02-13-2016, 09:28 PM | #1 |
1 pc rear main v 2 pc rear main
My latest project is building a 383 sbc for my 79 c10. I have built several sbc motors with 2 pc rear main seals (rms), but never a 1pc.
Anybody know what parts I would need specific to the 1pc rms if I am using aftermarket heads, intake, rotating assembly etc? From what I can tell the oil pan should be the only part not interchangeable in this scenario. What does everyone think? |
02-13-2016, 10:01 PM | #2 |
Re: 1 pc rear main v 2 pc rear main
you will have to buy an aftermarket stroker crank specific for the 1 piece rear seal. other than that its business as usual
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
02-13-2016, 10:11 PM | #3 |
1 piece factory roller block is the way to go! You'll have a great motor.
02-13-2016, 10:56 PM | #4 |
Sweet! I picked up the block today and the rotating assembly is on its way. I already have just about everything else. Check out the parts list below and let me know what you think! factory roller block w/4 bolt mains fully machined and .030 over Eagle rotating assembly w/hypereutectic pistons 9.5:1 w/76cc heads, 3.75 stroke cast crank, forged 5.7in rods EQ Torker heads w/2.02 in 1.6 ex, 76cc cnc'd chambers, and I believe 190cc runners, but may be wrong on that one Stainless roller rockers 1.6 Holley Street Dominator dual plane intake HEI distributor th350 trans Planning on a roller cam of course and waiting on Comps recommendation What size carb should I go with 650, 670, or 700cfm? I plan to keep it under 6,000 rpm with a rev limiter. Anybody have experience with using a smaller carb on a 383? Should I switch to a single plane intake? The truck will mainly see street use. What about gear ratio for the rear end? I'd like to go fast and drive on the highway. Any and all suggestions, tips, and comments welcome. Thanks! Last edited by LookSlowGoFast; 02-13-2016 at 11:05 PM. Reason: add photo |
02-13-2016, 11:03 PM | #5 |
Sounds great! Although... I'm not a Comp Cams fan. Not gonna sling trash, they're just not my cup of tea.
I'm running a Street Demon 625cfm carb on my stock 402 big block. Electric choke, super easy to tune. Was very close right out of the box. I'd definitely stick with a dual plane intake. What about a 200-4R trans? .67 overdrive and a 3.73 gear would be killer! That's what I'm building now for my 402. |
02-13-2016, 11:26 PM | #6 |
Great point about the od trans! What rpm do you get out of the 402 and is it stock or modified? Carb sizing is one thing I'm not clear on. I always heard to go with 750 no matter what growing up, but over the years have learned that's complete non-sense. I know there is a bit that goes into, but not sure what. I run 600cfm carbs on 355's with great results, but would think a 625 is too small for much anything over this. On the other hand, I see 500cfm 2 barrels on race cars all the time and they run great.
What all would you take into consideration when choosing a carb? |
02-13-2016, 11:44 PM | #7 |
The 200-4r is still on the bench! So, I have the stock 3.08 and TH400 in there. Honestly, it's not bad with 235/75-15's, but run the numbers on a 3.73 and overdrive and it's much better at both ends. Where my 3.08/TH400 runs 2500 rpm, a 3.73/200-4r will be 2024 rpm... and have lower first/second/third gears!
As for carb size, ANY time you're not driving with your foot on the floor, you're not using the whole carb's airflow, right? So if you're building a drag car that's one carb requirement. On the street I hardly EVER put the foot on the floor. And, even though it's a 402, I'm using the truck as my freeway dirt bike hauler. 2 hours each way. So I'm going for as much air velocity, vacuum, and optimized ratios as I can. The truck drives amazingly well and really scoots. Your 383 will light the tires so bad it'll scare you. |
02-14-2016, 12:10 AM | #8 |
Well that makes complete sense. I really never thought about it that way, but you are absolutely right about the carb situation!
I've spent plenty of time going sideways so I'm not too worried about how well it hooks up. I'm also planning to raise the rear back up a bit for better weight transfer and a better stance so that might help some. |
02-14-2016, 10:33 AM | #9 |
Nice truck! Just my opinion, but are you sure you want to go with the O/D? Guess I'm a bit "old school", but your already setup with a TH400 (probably one of the strongest trans. GM ever made) and a 3:08 diff which is close to a perfect match. Running the 400 you will not have to install any electronics, TV cable & adjustments etc. I have had too many BAD experiences in the past with high performance engines and overdrives. (put 3 700R4's in my 82)
I'm not familiar with the 200.... maybe it's a better trans.... Guess it also depends on where you do most of your driving..... around town, the 400/3:08 would be perfect, on the highway the overdrive will shine.... |
02-14-2016, 01:38 PM | #10 |
The 1 piece flexplate/flywheels are different bolt pattern as well. Since you are doing a 383 it might not matter but the later 350 engines use a externally weighted flexplate where the early ones are internally balanced.
Anthony |
02-14-2016, 01:52 PM | #11 | |
I also would not use a 1.6 rocker arm unless you need it. and since you dont have a camshaft yet there is no need for it. They are not automatic power adders. They will also increase your valve lift which can cause problems with retainer to guide clearance, piston to valve clearance, pushrod clearance and require extra spring pressure. I would go with 1.5 unless you end up with a camshaft with low lift and need to bump it up to make sure of the heads air flow. since Im not familiar with those heads I dont know what they flow. A 190cc runner sounds good but tells me nothing about what they flow. You can use a smaller carb but your fuel requirements will be different from say a stock 402. I would probably use the 670cfm carb from your list. I had a 670cfm street avenger years ago that was a decent carb. I was strictly Holley carbs when I was younger but I have been leaning towards qjets lately. They are great for economy and have great performance as well. Check out Sean Murphy Induction for more info on them. He is probably the best guy around for qjet performance. Gears will depend on several things. What tire size do you have? What camshaft do you have? What transmission do you have? And is it up to the task of this new engine? Stall converter? What type of driving are you going to do most? is fuel economy important to you? Dont forget you will want to upgrade the fuel pump to feed the new engine and possibly a ignition upgrade. A rev limiter isnt really needed unless you just want one.
Anthony |
02-14-2016, 04:22 PM | #12 |
Freeway dirt bike hauler?
Pics of if didn't happen
1982 K10 SWB 1987 V20 - Sold - Doh! |
02-14-2016, 05:39 PM | #13 |
Oh Ya?? Take THAT:
02-14-2016, 05:42 PM | #14 | |
02-14-2016, 07:00 PM | #15 |
This should point you in the right direction: How Big A Carb Do You Need http://www.hotrod.com/how-to/engine/...b-do-you-need/
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein |
02-16-2016, 05:10 PM | #16 |
Master Hater
2004r and a 4l80E are worlds better than any POS 700r4/4l60E
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
02-16-2016, 07:15 PM | #17 |
I have no problem with Comp other than that they'll likely suggest a thumpr cam which is mostly for sound, with power an afterthought.
I imagine any of those carb sizes will work well. On a street truck I'd absolutely want OD but there aren't any great options for non electronic auto. A manual valve body in a 4L80e is a reasonable choice.
1973 C20, 350/350 |
02-16-2016, 08:55 PM | #18 | |
driving is in my blood
Speaking of heads, you want to run 190cc ports with only 383cubes and a 6000rpm max? You want 180cc at best, or run the engine higher up.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-16-2016, 10:00 PM | #19 | ||
GM also kept the stroke at 3.48 in production sbc engines. When you add a 3.75 stroke it takes a large dish to get compression under 10:1 with a 64cc head. Nothing wrong with using the 76cc head here. Generally I would agree the 180 head would be better for low end power but the EQ heads are pretty decent and it will still make more torque than the tires will handle.
Anthony |
02-16-2016, 10:29 PM | #20 |
Looks like a KTM 300 smoker. Very nice. I ride a Husqvarna TE310. Rekluse Autoclutch too.
Tags |
1pc rms, 2pc rms, 383, rear main seal, sbc |
