Old 01-01-2016, 03:31 PM   #776
swampbog
swampbog's Avatar
Re: 1976 Square "Simple Green"
Originally Posted by RodsGreen10 View Post
Looks like this. So you have a visual. The batter terminal and the terminal from the junction block connect on the same stud on the starter. So how in the hell is connecting direct to be battery different that how I have it hooked it is getting the same voltage it is tied into the battery?
http://www.67-72chevytrucks.com/vboa...1&d=1451667253
I missed this post all together.
I thought your battery wire was going to the junction block and then down to the starter, not the other way around.
I'm no electrical engineer or wiz kid either, so is it possible that when your cranking the engine over that the starter is interrupting the power going to the junction block? As in is it sucking power (amps or volts) and keeping it from the junction block?
Then again, that wouldn't explain why it's stalling out after it starts. unless it's then getting full power and it "rests"?? God, I feel like I'm talking out of my ass
If you do the test of running dedicated wires to the battery and it works, verify that it's not because it needs both. If it does need both I would run a wire to the junction block and then from the block to the starter.
swampbog is offline   Reply With Quote
Old 01-01-2016, 03:50 PM   #777
RodsGreen10
RodsGreen10's Avatar
That's how it came from the factory. I just used the junction box as the power source for the FiTech.
RodsGreen10 is offline   Reply With Quote
Old 01-01-2016, 03:59 PM   #778
RodsGreen10
When I get back home I am going to run it straight to battery power and ground and test it. We shall see...
Old 01-01-2016, 04:00 PM   #779
swampbog
swampbog's Avatar
Sure but the factory didn't have to worry about electronics. Think back to the old factory radios that came in those year trucks.
I'm not saying that it's the problem, I'm still thinking grounding is the problem.
Just brought it up so you can double check it and in case we do get an electronics guy in here and maybe he can say something for sure. I don't want you have problems down the road after you spent all this time fixing this issue.
Plus look at it this way, if you need to run the battery cable to the junction block. You can run it along the fenderwall and down to the firewall all in black sheathing to give it a cleaner look. (trying to put a positive spin on it )
Old 01-01-2016, 04:02 PM   #780
swampbog
swampbog's Avatar
I really, really, hope that this fixes it.
Fingers crossed
Old 01-01-2016, 04:09 PM   #781
ray1970
Ray here.
Mine would stall about two minutes after I removed the charging cables at idle.
I don't think this has any thing to do with yours.. I believe you are stalling shortly after
the start?If it starts?
Im heading out back to swap body's than maybe the chip to see if mine idles better
After I take the **** battery back out...
Maybe I will do the chip first!
I really just need to go home......NOPE....wife is sewing don't want to even enter the house when that's happening.
Ray.
ray1970 is offline   Reply With Quote
Old 01-01-2016, 05:39 PM   #782
RodsGreen10
Hey hey hey. I will have you know I have a top of the line 76 Silverado with all the bells and whistles lmfao. I hear ya man yes it wasn't setup for all this hitech stuff. And you read my mind about how I would route the direct battery connection.
Old 01-01-2016, 05:40 PM   #783
RodsGreen10
Fingers crossed
Same here man.
Old 01-01-2016, 06:39 PM   #784
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Anxiously waiting to see if the direct wires do the trick.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-01-2016, 07:38 PM   #785
ray1970
Ray here.
After 28 posts can I start calling you RG10 ?
But in all seriousness I have not read this thread post to post... I bore easily.
Have you done a voltage draw? to see if that's what your working against.
and not some built in problem..It can happen....
On the controller.....Not that's its the best meter for this.......
Go to large gauges... click down to battery voltage and bring that up....
Try to start it and see what you get..
you my have already done this...I don't know that it would mean anything. But what the hell.
Ray.
Old 01-01-2016, 09:24 PM   #786
RodsGreen10
It will be tomorrow evening.
Old 01-01-2016, 09:25 PM   #787
RodsGreen10
Originally Posted by ray1970 View Post
Ray here.
Ray.
Yes you can.
And yes I have.
Short so you don't get bored. Lol.
Old 01-01-2016, 09:53 PM   #788
Crushkrew
Crushkrew's Avatar
I really hope adding direct connections to the battery positive and ground solves your problem...
I am no electrical engineer and I know you are focused on the voltage. ...but the power formula P=IxV...tells us that even with an equal voltage of 10.5 volts at the starter and the distrobution block...that if the computer or injectors are not getting enough Power. ..watts...due to not being able to draw enough amps...then no go....looking at your diagram of how you have the positive wired...I am assuming that you are using a heavy cable to the starter and a light wire to the distribution block...and we all know that when cranking that the starter can draw hundreds of amps....and maybe that is not allowing the necessary Power to get to the distribution block...and maybe a direct connection to the battery will....
I keep trying to apply the old fire hose analogy..but can't seem to articulate it....just trying to help eliminate items with you....
I do recall when I was running am old powerjection system on another car...having similar issues that were solved when directly wired to batt + & -...
I hope it works for you (and the rest of us with units on order)...so you can stop pulling your hair out....
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510
Crushkrew is offline   Reply With Quote
Old 01-01-2016, 09:58 PM   #789
Crushkrew
Crushkrew's Avatar
Oh man...swamp already said what I just said....even the bit about not being an electrical engineer.....
Old 01-01-2016, 10:02 PM   #790
ray1970
Smile Re: 1976 Square "Simple Green"
Ray here.
Can you shorten up that last post i barely got to the end.
Ray.
Old 01-01-2016, 10:09 PM   #791
RodsGreen10
OHMs law lol taking me back. I will test it out. But I still think it is some bs that I have to buy a ground wire and ground it to the battery. The FiTech does not have a ground. They are counting on the system to ground out by the mounting studs. So as a added precaution they need to ad a dedicated ground wire in the system. As a customer I shouldn't have to be doing that. If I do this and it does not fix it man o man am I going to be ****ing mad as dammit!!!
Old 01-01-2016, 10:15 PM   #792
Crushkrew
Crushkrew's Avatar
Ray here.
Ray.
Sure...add wires...tell us if it works...
Old 01-01-2016, 10:17 PM   #793
LostMy65
LostMy65's Avatar
A read on fuel line/hoses.
http://www.hotrod.com/how-to/engine/...ce-fuel-hoses/
Old 01-01-2016, 10:17 PM   #794
Crushkrew
Crushkrew's Avatar
I would start with just stringing an extension for the positive to battery...then negative...??
Old 01-01-2016, 10:25 PM   #795
RodsGreen10
I will test it tomorrow and let everyone know. I am getting tired of dealing with this. I want to move on to my next install my tranny. Then my c notch. Then interior. And maybe just maybe if every goes my way which it probably won't a supercharger hahaha!!
Old 01-01-2016, 10:28 PM   #796
RodsGreen10
I will say this never had this much issue with a carb the MSD or the Holley. But with saying that I still like the FiTech the best out of all of them if I can get this ***** to fire up cold I will be golden.
Old 01-01-2016, 10:30 PM   #797
Crushkrew
Crushkrew's Avatar
Maybe you could wrap a nitrous bottle warmer around it...😂
Old 01-01-2016, 10:36 PM   #798
RodsGreen10
Thinking outside the box. I like it! Lol.
Old 01-01-2016, 11:28 PM   #799
Crushkrew
Crushkrew's Avatar
Just came across this on a corvette forum....I know u have good grounds...just more data...
"...... After all was running great, I started having issues starting the car when it was cold. I noticed that the display would go blank or go blue when I tried to start the engine. After talking to Ken, he said that was a ground issue. After looking around for the grounds, most had been removed (exhaust, starter to engine). Since the TBI unit uses the engine as it's ground, the injectors weren't firing. I went ahead and added some engine ground straps and it started right up. Lesson learned: Make sure you have good grounds!....."
Old 01-01-2016, 11:39 PM   #800
RodsGreen10
Yep swamp posted that. That is why I ordered up a set of ground straps. I think I need more grounds honestly. I feel it is more of a ground issue than a power issue. Thanks everyone for helping. We will get this figured out so this does not happen to others.
