Old 01-25-2016, 10:33 PM   #301
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 1971 K20- project just get driveable!!
I had a few days off over the holidays and had some time to work on this again. Since its winter I have time to be on the forum again I finally made a subframe for the Diamond 9ft plow and got it mounted. It was a lot of fabrication since I just had two small bracket pieces to start with. There is a lot of steel here, probably about 150lbs in total. Total plow weight is about 1000lbs!
Here is the subframe I built and the intermediate Diamond frame I sandblasted and improved. Last pic is just the subframe on the truck, so how it will look in the summer if I pop off the intermediate frame.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-25-2016, 10:42 PM   #302
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great, the fab work looks awesome
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 01-25-2016, 10:58 PM   #303
Vintage Windmills
Vintage 4x4s
Thanks Dale! Here are some pics of it mounted and at work. I will make a new plow skin for it this summer, it has pretty serious rust on the blade still. These skyjacker 2.5 lift springs barely care this heavy plow is on the truck. Sure moves a lot of snow quickly. I do need to rebuild the front driveshaft, the cardan joint is clacking pretty loudly under load.
Old 01-25-2016, 11:12 PM   #304
swamp rat
swamp rat's Avatar
Yea nice fab work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-26-2016, 12:06 AM   #305
Ol Blue K20
It looks bad @$$, great job. It must be nice to keep the drive way clear
Dale
Old 01-26-2016, 12:23 AM   #306
El Dorado Jim
Originally Posted by Ol Blue K20 View Post
I would definately install the hubs, but if the gear ratio is the same I would probably swap the complete diff. It already has a broken axle let alone all the extra wear on the other parts because it didn't have lockouts. Everything spins all the time, just no load ya know... if you get the yellow lockout knobs I want the blues
The blue ones are period correct color, the yellow ones are '73 and newer
El Dorado Jim is offline   Reply With Quote
Old 01-26-2016, 12:49 AM   #307
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on the plow mount! How quick can you knock one out for a western or meyers?
Ryan
1969 Chevy milk truck
Old 01-26-2016, 03:27 AM   #308
El Dorado Jim
nice build on the truck, love the K20's
Old 02-01-2016, 11:41 PM   #309
Vintage Windmills
Vintage 4x4s
Originally Posted by swamp rat View Post
Yea nice fab work!
Thanks! I like your project too
Yep, beats my 2wd tractor that doesn't have a cab
Quite a bit quicker than this one Ryan, now I know where to attach the subframe main points and kick braces!
Thanks, the K20's are my favorites
Old 04-14-2016, 11:42 AM   #310
y5mgisi
Second Chance Program
y5mgisi's Avatar
Updates?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-16-2018, 12:40 AM   #311
Vintage Windmills
Vintage 4x4s
Long overdue for an update. A lot of life has happened in the last year or so. More on that later.
Finally found a little time to work on the truck again. Yanked the engine out as it was only running on 7 cylinders and I never could get the one valve to seat and give good compression. As such, I have only been using it around the property and to plow snow. I did put another ochre bed on some time ago for a better paint match.
Finally assembling and putting in a new crate engine that I ordered about 3 years ago. Here are some pics. Takes a little while to degrease the used manifold, spark plug shields, wire clips, paint the water pump, paint manifold, build a oil pump priming tool, round up the misc gaskets and rubber pieces. Anyways good to be back at this spare truck.
Old 01-16-2018, 02:41 AM   #312
Ol Blue K20
Good to see you're back on it.
Dale
Old 01-17-2018, 01:04 AM   #313
Vintage Windmills
Vintage 4x4s
Thanks Dale, glad to be back!
I was really struggling with not painting the engine orange but I figured this may be about my only truck that won't be fully stock looking so I might as well have a little fun with it.
Got the new flywheel and clutch installed.
This weird young cat now calls my place home. My friend found him starving and pretty wild on some property I own. We saved him and feed him well and now he is super grateful and just loves life. I'm trying to teach him not to be comfortable around vehicles but he just isn't getting it. If he survives to an old age I will be surprised.
Old 01-17-2018, 01:17 AM   #314
Vintage Windmills
Vintage 4x4s
Old engine out
Old 01-17-2018, 10:19 AM   #315
hgs_notes
GEARHEAD
hgs_notes's Avatar
Goin' crazy with the black paint! LOL You're a wild man.
The new bed looks good. Much better match for color. Good luck with the break in. The last one I did went very bad. I get to build another engine!
At least we're not getting much snow to plow so far.
hgs_notes is offline   Reply With Quote
Old 01-17-2018, 03:18 PM   #316
Ol Blue K20
I think it looks good black. Great looking cat to keep you company too.
Dale
Old 01-19-2018, 01:32 AM   #317
Vintage Windmills
Vintage 4x4s
Glad you checked in- I was able to check out your threads a little last week and you have been busy! I'm hoping the break in goes well- wondering if I can plow with it before its broke in properly? Probably won't be able to anyways since the front axle threw a cap on the U joint and then the U joint yoke wore into the axle yoke. I found a good used axle shaft off ebay that I need to install.
I figured it would look better longer with the black to hide any small leaks, dirt, heat damage, etc.
He is a bit odd, check out this pic.
Old 01-19-2018, 01:53 AM   #318
Ol Blue K20
What pic? LOL
Dale
Old 01-20-2018, 12:25 AM   #319
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hi Jud - great to see an update. Passed through Minneapolis last week and thought of you. Whats the cats name? Pete
Old 01-20-2018, 11:10 AM   #320
Vintage Windmills
Vintage 4x4s
What pic? LOL
Oops, was fighting the uploads. It is of Charles attempting a different grooming method. Also here is a pic of him in field find condition, before his “build”
Let me know next time Pete! Are you in town here for the Super Bowl?😀
Old 01-20-2018, 11:16 AM   #321
Ol Blue K20
He looks much healthier and happier now.
Dale
Old 01-20-2018, 02:34 PM   #322
BlueBullet
BlueBullet's Avatar
Good to see your back at it. Was thinking about asking how the projects are coming along and your thread popped up again. How is the Cummins swap coming in the red square body? Still have the Longhorn in the herd? I found another one out in South Dakota and I got a thread on it in the 4x4 section called Big Bird.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 01-20-2018, 07:59 PM   #323
Vintage Windmills
Vintage 4x4s
Hi Nathan, I will check it out, always like to see other builds! Thanks for stopping in here. I haven’t done much on the Cummins truck but it’s moving up the list and the engine is ready. Still have the longhorn. We parked it down by the road and sold apples out of it. Here is a pic of it while being pulled down there. We really like the color of it. I almost forgot how beautiful MN is in October.
Old 01-21-2018, 01:42 AM   #324
Vintage Windmills
Vintage 4x4s
New engine sitting in place.
Old 01-21-2018, 02:53 AM   #325
Ol Blue K20
Looking good.
Dale
