Old 02-09-2016, 06:23 PM   #1226
RodsGreen10
RodsGreen10's Avatar
Re: 1976 Square "Simple Green"
Anyone who does not know about DeVane Carburetor. Robbie builds carbs for some of the street outlaws on tv.
RodsGreen10 is offline   Reply With Quote
Old 02-11-2016, 06:24 AM   #1227
RodsGreen10
All parts have shown up for carb install. Carb will be here tomorrow.
Old 02-11-2016, 10:55 PM   #1228
funkatation
Are you keeping the tank/pump setup you had with EFI?
funkatation is offline   Reply With Quote
Old 02-11-2016, 11:14 PM   #1229
RodsGreen10
Yes I am. But replacing all the fuel line and fittings and inline filter. Ordered a Aeromotive fuel log bypass regulator combo kit.
Old 02-12-2016, 06:24 AM   #1230
RodsGreen10
After all the hard work and $ and effort converting over to EFI I had to keep something lol. Now I like a intank pump better than a mechanical pump. Plus the way it is going to be setup will be perfect.
But I have a extra baffled tank and all that fuel line I used for the EFI setup.
Old 02-12-2016, 06:26 AM   #1231
RodsGreen10
This is the Aeromotive fuel log with bypass regulator I will be using.
Old 02-12-2016, 06:47 AM   #1232
RodsGreen10
Plus I had to buy me a new Innovative AFR gauge for some fine tuning. The AEM one I had took a dump on me. It will only be used for tuning. Sure as hell won't be mounted in the truck.
Old 02-12-2016, 04:54 PM   #1233
RodsGreen10
Carb and log
Old 02-13-2016, 08:01 AM   #1234
RodsGreen10
My plan orginally was that I was going to mount the reg on the back side of carb. But that didn't work. Got all the old line out and filter. Put all new 8an line back in and new filter. 8 an line is fun to run and work with lol. Moving along real good and boom one of the fittings I ordered I guess I order the wrong one cause the fitting I needed well I didn't have. So I ordered the fitting I needed it will be here Monday. New spark plugs will be here today. Cause the FiTech ate a new set of plugs I put on when I got the FiTech. I am in a mad dash to get this running cause my tranny is setup for install next week. One of my hotrod buddies is doing it for me!! Thank God for that.
The Aeromotive fuel log is tha ****. I have not seen a fuel log that has a ball joint type fitting on it before. The part that runs into the carb back down to the log has a ball joint swivel joint thing lol. I honestly do not know what it is called. But man is it nice. I can position the log ever how I need it for clearance.
Old 02-16-2016, 07:59 PM   #1235
RodsGreen10
It's ALIVE!!! Haha!! Woooo!! Finally. It runs and cranks and idles and will drive!!!
Old 02-16-2016, 08:15 PM   #1236
swampbog
swampbog's Avatar
Hot Damn
Now this August I expect you up here for the Woodward Dream Cruise.
swampbog is offline   Reply With Quote
Old 02-16-2016, 08:21 PM   #1237
RodsGreen10
Originally Posted by swampbog View Post
Hot Damn
Yes sir HOT DAMN!! Sounds like a plan man sounds like a great time. Hell if you ever get down this way for a rod run in Piegon Forge or come 4 wheeling at Wynn Rock hit me up.
O and truck starts with turn of key. My EFI couldn't do that lmao. I just needed to get another stab in.
Old 02-16-2016, 08:22 PM   #1238
RodsGreen10
Feels good to have it running. 2 months of troubles it ran good 1 time in 2 months. Now I can move onto the transmission.
Old 02-17-2016, 06:40 AM   #1239
RodsGreen10
Got my transmission and converter from PTC in Muscle Sholes Alabama. Really nice people.
Old 02-17-2016, 09:37 AM   #1240
swampbog
swampbog's Avatar
Never heard of WindRock before, just looked them up. Looks interesting, maybe I'll will take a skip down there for some fun. It's only 8 hours away so a nice long weekend is possible.
I've been to Pigeon Forge before and for about 5 years we use to rent cabins in the area for our vacations. Now we are looking farther south and west for our vacations. All this time I was in Pigeon Forge I had a place to drink beer and I never knew it
Old 02-17-2016, 09:44 AM   #1241
RodsGreen10
Lmao! Damn right you did and a little moonshine!! Yes if you like off roading Wind Rock is the place to go.
Old 02-17-2016, 09:51 AM   #1242
RodsGreen10
PM sent
Old 02-18-2016, 11:48 AM   #1243
ray1970
Ray here.
This is not my thread.
This is not a Fitech thread.
But for the sake of info and making RG10 fell better I will post this.
I had a little problem with my EFI unit that was taken care of after a bit of time.
The new unit runs VERY well on my 408 motor.(12 in.vacuum)
Fast forward.....
Install on full mod. 408 mud truck.. High rev.. BIG cam..Low gears..Low intake vacuum.(6 in)
1. Will not idle.
2. Runs pig fat.
3. Adjusting any setting at this time makes NO difference .
Not giving up but not going to spent a lot of time with it....The old 950 carb is only a few feet away....
Ray..
ray1970 is offline   Reply With Quote
Old 02-18-2016, 12:20 PM   #1244
RodsGreen10
Originally Posted by ray1970 View Post
Ray here.
Fast forward.....
1. Will not idle.
2. Runs pig fat.
Ray..
Now Ray FiTech told me they have them on big cam low vacuum vehicles all over the country. And they even have them in house. Lmao. BS.
Don't waste your time Ray don't do what I did with that setup. Throw the carb back in or spend the money on a custom carb.
The DeVane Custom Carb I have now fires with turn of key no pumping pedal nothing. It was in the 30's yesterday truck sat all night all day came home turned key she fired right up!!! I got what I paid for with my DeVane Custom Carb!!
Old 02-18-2016, 01:24 PM   #1245
Low Elco
Glad it's up and running. Time to pull it all out for the LS swap!
Low Elco is offline   Reply With Quote
Old 02-18-2016, 01:32 PM   #1246
RodsGreen10
LS hahaha!!
Old 02-18-2016, 02:10 PM   #1247
ray1970
Ray here.
The 950 works very well but when your jumping 10-15 feet in the air and landing hard.
Float bowls don't always do well with that.
Was (Still) hoping EFI would be the answer..
As we know sometimes the answer can become the problem.
Ray.
Old 02-27-2016, 10:03 PM   #1248
ray1970
ray here.
failure of the fi working on my mud truck tuned out to be ing. interference
so all the adj. in the world was not going to help...
hope this helps someone......
ray
Old 02-28-2016, 08:27 AM   #1249
RodsGreen10
ray here.
ray
Ray hit my guy up he will build you a custom off road carb.
https://m.facebook.com/DevaneCarburetors/
Old 02-28-2016, 08:29 AM   #1250
RodsGreen10
Well if weather permits I am having my PTC transmission and convertor installed. I have decided against putting it in myself. Which makes me kinda nervous lol. I am a perfectionist. Taking it over to one of my hot rod buddies shops down in Severville TN.
