Are you guys as disappointed with 07 and up chevy trucks as i am?
I have always been into chevys but man between my 08 silverado and now my 09 tahoe these trucks are a let down my 08 ran like crap gas gauge didnt work right the blower motor would just come on randomly even when the truck wasnt running among other issues now my tahoe has the disintegrating dash and it takes forever to fill up with gas due to the evap problem are these common problems with you guys also??
Re: Are you guys as disappointed with 07 and up chevy trucks as i am?
No; I haven't experienced any of those.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I dont have any that new so Im just reading and learning.
on my 09 tahoe the rear passenger side window has the elements in the glass for defrost but it doesnt work when i run the rear defrost does anyone know anything about this issue?
Both sides or one side only?
The reason I ask is you may be seeing the grid antenna, not a defroster grid. Some models have a "diversity antenna", for OnStar and satellite radio, in the quarter glass. If that is the case then the grid should look different LH vs RH (or no grid in the opposite side). K
One side only
Posted via Mobile Device |
Just like any vehicle they have there share of issues. The dashes do seem to have a cracking issue on the earlier models. On the defrost I'm not sure, alot if the connectors seem to break off of the glass with the opening and closing of the glass. Do you know what evaporated code you have? Sounds like you need a evap vent solenoid, the ac delco ones have a updated design and require a jumper harness when installed. When it comes to fuel system OE parts are worth the extra $$. If you can pull codes out post up what you got. Hope this helps.
1979 ![]() 1996 Silverado x-cab "the daily" |
I miss this truck.
Actually, I've been very pleased with my '08. I didn't buy it until it had 142,000 miles on it, but it's done really well for me.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
Yah - I don't think that's a defroster grid. There isn't a defroster in the side glass (back glass only).
K
![]() Join Date: Oct 2013
2010 silverado, with 5.3 and 6 speed auto, short bed, really like it, no problems at 54K miles. Great driver. Especially like the 6 speed auto, with kick A... First gear. It gives Hemi chargers a run up to legal speeds.
Les |
Parts and more parts
Just like the statement above. 2011 GMC SWB, lowered 5/7 and running a 5.3Kooks headers, Magnaflow dual exhaust, 6 speed auto and 3.42 gears. I have 140,000 miles on the truck and it runs pretty damn good,with an EFI Live tune on the engine and tranny. In cold weather the mileage drops off a little, but if driven responsibly I can put down 20 MPG on the highway.
Frank |
#12 | |
Happy to be here
![]() Join Date: Mar 2000
Another issue these have are the exterior door handles are plastic and commonly break. I have replaced several of those. I quit buying GM handles, and tried aftermarket the last time. I paid 19.95 on Amazon for a GM replica and it looks great. Normally I would only buy GM parts, but I figure these cant be any words than the GM junk. Power folding mirrors are another poor design. Again, between me and the in-laws we have replaced several. My biggest peeve with this gen of GM trucks is the headlight design. On my wifes 2007 Denali you pulled a L shaped pin and the head light swung out for access to the bulbs. Freakin ingenious idea that made access to light bulb change so simple you could do a change in the auto parts parking lot. Have you tried to change a headlight bulb in any 2007–2013 trucks? You better You Tube it before you get started. It is easily a 2 hour job and be assured you will be cussing GM design engineers about 15 minutes in. If you have a headlight bulb go out, heres a couple of very valuable tips. First off, replace both low beams at the same time. You have already done 90% of the work getting to one, you should do the other at this time too. Three times now I have had the second one fail with in a very short period. Another tip you might cringe at, but you will appreciate if you do have to do this twice. There is a long tab at the bottom of the headlight assembly that requires you to remove a portion of the fender liner to access. Once you loosen the bolt on that tab, grab the headlight firmly and twist and tug on it. This will snap that lower tab off. As much as I hate doing things like this, that tab is not necessary to hold the light assembly tight, and reduces the install time by 15-20 minutes. Yep, I am disappointed in certain features of the 2007–2013 GM trucks. I hope they have been improved before I buy again.
#13 | |
Frank |
^ I agree, takes me maybe 10 minutes to do both. I don't really care to own one, not because there crap but just cause there to new for me lol.
#15 |
I am not sorry that I purchased mine. It is leaps and bounds over the 91 that I was driving on a daily basis. My plans are to keep it and upgrade the engine when it reaches a point of no return.
Frank |
#16 | |
Happy to be here
No worries though, my nest truck will have a new set of GM problems. I'm looking at the 15 or 16s already.
#17 |
I miss this truck.
Yep. That's how I felt replacing the bulbs on my wife's Acadia, too.
#18 |
Yes disappointed in that body style era! Know of several around '10 that had major motor internal issues before 70k miles. Our '07 (first yr of new style) was a really good truck mechanically but cheesy interior...seats very uncomfortable, plastic reclining handles stripped out, of course the cracked dash, & carpet worn in spot by throttle petal by 25k miles. New transmission at 150k; no motor issues & sold with 190k miles on it. But spent many months & several hundred dollars trying to get ck engine light & traction control lights off (made shift hard from 1 to 2 & that prob what eventually got trans)...all to eventually be corrected by new ground cable end. So we won't get another truck of that era; found a 2006 with 45k on it for our latest "new" truck!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#19 |
and a few others
Am I the only one who hates the square wheel-wells?
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#20 |
Boosted Member
Yes.
![]() I really liked my 2013 Denali HD, and I *absolutely LOVE* my 2015 Denali HD. The new interiors are awesome....solid powertrain...good looks...smooth power delivery and good ride. I do know that the 07-up tend to be rust buckets. I've seen so many with the wheel arches rotted out on truck less than 10 years old. That's my only gripe.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#21 |
Windy Corner of a Dirty Street
I can't stand the 2007-2013 GMT900's. Ugly with very poor body and interior quality...powertrain is fine though. The 900's practically changed me to a RAM fan. Although, the new 2014+ K2XX trucks are much better than the 900's by leaps and bounds. When you look back the GMT900's were designed and launched during GM's darker broke days and it shows.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#22 |
That is why I purchased the GMC model and not the Chevrolet.
Frank |
#23 | |
Boosted Member
#24 |
![]() Join Date: Mar 2013
I've been very happy with mine. My only gripe is the cylinder deactivation.
#25 |
![]() Join Date: Aug 2005
I work for a large utility fleet, and we liked the 900's, particularly the 2011-up HD's. In our 800 series GM trucks, we used to see the upholstery wear very quickly, instrument panel gauge failures, and lots of popped spot welds and sheet metal cracking in the cargo boxes when we mounted large tool boxes and other equipment. The 900's (base WT models) had better seats, no instrument panels problems, and the cargo boxes seem to be a lot stronger. Did notice the top horizontal part of the quarter panel (bed rails) to dent real easy though. 2011 up HD front suspension is the best in the business and the chassis is very strong. Interesting that the new HD's have the same chassis, suspension, and inner cargo box as the 2011-up HD's.
Don't get me started on our Super Duty's...........
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
