02-20-2016, 08:29 PM | #1 |
Re: Changing from trailing arms to coil spring rearend
I read the post carefully and thoroughly. Read it again when it made no sense. Every time I looked at it it still said the same thing, then I posted. I just read it again to be sure and I have no idea where you got what you posted above unless you had a conversation with the thread starter somewhere other than on this tread. I'm still waiting for that person to come back with a clear question so we can give a clear answer.
02-20-2016, 08:50 PM | #2 |
Sorry for the confusion.Donor 72 LWB GMC has leaf springs.Noisey rearend in in 72 SWB Chevy coil springs.
02-20-2016, 08:51 PM | #3 | |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-20-2016, 09:40 PM | #4 | ||
02-21-2016, 09:19 AM | #5 |
You will need the axle perches to weld onto your housing after you remove the leaf spring perches. Most vendors carry these, but make sure you have the correct pinion angle before they are welded, because you'll have more troubles with u joints and pinion bearings if you don't.not to mention the panhard bar stud provision. Here's a link to classic parts kit for your type conversion:
http://www.classicparts.com/mobile/1.../#.Vsm5mcnnaBY. HTH, Ben |
02-21-2016, 09:27 AM | #6 |
Save yourself all the time and trouble of switching rears and just rebuild the noisy one .
