Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-26-2016, 12:23 AM   #176
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
I have no idea what the mounting stud pattern is on that booster that they are using. The '67-'70 boosters are one of the boosters that are compatible with all of my booster brackets. The '71 & '72 boosters have a different mounting stud pattern and require slight elongation of the holes in my booster brackets.
Originally Posted by Already Gone View Post
Will your bracket work with this setup.? My truck is a 72 C10 with the original factory power brakes.
http://www.ebay.com/itm/331723920041...%3AMEBIDX%3AIT
Old 03-01-2016, 01:51 PM   #177
jeh
jeh's Avatar
I have a question about your bracket, I have an original type booster on my truck now with the step down style bracket that attaches to the firewall. With your bracket is the rod that goes to the brake pedal at an angle?
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 03-02-2016, 02:42 AM   #178
Captainfab
60-66 Nut
That will depend on whether you install it in the original hole in the pedal or drill a new hole for a better ratio. I would say that in the original hole it should be fairly straight.
Old 03-02-2016, 09:37 AM   #179
jeh
jeh's Avatar
Will I have any trouble with the automatic shift linkage on the steering column as far as clearance issues with the booster? do you have any pictures of it installed on a column shift truck? Thanks
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 03-03-2016, 12:54 AM   #180
Captainfab
60-66 Nut
If you use your original booster or one the same size, it will interfere with the column shift linkage. You will need to use a booster with a diameter less than about 10". No I do not have any installed pics other than what members have posted in this thread.
Old 03-03-2016, 08:27 AM   #181
jeh
jeh's Avatar
Ok, thanks. The Wilwood setup I'm going to use has a 8" booster so it should work out.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 03-14-2016, 09:26 PM   #182
Rustyo61
Bracket arrived today and the fit and finish are the best I have seen. Thank
Rustyo61 is offline   Reply With Quote
Old 03-14-2016, 10:57 PM   #183
Captainfab
60-66 Nut
Thank you for the compliment.
Old 03-21-2016, 02:53 PM   #184
jeh
jeh's Avatar
Captain, I would like one of your brackets for my '70 c/10 in black powder coat, how do I pay you? Thanks, Jason
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 03-23-2016, 08:14 PM   #185
jeh
jeh's Avatar
Payment sent via PayPal for 67-72 brake booster bracket in powdercoat satin black, thanks, Jason
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 03-26-2016, 07:38 PM   #186
jeh
jeh's Avatar
Recieved bracket today, looks great. Hopefully I'll get it and my new master/booster installed next week, thanks
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 03-28-2016, 04:49 PM   #187
juddss
Posting so I can find again. Nice work
juddss is offline   Reply With Quote
Old 04-06-2016, 06:33 PM   #188
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Thanks for the previous reply. Sorry to keep questioning you but getting parts from the USA to here is expensive so i want to make sure things will work if I buy them. Frank (vendor Pickemup ) in Olympia is selling this master/booster proportioning valve combo and I'd like to use it in conjunction with you bracket. In Post 2/3 of this thread the booster you how hanging on your bracket seems to be the same as the one in the attached pic of Franks so am I to assume Franks will work will your bracket. I have 1972 C10 350/350 with factory original power brakes.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-07-2016, 12:08 AM   #189
Captainfab
60-66 Nut
The booster and master assembly you show in that picture, will bolt right up to your firewall since it is an original replacement assembly. No additional bracket is needed. My booster brackets are typically used with nonstock boosters to get everything closer to the firewall. Additionally, my booster brackets are not compatible with a column shifted auto trans unless the booster is smaller than about 10" in diameter. If you do want to eliminate the factory brackets and get everything closer to the firewall, the booster mounting holes will have to be elongated if that is an original style '71-'72 booster.
Old 04-07-2016, 11:46 AM   #190
Already Gone
Thanks for the info. My idea was to use smaller booster ( this one is 9 inches ) and get it right up to the firewall. Sounds like I should just use the above setup the way it is.
Old 04-07-2016, 07:14 PM   #191
jeh
jeh's Avatar
I'll throw in a pic of mine after I got it all buttoned up. Looks so much better tucked in toward the firewall.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 04-07-2016, 07:50 PM   #192
Already Gone
Thanks and yes they look so much better close to the firewall.
Old 04-07-2016, 11:12 PM   #193
Captainfab
60-66 Nut
I would be happy to sell you one of my booster brackets. I just wanted you to understand that you will not be using any part of those factory mounting brackets. That will end up costing you more money than just buying a compatible booster and master cylinder locally along with my booster bracket.
Old 04-20-2016, 05:41 PM   #194
Rondaddy
Captain, it looks like your bracket might cure a clearance issue I'm having with my 68 K10. My new intake and carb setup isn't working with the stock 11" booster location and I'm looking for a solution that would allow me to mount a smaller diameter booster closer to the firewall.
Will your bracket help me to accomplish that goal?
If so, what booster and master cylinder do you recommend I use with your bracket. I converted the front axle to disc brakes and have the correct proportioning block. My truck has a floor shifted automatic.
Rondaddy is offline   Reply With Quote
Old 04-20-2016, 11:07 PM   #195
Captainfab
60-66 Nut
I replied to your PM.
Old 05-05-2016, 08:59 AM   #196
mantolik
Hi - looking for one of these black power coated sent to 44001 -
mantolik is offline   Reply With Quote
Old 05-06-2016, 12:59 AM   #197
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Old 06-01-2016, 10:36 AM   #198
Already Gone
Can you send me ordering and pricing info on a black powdercoated brake booster bracket. I will give you a Montana address for shipping. I will need it in Montana by June 15th.
Old 06-01-2016, 10:56 PM   #199
Captainfab
60-66 Nut
I will send you a PM with ordering info. The prices are exactly the same as in post #1 of this for sale thread.
Old 08-08-2016, 12:47 AM   #200
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
