01-12-2016, 09:20 PM | #26 |
Equal opportunity joke ofender
Re: 66' c60 Parts for sale
Jimmy,
I will be trying to get more pulled off of it tomorrow. I tried to get the cluster out the other day with no luck. Am I to assume I have to pull all the switches and ignition out before it will come out? I could not get the bezel to unscrew on the ignition and did not want to tear it up. I will put you 1st in line for the items you mentioned. The door glass is no good as some clown used it for target practice, I am pretty sure it was not soft ray anyway. Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-12-2016, 10:01 PM | #27 |
If you pull all the other switches speedometer cable and the choke cable it may roll out. You may have to bend down the dash some at the bottom as the sheet metal will catch on the bezel. Some PB blaster and channel locks may get the ignition switch out.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-13-2016, 08:04 AM | #28 |
Did the grill sell? If not, what's the condition? Also if you can, price shipped to 15126.
Thanks. |
01-13-2016, 10:15 AM | #29 | |
The main grill has some surface rust but no pitting that I can see. The mounting brackets on the back side that are riveted on would need some attention. One side the rivets are gone and there is some minor pitting and break thru on the brackets. I have tried to show this in the attached pictures. I also tossed the bezels in my little blast cabinet and there was a bad spot on the bottom of each one. If it still interests you I would take $130 shipped to 15126 for grill, bezels and uncut harness. Richard
01-13-2016, 10:15 AM | #30 |
one more picture
01-13-2016, 10:50 AM | #31 |
Also had a request for better pictures of the roof clearance lights. 4dranch has 1st refusal on these at $40 shipped
01-13-2016, 01:09 PM | #32 |
How are the fenders and if they are good how much?
01-13-2016, 01:37 PM | #33 |
I have not gotten them off of the truck yet but there appears to be no rust. The passenger fender has some dents in it from running into something and the drivers side might have a slight dent from the door coming open too far (but I dont remember) Some pictures are attached. As far as price I am not sure yet until I see how hard they are to get off of the truck. Hope to get them off later today.
01-13-2016, 01:50 PM | #34 | |
I am pretty sure radio not original. The wiper arms and heads appear stainless but the tension spring is gone in one of them. Gotta clean them up a bit and will post pics of them. Richard
01-13-2016, 03:26 PM | #35 |
Richard the radio is a later model. Was hoping for 64 to 66 knobs. If you pull the three things in the pic and the speedo cable the cluster may come out. The wiring plugs in about center of the cluster and may be clipped to the pedal bracket. Unplugging it helps roll the cluster out.
Jimmy
01-13-2016, 07:46 PM | #36 |
Are the cab clearance lights sold?
01-13-2016, 07:58 PM | #37 |
4dranch has 1st refusal on them since he already asked me about them. I will give him 24 hrs to respond from when I posted the pictures then you are up.
Richard
01-13-2016, 09:36 PM | #38 |
Thanks for the pics and info on the grill. It's a bit rougher than I'd like unfortunately. So I'm going to pass.
01-15-2016, 08:56 AM | #39 |
OK no problem thanks for letting me know.
01-15-2016, 08:57 AM | #40 |
Mike,
You are up on the clearance lights. Have had no response from 4dranch Richard
01-15-2016, 08:58 AM | #41 |
Been busy at work and looks like I wont get the fenders off until tomorrow. Gotta try to beat the scrap guy coming in the morning and get him to start cutting at the back.
01-15-2016, 12:02 PM | #42 |
PB blaster will be your friend for the bottom bolt on fenders
01-15-2016, 12:13 PM | #43 |
Yea, I sprayed everything good the other day. Surprisingly everything other than the dash cluster has come apart easy
01-15-2016, 01:29 PM | #44 |
I wish I could afford that grill ,but TTT for you.
01-15-2016, 02:05 PM | #45 |
Alternator brackets available? thanks
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
01-15-2016, 06:03 PM | #46 |
yes but I am not sure if they are correct since it appears to be a newer 350 motor. Let me get some closer pics in the morning and I will post them to be sure they are what you need.
Richard
01-15-2016, 06:30 PM | #47 |
I found a few pics I didnt realize i had. Let me know if these are the correct alt. brackets.
Richard
01-16-2016, 05:01 PM | #48 | |
Only things I was able to pull for your requests were the wipers, headlight knob and a plug knob. The cluster just would not come out and my neighbor gave me until lunchtime today to get what I wanted off as he found someone else that wanted the drivetrain. The wipers are stainless but the pass side spring is broke which I assume is replaceable. Everything in the pics $25 shipped The other four knob looking pcs are what I think battery top plugs for filling.
01-16-2016, 05:06 PM | #49 |
The fenders cleaned up nice. the drivers side has no dents that I could see but it does have one very minor spot of rust on the front cup. The passenger fender has no rust but does have a few dents as shown. $100 each plus shipping
01-16-2016, 05:07 PM | #50 |
few more fender shots
