How are you storing your Blazer top?
Trying to get some ideas of storing my top this spring.
I'm thinking pulleys, and raising it to the rafters of our Shop. Anyone have pictures of what they have done? Also, can top be removed without help, just one person? Thanks! |
Boosted Member
Re: How are you storing your Blazer top?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Boosted Member
I screw some of these to the 2x4s that are under the top in that pic, and just roll it around my shop for summer storage. Makes for a pseudo work bench. lol.
http://www.harborfreight.com/movers-dolly-93888.html
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Here is a popular one that has gone around several times. Looks like a nice setup
http://67-72chevytrucks.com/vboard/s...d.php?t=159221 .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Wasted Income.... I wouldn't call it wasted
![]() They are kind of as I was thinking, love the wench. I'd like to design a track where I could move from One side of shop to other. Floor rollers are nice, but My 5 yr old might be to much for it. |
Boosted Member
Yea, i've been meaning to hang mine from the ceiling for a few years, and never seem to find the time to rig it up.
Here is how I take mine off. Takes me about 15-20min by myself. Then to store it I pull it up all the way to the rafters and can park under it.
This is why i like soft tops :P
![]() Join Date: Mar 2013
Mine has been hanging in the rafters for 10 years. I put it up there myself, but it wasn't easy. Used a combination of cheap pulleys which made it difficult and very sketchy and then used cheap ratchet straps as supplemental support. If I was to do it again or had plans of taking down and putting it back up I would purchase a cheap HF winch mounted to the rafter.
So here's my solution
![]() so I will be happy to yours advice .. |
![]() Join Date: Jul 2014
Welcome to the forum. You may want to put something under the top to get it off the ground and to keep the sides from spreading out with the added weight of the snow. They have a bad habit of developing cracks in the rear corners if not supported. When I've hauled a few, I take 2" x 4" pieces of wood that will reach from one side to the other (driver's side to passenger's side). I then attached shorter pieces of the wood to the ends in an vertical position. Here's may fancy representation. I______________I It keeps the bottom edges that sit on top of the bed rails from spreading.
#12 | |
This was a temporary solution because I had to move it, but I have ordered a new garage being built for spring 6,5 x 13 m so then I will hang it. |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here is version #2 of the winch set-up.
http://67-72chevytrucks.com/vboard/s...d.php?t=398105 Here is a short video clip of it working. https://www.youtube.com/watch?v=4X-f...ature=youtu.be
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() Join Date: Apr 2006
I built this over the weekend. Not as cool as the winch version but it works and was about $40 in materials. I can pull the blazer up under it as the it's u shaped and the front 2x4 comes off. I wanted something to get it out of the weather quick.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#15 |
Has anyone used a jeep top hoist? Any other ideas for us non-welder types?
#16 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Bump. Anyone familiar with this hoist system or something similar? http://www.saferacks.com/buy-direct/...ge-system.html
Looks like it would be good to go out of the box but weight limit is 220 lbs. Anyone know the exact weight for 2x and 1x wall tops? I'm guessing close to 250 lbs.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#17 |
![]() Join Date: Sep 2015
I saw this jeep hoist system online somewhere. Has anyone tried making something similar to this design? it essentially goes under the hardtop and lifts it up from there. It would make hardtop removal a 30 second process.
#18 |
How much do yas think the caps weighs about? I have a car port and was thinking of hanging it in there...
#19 |
I hung mine from trusses. 2, 2x4 at top on each end,
Single 2x4 on bottoms. Eye bolts, Rachel straps. Added cable for over kill. I did move my front support to the bottom of the topper to match rear. |
#20 |
My single wall top weigh's 240lb.
#21 |
I built a couple of metal braces that slid underneath for support.
#22 |
Carpe manana
Thanks for posting guys. BobbyK thanks for weighing your top.
#23 |
Ditto on the thank you for the weight...
#24 |
Carpe manana
Here's a useful related video from a nice ochre example now on BAT: http://www.youtube.com/watch?v=bgvv_...ature=youtu.be
#25 |
In the Pic the scale reads 305Lb's but the "I" frame weigh's 65Lb's.
Tags |
blazer top storage, top removal, top storage |
