Old 12-30-2015, 11:33 PM   #926
mjensen
mjensen's Avatar
Re: 69 GMC "Ol' Blue"
Originally Posted by 7dee2 View Post
Ruh-roh, I'd say relocate it by moving it back or up out of the way (cab clearance?). You could possibly remove rotate 180 and bolt it up to the bottom rail. I'm assuming you are going to run a one piece rear drive line and remove the carrier bearing stand off?
Yeah, I've already removed the carrier bearing stand off, but then my water filter on the air compressor decided that it was done working in the cold and broke, so I couldn't remove the rest of the cross member. I'm taking tomorrow off, so I'm going to replace that and get back to disassembly on the cross member. I'm also keeping my eye out for a fixed yoke, but I'm not going to hold my breath on that.
Originally Posted by mcbassin View Post
Awesome work on the Transfer case! Looks better than new.
Thanks Mike!
Originally Posted by Dieselwrencher View Post
Great work! The tcase looks great. Funny, I never have had a clean 205 to take out of a truck on a build! They always seem to be caked in grease, mud, and gunk.
Haha! This one was pretty greasy. Funny thing is that the guy that brought it home for me loaded it in the back seat of his Fusion because his trunk was too full. I bet that was a aromatic ride home
Originally Posted by mud.man.rj View Post
T case looks to good to get it dirty again..nice work, if the rest of the truck turns out like the t case, wow.
Thanks mud man! Well, does parking lot dirt count? I hope it turns out...It's kind of hard to screw up a T Case haha.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-02-2016, 01:05 PM   #927
mjensen
mjensen's Avatar
Well, I haven't been able to get much done over this extended weekend. On Thursday, my regulator on the compressor decided it didn't want to play anymore. Finally got that repaired yesterday and was able to get the last two rivets out of the crossmember. You know, it's amazing to me how much power the old regulator/oiler was robbing from my air tools! Now with just the regulator, this thing zings!!!
Ok, for anyone tagging along I have a question....do I really NEED this crossmember? I think the only real reason it was there before was to hold the carrier bearing, but I'm going to be running a one-piece driveshaft now. The only other thing I can think of is emergency brake cables and exhaust hangers were attached to it. Let me know what you think.
Mike
Old 01-03-2016, 12:45 PM   #928
mjensen
mjensen's Avatar
Tiny update here. Now that I have the 205, I can actually run the 4wd lever the way I originally wanted it.
Mike
Old 01-03-2016, 02:02 PM   #929
54belair
54belair's Avatar
Im not sure it would be required--but if its not in the way I think Id leave it. Frame rigidity is not a bad thing.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 01-03-2016, 02:26 PM   #930
mjensen
mjensen's Avatar
Well, it kind of is in the way. I'm just going to modify it to work somehow I think...
Mike
Old 01-03-2016, 04:55 PM   #931
mud.man.rj
mud.man.rj's Avatar
I would leave it, power is twist so I would just work some magic and modify it.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 01-04-2016, 12:14 PM   #932
7dee2
7dee2's Avatar
Nice job on the linkage Mike mucho bettero! IMO I would figure a way to run a crossmember in the area. Maybe get your rear drive line sorted and then revisit, if moving it back won't work think about cutting it out and then fab or source another.
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 01-04-2016, 07:43 PM   #933
mud.man.rj
mud.man.rj's Avatar
You could always consider moving it back a bit then may not have to modify it for clearance, or minimal.
5.0 4spd std.
7" lift w 35's.
Old 01-04-2016, 11:49 PM   #934
mjensen
mjensen's Avatar
So, the only thing about moving it back is that I only have about 1 1/2 - 2" before I'm going to run into issues with the bed mounts. I think what I'm going to do is get a piece of 4" round tubing to mount in the center of the crossmember to create somewhat of a loop. Then I should be able to mount it in the stock location. That's the theory bouncing around in my head anyway
Mike
Old 01-10-2016, 12:13 AM   #935
mud.man.rj
mud.man.rj's Avatar
The loop idea is what I would have done 1st, instant drive shaft safety loop also..
5.0 4spd std.
7" lift w 35's.
Old 01-10-2016, 07:53 PM   #936
mjensen
mjensen's Avatar
Yesterday, I was able to get the crossmember cut out, and my new clearance piece tacked up. I was going to try to finish it today, but just ran out of time.
I used my plasma to cut the pipe in half. I used the angle iron as guides.
I'm actually surprised by the fact that I was able to actually get it in half
tacked up!
Next up is to drill all the bolt holes and get this piece checked off!
Mike
Old 01-10-2016, 08:44 PM   #937
rgunlock
rgunlock's Avatar
Most excellent Mr. Mike! Looks like that will git'r done and look good doing it
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 01-10-2016, 09:14 PM   #938
mjensen
mjensen's Avatar
Thanks Rick! I think it's going to work, but I do need to clearance a little more I think. It looks like it may still hit.
Mike
Old 01-10-2016, 10:52 PM   #939
mud.man.rj
mud.man.rj's Avatar
Nice work..
5.0 4spd std.
7" lift w 35's.
Old 01-11-2016, 12:02 AM   #940
swamp rat
swamp rat's Avatar
I agree ^^, are ya gonna put a loop on the bottom or call it good?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-11-2016, 11:00 PM   #941
mjensen
mjensen's Avatar
Nice work..
Thanks guys!! I hadn't considered it, but it may be kind of cool. I need to see if I'm going to have enough clearance with the way that it is right now.
Mike
Old 01-12-2016, 11:36 AM   #942
7dee2
7dee2's Avatar
Nice work Mike!
Brett
Old 01-14-2016, 12:31 AM   #943
mjensen
mjensen's Avatar
Nice work Mike!
Thanks Brett!
Mike
Old 01-14-2016, 04:38 PM   #944
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! That's what I would have done to. If the lower half of the tube won't fit there, you could just put a strapat the front or rear hanging down and around to add a safety feature.
Ryan
1969 Chevy milk truck
Old 01-16-2016, 12:26 AM   #945
mjensen
mjensen's Avatar
Thanks! Yeah, I was thinking that too. I'm not sure I'll have much time this weekend to work on the truck, I have to do some homework so I can finish my degree by April. Oh yeah, I also have to tend to my new running/garage buddy
Mike
Old 01-16-2016, 10:03 PM   #946
mud.man.rj
mud.man.rj's Avatar
Cute garage buddy..
5.0 4spd std.
7" lift w 35's.
Old 02-11-2016, 11:36 PM   #947
rgunlock
rgunlock's Avatar
Hey Mike, any progress?
Rick
Old 02-13-2016, 12:38 AM   #948
mjensen
mjensen's Avatar
Hey Rick! I haven't made any progress on the truck. I've been pouring every spare minute into finishing my last 3 classes for my degree. I should be graduated no later than the end of March. After that, I will start working on it again. Of course I do have some new life goals which will slow down the progress on the truck, but it will at least start moving forward again.
Mike
Old 02-13-2016, 12:52 AM   #949
swamp rat
swamp rat's Avatar
I know the feeling, when i went thru my apprenticeship i crammed 4 years of schooling into 2 years to get it over with early, basically any free time i had was spent in the books..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-16-2016, 09:42 AM   #950
mjensen
mjensen's Avatar
Ok, it's time to start making some progress again on this. I'm happy to report that I was able to finish my degree! I now have my BS in IT. I've always had the BS part down, but now I have a diploma to go with it!
Things are probably going to start off pretty slow, as I need to get out in the garage and get it organized again. Then I need to start making an action plan of items that need to be completed.
Mike
