Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-31-2016, 12:00 AM   #326
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
I replied to your PM.
Old 02-29-2016, 06:32 PM   #327
The Rocknrod
Moderator
The Rocknrod's Avatar
I'm looking for the boot to use (dust boot) on the firewall. Would this work?:
http://www.classicparts.com/1963-72-.../#.VtTGluYYFas
63-72 Push Rod Boot
Old 03-01-2016, 12:57 AM   #328
Captainfab
60-66 Nut
I have not tried that part, but it looks like it should work.
Old 03-18-2016, 12:29 PM   #329
ARG0220
Captainfab,
I'm building a 65 GMC shortbed truck with my son. We are using the drive train from a 69 chevy longbed including the powersteering/steering linkage components. I'm interested in the bracket but have a few questions regarding the swap and use of your bracket.
Thanks,
ARG0220
ARG0220 is offline   Reply With Quote
Old 03-18-2016, 11:55 PM   #330
Captainfab
60-66 Nut
I'll send you a PM.
Originally Posted by ARG0220 View Post
Captainfab,
Thanks,
ARG0220
Old 03-26-2016, 10:59 PM   #331
62bagger
62bagger's Avatar
Has anyone converted to non power disc brakes? Is this a possibility?
62bagger is offline   Reply With Quote
Old 03-26-2016, 11:49 PM   #332
Captainfab
60-66 Nut
It is done quite frequently. All you need is a manual master cylinder for disc brakes and bolt it to your firewall.
Old 03-28-2016, 12:02 PM   #333
62bagger
62bagger's Avatar
Thanks for the quick response. This is my first complete brake system install. The info is much appreciated.
Old 04-03-2016, 10:21 AM   #334
doublebeetx
Capt. will you pm payment info ?
doublebeetx is offline   Reply With Quote
Old 04-03-2016, 11:35 PM   #335
Captainfab
60-66 Nut
PM sent.
Old 04-05-2016, 10:57 PM   #336
doublebeetx
I sent PayPal and pm for a bracket. Thank you !
Old 04-05-2016, 11:13 PM   #337
Captainfab
60-66 Nut
Payment received and PM replied to.
Old 04-09-2016, 07:25 PM   #338
1968vetL-71
Junior Member
1968vetL-71's Avatar
captainfab, Just making sure this will work for a 68 swb 4x4 frame? It is has the flat area for the steering box. Thx!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 04-10-2016, 12:34 AM   #339
Captainfab
60-66 Nut
Tis is the for sale thread for the '63-'66 brake booster not the steering box adapter plate.
To answer your question, I have sold many steering box adapter plates that have been installed on K series frames. I just do not have installation instructions or a template specific to the K series frames. I can give you a link to a build thread that has all the dimensions and pictures you need.
Old 04-10-2016, 01:03 PM   #340
1968vetL-71
Junior Member
My bad, i was going through so many threads about them i just replied. lol.
Yes that would be great!
Thank you sir!
Old 04-10-2016, 11:38 PM   #341
Captainfab
60-66 Nut
I posted a link in the power steering box adapter plate for sale thread.
Old 04-12-2016, 10:18 AM   #342
Lugnutz65
Lugnutz65's Avatar
Sent you some dough for the Booster bracket.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-12-2016, 11:57 PM   #343
Captainfab
60-66 Nut
Payment received. I should be able to ship your booster bracket on Thursday.
Old 05-08-2016, 09:18 PM   #344
Vortech
Vortech's Avatar
Captain, I need a booster bracket for 65 C10.
Vortech is offline   Reply With Quote
Old 05-08-2016, 11:03 PM   #345
Captainfab
60-66 Nut
Old 05-15-2016, 06:23 PM   #346
yellowGT
yellowGT's Avatar
Do you have some adapter brackets in stock? Just trying to figure out turnaround time for one.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 05-15-2016, 10:53 PM   #347
Captainfab
60-66 Nut
I replied to your PM. Other than a couple of powder coated booster brackets in stock, most orders are built when ordered.
Old 05-25-2016, 01:05 PM   #348
dschmit
Where can i source the vacuum for adding a brake booster? 1965 283. There is PCV valve and fitting behind carb that has a plug on oppsite side of the valve. Can I use that plugged port for the booster vacuum source, or does it have to be isolated from the PCV?
dschmit is offline   Reply With Quote
Old 05-25-2016, 11:41 PM   #349
Captainfab
60-66 Nut
The vacuum for the PCV should be isolated from any other vacuum operated accessory. Is there no manifold vacuum port on the carburator? If the one with the PCV is the only one, then you will have to use that. Another option is a carb spacer with a vacuum port. Of course this depends on what carb you have.
Old 08-08-2016, 12:46 AM   #350
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
