02-26-2016, 05:46 PM | #2626 |
Re: PO has me PO'd
hydratech delivered as promised... great packaging, bomb proof
WIN_20160226_163514 by [url=https://www.flickr.com/photos/131980308@N07/] WIN_20160226_163551 by [url=https://www.flickr.com/photos/131980308@N07/]
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-26-2016 at 05:56 PM. |
02-26-2016, 08:45 PM | #2627 |
Equal opportunity joke ofender
Re: PO has me PO'd
That should help the ole girl stop much nicer. Looking good Jim
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-26-2016, 09:35 PM | #2628 |
Re: PO has me PO'd
The plate is nice, much better than the steel one I got, which was a bit thin and crude, to the point I had another one machined. Still steel though, I needed it thicker so I could countersink the flanges on 3/8" rivetnuts.
02-28-2016, 05:28 AM | #2629 | ||
Re: PO has me PO'd
Anyone need OEM brackets and linkage for power brakes? Also, new brake booster After I get some flange nuts, I plan to run a bead of dumdum around the alum. To keep out water, every bracket I have taken off so far has had rust behind it Scorpio, great idea on the rivnuts, one of these days I'll get around to spending the money to buy that tool [url=https://flic.kr/p/E9GPYy]WIN_20160228_043230[/
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-28-2016 at 05:37 AM. |
02-28-2016, 06:33 PM | #2630 | |
Re: PO has me PO'd
The tool is about the size of a decent size set of bolt cutters. There is also smaller ones more like a typical pop-rivet tool that do #4 thru #12. For either of these you need a nose piece and a draw stud for each size you want to do. |
03-04-2016, 11:06 AM | #2631 |
Re: PO has me PO'd
Thanks Scorpio for the info
03-04-2016, 11:08 AM | #2632 |
Re: PO has me PO'd
Ok, must of filled up my allotted number of pages
03-04-2016, 12:25 PM | #2633 |
Re: PO has me PO'd
Don't know what's going on, but got the lines threaded. Don't use a wrench, unless you have 3-4 threads started by hand
I can only post up on the quick reply Loosen all brackets and mounting bolts and use a pipe wrench WIN_20160304_111823 by [url=https://www.flickr.com/photos/131980308@N07/]
03-05-2016, 12:52 AM | #2634 |
Re: PO has me PO'd
If you are out of pages they have to give you more. I have enjoyed it too much.
BR549 |
03-05-2016, 08:12 AM | #2635 |
Re: PO has me PO'd
Thanks Chad for watching, every time I try to post to quote, it takes me back to a previous one.
Anything new on your build?
03-05-2016, 05:00 PM | #2636 |
Re: PO has me PO'd
That Hyrdo Boost looks nice. I like how the hoses connect from the bottom. Where did you get this unit?
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
03-05-2016, 05:02 PM | #2637 |
Re: PO has me PO'd
whoops.. I scrolled up the page and found out. I'm looking to use the same unit as well
03-06-2016, 09:54 AM | #2638 | |
Re: PO has me PO'd
Flange nuts were in the box of parts, hooked up the premade hoses to the unit, now working on the linkage to the peddle, and mount the tank, still want to get cover for m/c plated, not sure which type of plating, black or phosphate. Black may tie in better with the 49 shades of grey, have to ask Pete who he used Www.hydratechbraking.com has three levels of build, 3-4 weeks lead time WIN_20160306_084213 by [url=https://www.flickr.com/photos/131980308@N07/]
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-06-2016 at 10:05 AM. |
03-09-2016, 12:59 AM | #2639 |
Re: PO has me PO'd
Jim...my build is going well. Just slow. I had to work most of the month of February so I haven't done much lately. However I hope over the next couple weeks to make some significant progress. Here are a couple pics. Thanks for asking.
BR549 |
03-09-2016, 01:01 AM | #2640 |
Re: PO has me PO'd
Framework
BR549 |
03-10-2016, 09:40 AM | #2641 |
Re: PO has me PO'd
Thanks Chad for watching, progress looks good on your truck
Been in contact with Petersen fluid to make a new power steering canister, don't want to use a 'T' fitting, so I'll add another -6 fitting to the can for the return. Drawing should be done Friday, and about a week to build, if the drawing is correct. They told me the fitting inside should have a bend, so to swirl the fluid and allow the air to separate. My plan is to mount it on the prop. valve bracket
03-13-2016, 11:20 AM | #2642 |
Re: PO has me PO'd
Here's a drawing of the new can, should take about a week to make
08-0481-SPEC by [url=https://www.flickr.com/photos/131980308@N07/]
03-14-2016, 01:36 PM | #2643 |
Re: PO has me PO'd
03-15-2016, 09:52 AM | #2644 |
Re: PO has me PO'd
That's the right port for high pressure. I just checked mine for confirmation.
03-15-2016, 05:24 PM | #2645 |
Re: PO has me PO'd
Thank you for your time Dan
03-17-2016, 12:32 PM | #2646 |
Re: PO has me PO'd
Ordered my remanufactured power steering pump from NAPA yesterday, arrived this morning 8 am, 40.00 w/ core.
[url=https://flic.kr/p/ErW6Bx][/ Just have to make up some hoses Found a fitting supply that doesn't know the meaning of " not in stock". Pure choice motorsports, needed a an -6 female swivel to 90 degree bend 3/8" push on barb, for the low pressure port on the steering box Also, my SS socket head cap screw are about 1/2" long for the mount, so I'll have to get some shorter ones
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-17-2016 at 12:44 PM. |
03-17-2016, 02:03 PM | #2647 |
Re: PO has me PO'd
This is such a great build, learning a ton from it. Thanks Jim!
03-17-2016, 02:08 PM | #2648 | |
Re: PO has me PO'd
Hope you get that driveshaft worked out... since a shop did the lower, can you have them address it My new thoughts are tending to the steering knuckle
03-18-2016, 12:29 AM | #2649 |
60-66 Nut
Re: PO has me PO'd
If you don't mind my asking, what is the application or part number for that PS pump?
03-18-2016, 08:53 AM | #2650 |
Re: PO has me PO'd
Sure captain, 1972 350 cu. in. GMC jimmy and pick up
NAPA's part #38-5141, I bought mine w/o tank, you can get either way. No pulley and no mount, but was an exact match to mine. My pulley had a key If you get yours w/o tank, make sure you keep your mounting bolts for the tank, as it doesn't come with them, but does include the pressure port fitting
