1972 Roll "cage" and Hardtop: what do I have?
I started a build thread but thought I'd also ask the question here:
I'm starting my modern drive-train build with what appears to be a very original 1972 Blazer... my question concerns the top and roll bar... what do I have? It doesn't look quite like other double walled tops I've seen and I've never seen a roll bar like this... BUT the inner part of the top appears factory molded to fit around where the roll bar attaches at the windscreen header. Is this factory/rare/desirable? (I had planned on no cage and keeping the top off most of the time in favor of a soft top). But if I have something really unusual I may keep it... Thanks! |
Re: 1972 Roll "cage" and Hardtop: what do I have?
I don't believe it is factory. It looks like a custom built roll bar. My top has those cutouts/indentations where the roof bolts to the windshield frame. I like the idea of that roll bar seems like it would do the job in the event of a roll over.
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
Ah, thanks! I didn't think about the possibility that the indents were in the top anyway! Does the top look stock?
![]() Join Date: May 2011
Appears to be a correct double wall top
Are you sure it is a 72? Why I ask is your rear view mirror is mounted to the windshield frame in 72 they were glued to the windshield and sometime in 72 they went to a single wall top. I just listed a 72 that I am parting out in the for sale section it may have a picture of the rear view mirror I don't remember LOL.
Thanks for the info on the top!
Actually I'm not 100% certain it's a '72 though that's what all the paperwork says... will investigate further. Thanks again! |
I agree, it's a factory double wall top.
I also agree on that being a nice roll bar. It looks like it will add some level of protection to the windshield frame.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Found the VIN on the frame and it's definitely a 71... thanks for the info!
I wouldn't count on those bars running to the windshield frame adding much roll-over protection. The windshield frame will still collapse and those bars will end up in your lap.
I also don't recommend keeping those bars connected to the windshield frame when the top is removed. Blazers naturally flex through the door openings, and those bars will put a lot of stress on the thin windshield frame, eventually fatiguing the metal and tearing free. I did this years ago thinking it was a good idea, and that is what was happening. The only time you can connect a roll bar directly to the windshield frame is when you have completely caged the Blazer to prevent body flex. |
