Old 01-18-2016, 10:08 AM   #51
steveo3318
steveo3318's Avatar
Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
I don't use it to scare people. Being from 57 they didn't care about decibels and its a lot louder than most on the tracks today. To many sue happy people out there. But yes it will get anyone's attention with a quickness��
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 01-18-2016, 10:19 AM   #52
bigguy69
dazed and confused
bigguy69's Avatar
Nice
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 01-18-2016, 12:03 PM   #53
Big Kev-O
Big Kev-O's Avatar
Thats one nice truck, love that red/orange paint and trick horn setup.
I have the same FiTech kit and I'm still debating on using the timing feature. I see you plan on using a MSD 85551 distributor. I guess that means you don't plan on using vacuum advance? I have been meaning to call and see if FiTech recommends using vacuuming advance when using the system for timing control.
It's hard to tell from your pictures but did youinstall that O2 sensor 10* above level as per the instructions? Not trying to pick on your work you have done an excellent job on that truck.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 01-18-2016, 12:16 PM   #54
steveo3318
steveo3318's Avatar
I do not plan on using vacuum advance. I believe the fitech goes up pretty high in its advance set up. I did not install it 10 deg above center. I have done several several O2 sensors on my rides and several others and never had any trouble at the 90 angle. This one may be the one that proves me wrong but only time will tell. If you look close I have other O2 bungs there already. They were just to long to use
Old 01-18-2016, 12:16 PM   #55
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The computer takes care of mechanical and vacuum advance.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-18-2016, 12:23 PM   #56
LostMy65
LostMy65's Avatar
Edit.
It's my understanding that the computer handles both mechanical and vacuum advance.
Old 01-18-2016, 12:28 PM   #57
swampbog
swampbog's Avatar
The reason they want 10° is to keep moisture from collecting (sitting) on the sensor.
It can be straight up and from the top of the tube and it'll still work as well as 10°
swampbog is offline   Reply With Quote
Old 01-18-2016, 12:33 PM   #58
steveo3318
steveo3318's Avatar
You will be the first to know when it goes bad. I understand your concern. But I have sold cars before they have went bad on me. I will be screaming damnit swampbog told me so. Lol
Old 01-18-2016, 12:38 PM   #59
steveo3318
steveo3318's Avatar
Also I just want to say the FITECH customer support is top notch. I just called them to see if I could get the decel pid to act a little faster because my truck is an standard. He told me these are set up for autos but immediately knew the parameter and values to put it to and try. Also he told me another parameter to watch for the absolute best idle blade openings. I work for Johnson controls and program for a living. It's nice to talk to someone that actually knows the configuration and pids and can immediately tell you where to look. These guys are top notch and not just salesmen. They make me feel like they built all the logic and have it on their rides.
Old 01-18-2016, 12:40 PM   #60
swampbog
swampbog's Avatar
No concerns here, I was just pointing out it can be mounted any which you want it's just for the moisture they recommend 10°
And it won't be the first time I lied to anyone......on purpose
Old 01-18-2016, 12:45 PM   #61
steveo3318
steveo3318's Avatar
I know and thank you for pointing it out but I knew it when I installed. I read the instructions 3 times lol. One thing I do not do is drive it short distances and shut it down. This may help in keeping them dry. If it does go bad I will cut the pipe and rotate it. No biggy.
Old 01-18-2016, 03:31 PM   #62
2500HD
2500HD's Avatar
Are you using the factory rod type throttle linkage?
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 01-18-2016, 03:33 PM   #63
steveo3318
steveo3318's Avatar
I sure am with a set of steel bushings!
Old 01-18-2016, 04:04 PM   #64
2500HD
2500HD's Avatar
So you did not use the factory throttle linkage?
Early Classic 4.5/6
Old 01-18-2016, 04:34 PM   #65
steveo3318
steveo3318's Avatar
the rod linkage is the factory linkage to my truck. It did not have the cable which I like.
Old 01-18-2016, 06:30 PM   #66
Z10
Z10's Avatar
Here's a video starting from a mile or so away
http://vid227.photobucket.com/albums...psyrdx6orc.mp4
That is the coolest/funniest thing I've seen/heard in a long time.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-18-2016, 06:32 PM   #67
steveo3318
steveo3318's Avatar
Don't let me catch someone crossing a train track to slow cause they scared of bending their 26 inch rims. I have made a couple turn the tires to smoke that was dicking around.
Old 01-18-2016, 06:42 PM   #68
diceman50
Ok heres the only part that gave me any trouble. I don't wish push locks on my worst enemy. I tried wd40, grease, ky jelly, you name it all in the vice while damn near standing on it. My neighbor came over "a 56 year old DOT" machinery mechanic and tried and said something wasn't right. we tried a torch and it immediately cracked the inside of the hose. Finally I tried boiling them and I still had to put out with all my might with vegetable oil on the fittings. Lets just say the hose or fitting will break before the connection.
I too have had issues with push lock hose and fittings. Having done several EFI installs that use them I knew I had to come up with a solution. Following are some pictures of my crude but cheap and effective gadget. I made mine out of aluminum because that is what I had. It could just as easily been made of steel. I have another handle with a fork on it for angle fittings but I can't find it right now.
I am doing a study find the best lube. So far I have tried motor oil, WD40, "O" Ring lube, JB80, and Joe Gibbs assembly lube. Results are inconclusive.
"In an insane world a sane man must appear insane" ~Spock~
diceman50 is offline   Reply With Quote
Old 01-18-2016, 06:46 PM   #69
steveo3318
steveo3318's Avatar
I would of paid good money for that the other night. Very cool design. I can favricate most tools and that may be my next addition if I ever have to do another EFI.
Old 01-18-2016, 07:33 PM   #70
Z10
Z10's Avatar
I need me some train horns.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-18-2016, 07:43 PM   #71
Leftlane
I'm unfamiliar with this.
Is this setup to press the fittings into the plastic injection hose?
1971 C10 SWB 350/350 A/C PS PDB
Leftlane is offline   Reply With Quote
Old 01-18-2016, 07:44 PM   #72
72_K10_Vegas
72_K10_Vegas's Avatar
That's just awesome. Grew up next to the Southern Pacific. Hijacked rides when the freight slowed down for the Siskiyou's, then down to Northern California to fish on the Shasta River. Sounded just like that. Just awesome.
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 01-18-2016, 09:14 PM   #73
diceman50
It's not for the hard plastic OEM style fuel lines. It is for the rubber "push lock" type of hose and fittings that a lot of the aftermarket EFI systems use. They are very hard to install.
Old 01-18-2016, 09:20 PM   #74
LostMy65
LostMy65's Avatar
Funny, used to hike up the tracks to fish Shasta Lake. Back when it was still a lake.
Old 01-19-2016, 08:30 PM   #75
snipescastle2
snipescastle2's Avatar
Talking Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
Diceman,
How about using dish soap for lube? give that a try....
Ben
snipescastle2 is offline   Reply With Quote
