04-17-2015, 10:36 AM | #276 | |
Re: Ok Boys and Girls it's Storytime
Had a racer friend w/ similar trailer tire experience. He now runs his tires 4 years, and they come off, regardless of how they look. Most companies that recap tires will not cap a tire older than 4 years old. Tire knowledge is part of my job. Knowing how old your tires are is a good thing, for any vehicle. Hope you make it to Oklahoma again soon!!! The Tulsa divisional race is weekend of June 13, 14. Thanks again for show me your pickup at Noble last fall!!! Jeff |
04-18-2015, 04:46 AM | #277 |
mini truck racer
Hoping the weather holds out for you . Everything got cancelled down here . Alot of my buddies are up their with you . James ogden and David Sheets in top dragsters quit a few 10.90 guys also .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
04-27-2015, 08:02 PM | #278 |
I havent given an update becuase it was not a good trip. I had fuel system issues from the start. Finally got it down the track on 3.5 pounds of fuel pressure and it was 11.00 at 149.50. The air conditions and the wind were horrible fri and sat but all the passes I made were good mph. Sunday first round I screwed it up and gave the stripe up by 15 thousands and lost first round. But it looked to have been on a 152 mph pass. My generator gave me hell all weekend. It had an exuast valve guide that gave up on me. Now I have to replace a head on my Onan 7000 generator. Its never ending!
NHRA Super Street 469C It only runs 10.90 at 156 mph |
06-04-2015, 04:25 PM | #279 |
mini truck racer
Bump for an update :
Sportsman Series Points Driver: Regan Wilson Class/Registration: SST/469C Hometown: Tyler, TX Points Sum Type Event Code And Location Date 30 30 HD 41-Ennis, TX 04/19/2015 30 Events Attended/Counted: 1/1 Points listed in green background are included in the total. Points listed in red numbers are not eligible. Type: HD=Home Div, NA=National Event, OD=Out of Div
06-05-2015, 08:26 AM | #280 |
LOL Hotrod... Your not going to do that to me all season are you? Ok heres the update since you ask. I just got my generator parts this week. Put a new cylinder head on yesterday but still have an hour or so of work to finish. Also they didnt send my manifold gaskets so I have to find some. They postponed the Belle Rose La race till July becuase of rain. I am supposed to be going to Tulsa next week but Im not sure I can go. All the sudden my old trusty Goat decided to develop an exhaust manifold leak. Also I have an equipment install thats going to take all day wednesday next week(when I should be loading up). On top of that Houston is the week after on June 19th. I really dont have the time to do both becuase its just too much time away. It looks like the plan is Houston, Topeka(two races in one), Shreveport, and Noble Ok. That will only make six for the year but at least I will still have one to throw out(we only count five). See you in Houston for sure.
06-12-2015, 12:33 AM | #281 |
Ok HotRod you shamed me into going racing.im in Tulsa right now. I'm by myself so does someone want to come take care of my tires? Lol I'm spoiled
Posted via Mobile Device |
06-12-2015, 01:36 PM | #282 | |
06-13-2015, 04:12 PM | #283 |
Well it looks like my water leak has reappeared . I went this morning for our first time trial. It got warm just as I got to the lanes and wouldn't cool down like it should. I finally got it down to 150 and made my run. I was .002 on the tree and went 10.855 right at 151 mph. It was really hot at the end of the track. I got it cooled down and pulled the radiator cap. The water level was at least 10" low. Pulled a valve cover and it had a half inch of milk in it. I literally raked it out with my hand. I'm done for now and probably for the season. This will require a total tear down.
06-13-2015, 04:17 PM | #284 |
On the other hand ! If you do the math my last thee runs. If my delay was set the same my light would have been .000, .008 and .002. I was .020,.011 & .002. It sucks to go home when you know you could be really competitive. There's too much at stake to take the chance.
06-13-2015, 04:32 PM | #285 |
mini truck racer
Man sorry to hear the bad news .
06-19-2015, 11:50 AM | #286 |
I'm just glad to be here!
Man that really sucks...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-01-2015, 02:07 PM | #287 |
Regan,
You get that engine ordeal figured out? |
09-01-2015, 07:32 PM | #288 |
I haven't posted anything in awhile but I'm trying to get going on this. I got everthing worked out as far as the block and heads go. My left cylinder head had a crack that didnt show unless it was tourqed down(this head has been through hell and back). When I say through hell and back I mean it. Anyhow Brodix helped me find the problem and they fixed the problem. I have all new seats, 14 new valve guides, and a pretty (I mean beautiful) new surface to work with on the heads and block. My new rings were on the porch when I got home today. I also bought a cylinder hone (brush hone) so I can re-ring without a trip to the machine shop. I will get started on this in a day or two. I dont think I'm going to any more divisionals this year(but you never know). My plan right now is to get it together and go test and then run it wide open. I want to know what what the old Blue Truck can do!
09-01-2015, 09:42 PM | #289 |
I want to see some wide open runs with the blue truck also, please have someone video if you can.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
09-02-2015, 12:24 PM | #290 |
Noble divisional is last weekend of this month.....a good test
No need for a recording (for me at least)!!! I'll be there! |
09-12-2015, 01:54 PM | #291 |
I would love to see what it runs WOT.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-18-2016, 09:28 AM | #292 |
Well guys the troubles continue. I had the shortblock together since probably October. Had too much work so it was on the backburner. Finally put it all together and started it new years eve. New Years Day I found water in #1. I've done everything I could think of to resolve the issue with no luck.
I pulled the motor on 1-16 after a leakdown test. #1 pushes compression straight into the water jacket. #4 is real oily and #8 has too much leakdown. The sealing problem makes no sense at all. The surface of the heads and block are like new from Brodix. Upon examination the head gasket was leaking in between layers. They were all flat layers unlike the Cometic I tried last year that had a fire ring stamped into it. So now I'm in the middle of a mechanical autopsy. I hope to figure out what I need today to put it all back together. I have six weeks to be ready for our first race in Houston.
01-18-2016, 09:49 AM | #293 |
On the other hand, Is this motor cursed?
I guess the Devil is in the details! It is real close to 666 cubic inches! LOL
01-18-2016, 10:42 AM | #294 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-20-2016, 09:34 AM | #295 |
Well it looks like I dont have any real issue with the rings. My Total Seal top rings were lined up wrong on #8 causing the bad leakdown. The oil gap was in line with the wrist pin on #4(there is a gap where the pin is exposed) thus the oil in #4. Ill be able to fix all that easily.
Hopefully today I can solve the head gasket delima and get some parts on the way. Now all I have to do between now and Feb 21st is, Put the motor back together and get it running New 5" collectors and exhaust tubing with collector tethers Put on the rebuilt anti-roll and scale it Sounds easy if you say it real fast!
01-27-2016, 09:50 AM | #296 |
Well I have all my parts now. I'm going to try to finish the motor today.I have the shortblock back together and the pan on it already. I found no reason for the Cometic gasket to leak. But after the crappy customer service from them I wont buy anymore. I just hope it works with the Fel Pro because this is getting a little disheartening. I hope to have it running this weekend and get back on track.
01-28-2016, 09:21 AM | #297 |
Well I was wrong! I bolted down the head with a FP gasket and aired up the cylinder. Air was coming out of the water jacket. Pulled it back off and found what looked like a crack where the fire ring seals to the head. I called Jeff Brotherton and begged like a little kid for help. The head will be at Brodix today and hopefully they can get it back to me before next weekend.
It looks like my heads are just getting old and soft. Thats a shame because they work so well. You wont see too many of these old castings that will flow over 530 cfm. My guess as to what happened is the Cometic gaskets I tried last year had a embossed inner layer so strong it weakened the head surface even more (it left impressions on the head surface). So all that being said its not Cometics fault ! (although I still didnt care for the customer service) I found the problem but will be under pressure and a major time crunch to be ready for Houston at the end of Feb. If i get the head back next week I have two weekends to get ready. I love this stuff !!!!!!
01-28-2016, 10:49 AM | #298 |
Well the good news is you found the problem!
Hope it all works out for you and you can make the Houston race!
01-29-2016, 09:31 AM | #299 |
Well I put my other head on yesterday just trying to do everything I can with the situation. I have been looking for some shim stock to space my rocker stands because the machine work multiplies into the valve train setup. I dont have time to send off my Smith Bros ex pushrods and i dont want to replace my Manley int pushrods. Anyway I was disgustedly looking at $500 worth of useless Cometic gaskets sitting on the bench and thinking (I need to throw those away). Then a light bulb went off !! Those are multi layers off shim stock just waiting to be cut to shape. I pulled all four off them apart and now I have 10 thou and 15 thou shim stock. I felt pretty dang smart. I must admit though it felt good cutting them up! LOL
02-01-2016, 09:46 AM | #300 |
I got my rebuilt anti-roll back on yesterday. Put on a new master cylinder and bled the brakes. I guess I left out the fact I almost ran off the end of the track in Tulsa. I might have been in trouble somewhere else. If it wasnt for the long uphill shutdown I would have been.
Anyway my head should be back home today. Hope to have it running by wednesday. Then its off to the chassis shop for the new collectors and convert all the exhaust to 5". If all this works out I will be in good shape and ready for the first race.
