like em both. But to me ... the gold one might edge it out a little because the corners match the edges and angles on the truck better.
12-15-2015, 12:49 AM | #7 |
rectangle on a flat surface, by far. I think it would look better fwd of wheelwell, in the 73+ stock location, but I'm assuming that's not gonna work based on tank location. Another option is the marker light filler approach. I think the curved surface approach will detract from the curved body line in that location personally. All look good though.
12-15-2015, 09:32 AM | #8 | |
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
12-15-2015, 09:48 AM | #9 |
Take a look at the following after market door.
http://www.yogisinc.com/index.cfm/pa...d/prd13954.htm. They have a template that you cut out and match against your truck and there is a spot that is a match. I don't know if it will fit between the moldings - you will have to check. http://www.haganauto.com/v/vspfiles/...20template.pdf |
12-27-2015, 10:45 PM | #10 |
I like the curved one. What did it come off of?
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
12-27-2015, 11:16 PM | #11 |
SWB 4x4 Collector
IH travel-all, here is was mocked in before pulling out my low spots.
12-27-2015, 11:51 PM | #12 |
I like it!
12-28-2015, 01:28 PM | #13 |
It looks like it's higher on the body than I envisioned mine would be is that because of the curves you had to work with or is there a benefit to filling the tank?
You running a square body blazer tank? |
12-28-2015, 01:50 PM | #14 |
Great job on the install!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-28-2015, 02:29 PM | #15 |
It had to go high in order to intersect the curve, because the door was curved, and the door was curved because sometimes its cool to do it the hard way - with a curved door.
Just FYI, when I did some research on keeping my triple tanks I found tha Ford vans had a dual tank option with mirrored doors, so you can harvest a door from each side and they match. Wouldn't be curved though, and only important if you're doing both sides.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-28-2015, 02:37 PM | #16 | |
12-28-2015, 04:57 PM | #17 |
Just to throw it in the mix here is a 95 door in my 69 fleetside. I didn't care for the square ones at the time I did mine.
69 Chevy 4x4 383 Power |
12-28-2015, 07:42 PM | #18 |
SWB 4x4 Collector
Nitis, it's because I had to lower my bed cross members about 2" on my bed so that my cab matched my bed in height. My truck is on a c30 c&c chassis which is completely different from the c30 and down frames. With the 2" drop, the filler door would have been almost straight into my tank. Rather than having to spend 20 min clicking on and off at the pump, I went with this door, which I had never seen used before. Should be able to still use the blazer fuel neck from our generations and yes, I am using a modified 31 gallon 73-91 blazer tank.
12-28-2015, 09:51 PM | #19 |
SWB 4x4 Collector
Paint dried....pre body work.
12-28-2015, 09:53 PM | #20 |
Moderator
Nice work!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
12-29-2015, 01:03 PM | #21 | |
Lookin' good
12-30-2015, 12:48 AM | #22 |
BlahBlahBlah
Turned out great, I really like it. You couldn't really go wrong either way.
