Old 01-28-2016, 12:14 AM   #476
lower50's
lower50's's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
I am using a 16" Derale 16136. All the good aftermarket fans should be similar.
I never had any luck with the fan temp probe in the block as the thermostat keeps the engine at a consistent temp. But there is no pcm.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-28-2016, 09:01 AM   #477
FarmerSid
FarmerSid's Avatar
Thanks again JJ!
Looks like the Spal I'm looking at is pretty much the same as the Derale you are using. Where do you order your parts from? Even with the crappy dollar, it's still cheaper on a lot of things to get them out of the states.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-28-2016, 10:56 AM   #478
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Originally Posted by FarmerSid View Post
Thanks again JJ!
On a lot of my parts, I tend to price-shop between Amazon, Jegs/Summit and Ebay ... I wish just one of them always had the best prices on everything, but it's rarely the case
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 02-05-2016, 09:25 PM   #479
FarmerSid
FarmerSid's Avatar
Just noticed JJ but I meant to ask Lowers where he orders his stuff fro as he's in Canada too. Brain fart on my end.
Question. What year of S-10 are you guy's using the brake pedal assembly out of?
C4 IFS & D44 IRS
5.3 HO L33
Old 02-05-2016, 09:44 PM   #480
99 to Life
99 to Life's Avatar
on my 51' I used a brake pedal from a square body s10. I just bought a corvette pedal assembly off egay for dirt cheap should work out pretty similar. I used a 98 Silverado pedal on my 49' little taller allowing the booster to go up higher. I like it. I like the s10 pedal setup the least.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-05-2016, 10:14 PM   #481
JJorgensen52
Mine was out of a square S10 as well, '87-'93 vintage. I think a fullsize truck bracket from the '88-'98 realm might work reasonably well, too.
**EDIT** saw 99 to Life recommended the '88-'98 bracket, too ... so +1
CURRENT
SOLD
Old 02-05-2016, 10:40 PM   #482
FarmerSid
FarmerSid's Avatar
Thanks guys! Maybe I should be rethinking things. I have a booster MC coming. Thinking of using a factory pedal and bracket such as the s10 as I don't know the dimensions to build my own. If anybody has ideas, please share.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-05-2016, 10:58 PM   #483
99 to Life
99 to Life's Avatar
I was thinking of building my own on last two builds and just became easier to use one that was already someone done. but... it would be easy to build non the less.
Old 02-06-2016, 08:06 AM   #484
4DSEVEN
4DSEVEN's Avatar
Congrats to your son and the proud ole' man! Great memories for sure.
Build is looking great!
I still order from Summit now and then. Some stuff there's not a ton of options and have to go State side. If youre close to the border get it shipped to a UPS store and pick it up there. A lot of US based companies offer free shipping within the States.
4DSEVEN is offline   Reply With Quote
Old 02-06-2016, 09:03 AM   #485
FarmerSid
FarmerSid's Avatar
Thanks 99. Have any pictures of the 98 brake pedal assembly? Found your S10 setup in your builds. What year Vette assembly did you get? No sense in re inventing the wheel!
Found your bracket mods in your build JJ. Great work and very detailed documentation! Will be referencing that for sure.
4Dseven. That's pretty much what I have been doing too. I have a shipping address at Wellesley Island just across the border at thousand islands. I actually have a rad and fan sitting there ready for pickup. Waiting on a few more parts to come in before I go and pick it all up.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-07-2016, 12:24 AM   #486
99 to Life
99 to Life's Avatar
corvette was c4 90-96 automatic pedal. Here is the 98' set up
Old 02-07-2016, 12:39 AM   #487
99 to Life
99 to Life's Avatar
here is the pedal I got, this one is on ebay right now same price, same seller. only mine came with the brake light switch, but those are dirt cheap. Preliminary viewing, the bolting pattern on the back of the pedal most likely isn't going to line up with the booster I have. So.. I'll confirm that tomorrow. If I was a real man I'd have a friggin tig welder and I could work with this aluminum bracket. Since I'm a pauper, well I'll have to bolt a plate with the right bolt pattern to this and mount to firewall that way. Which... isn't bad to do since you need to reinforce the firewall anyway, the plate will serve two purposes.
Old 02-07-2016, 08:56 AM   #488
FarmerSid
FarmerSid's Avatar
Thanks 99! Pictures and info is a great help. Found a guy parting out a 1992 and a couple 1997 trucks. Is there a prefered year of truck to get the brake assembly out of that you know of? I'm gonna take your advice and get a longer siverado setup.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-07-2016, 10:45 AM   #489
99 to Life
99 to Life's Avatar
well, my pedal came out of an automatic and let me tell you, was the biggest nightmare I ever had taking something out. There are lots of spot welds on the top, some of which I had to cut a hole in the cowl from the outside to drill them out. So if you can get in there and torque it out, I'd suggest that. If you could find one out of a 73-87 I bet it would work just as good and easier to take out.
Old 02-07-2016, 11:13 AM   #490
Advanced Design
Advanced Design's Avatar
Sid, have you considered this one from Speedway?
http://www.speedwaymotors.com/Univer...unt,59785.html
Reaper71 used it in his Orange truck build and it is $80. Has good reviews.
Advanced Design is offline   Reply With Quote
Old 02-07-2016, 02:00 PM   #491
FarmerSid
FarmerSid's Avatar
so the 95 brake assembly is welded in? Crap! that sounds like a bunch of work. The 73-87 assemblies unbolt?
C4 IFS & D44 IRS
5.3 HO L33
Old 02-07-2016, 02:02 PM   #492
FarmerSid
FarmerSid's Avatar
Thanks AD. The price isn't too bad. I'll look into it. Cheers!
C4 IFS & D44 IRS
5.3 HO L33
Old 02-08-2016, 10:41 AM   #493
lower50's
lower50's's Avatar
Yes I believe the 73-87 assemblies unbolt. My mid '80's chev van pedal did.
1951 MG TD
Old 02-08-2016, 12:15 PM   #494
Coach529
Coach529's Avatar
I love the looks of that. Might have to give it a try.....
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-08-2016, 12:21 PM   #495
JJorgensen52
I can confirm they do.
CURRENT
SOLD
Old 02-26-2016, 08:27 PM   #496
lexteak
Re: 1952 Chevy Vette Farm Truck Build
Jim, just reading thru your build. I'm doing C4 with flatout. I see early on you indicated that you wish you had done the front suspension first. I was thinking of starting on the rear first. What was your reasoning there ? Thanks Jay.
lexteak is offline   Reply With Quote
Old 02-28-2016, 08:19 AM   #497
FarmerSid
FarmerSid's Avatar
The reason I said that was because of the way the rack mounts to the cross member which limits how low one can get the front. That's with my type of front cross member anyways.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-28-2016, 09:26 AM   #498
lexteak
I understand know. I think I'll take your advice and mock the front up first. Thank Jim. Appreciate the quick response.
Old 05-24-2016, 12:27 AM   #499
Root2812
Root2812's Avatar
No problem 99! The pan is for a 98-02 F-body Camaro. GM part# and part. Truck pan hangs way lower than the cross member. These pans are pricey as everyone wants/needs it for a lot of LS swaps. I think I got lucky and found a brand new one for $215 US shipped to the Canada/US border. It came with some extra parts that are needed for the swap.
Where were you able to find that pan for that price? Or was that just the pan without the pick up tube, windage tray, and dip stick? I need that set up too.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 05-24-2016, 01:14 PM   #500
FarmerSid
FarmerSid's Avatar
I go the pan from a private seller. It came with the pan, windage tray and pickup tube.
https://www.superchevyperformance.co...tCode=12628771
Above is a pan and the related parts are available there too.
C4 IFS & D44 IRS
5.3 HO L33
